Better code check before compile?
Results 1 to 30 of 30
    Default Re: Better code check before compile?
    no, it is not, because if I add GOSUB statement, it is being triggered on IF-THEN condition only.
    Sep 2009
    Hehe. Read manual...
    This : replaces new row. Same as you press enter on your keyboard. So try to compile code from my code above. You will get same results.
    Only thing behind THEN depending on IF. Next statement after : does not.
    Sep 2009
    From manual
    2.18 Line-Concatenation ( : )
    Multiple commands may be written on a single line using colon characters to tell PBP where to insert a "virtual" line break.
    I agree with peja089, the colon acts as a virtual line break.
    If more than a signle statement should execute as a result of the evaluation use IF-THEN-ENDIF.
    With that said... In section 5.35 of the manual they actually DO show the following as a valid example:
    IF B0 <> 10 THEN B0 = B0 + 1: B1 = B1 - 1
    And in fact, when compiling the followong code for a 16F628 both the Test1 and Test2 routines results in the same assembly code
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    D VAR BYTE
    Test1:
    IF A = 12 THEN B = 2 : C = 3 :  D = 4
    Test2:
    IF A = 12 THEN
      B=2
      C=3
      D=4
    Here's the resulting assembly (both versions looks identical to me (wasn't really expecting that to be honest):
    _Test1
             clrwdt
             movf    _A,  W
             sublw   00Ch
             btfss   STATUS, Z
             goto    L00001
             movlw   low (002h)
             movwf   _B
             movlw   low (003h)
             movwf   _C
             movlw   low (004h)
             movwf   _D
    L00001
    _Test2
            clrwdt
            movf    _A,  W
            sublw   00Ch
            btfss   STATUS, Z
            goto    L00003
            movlw   low (002h)
            movwf   _B
            movlw   low (003h)
            movwf   _C
            movlw   low (004h)
            movwf   _D
    L00003
    That got me curious so I compiled both version of the original code
    ticker VAR BYTE
    ard VAR BYTE
    atrig VAR BYTE
    Test1:
    if ticker>150 and ard<140 and atrig=0 then ticker=1: atrig=1
    Test2:
      ticker=1
      atrig=1
    And the resulting assebly (less library code) looks like this:
    _Test1
            movf    _ticker, W
            movwf   R0
            movlw   low (096h)
            call    CMPGTB
            movwf   T1
            movf    _ard, W
            movwf   R0
            movlw   low (08Ch)
            call    CMPLTB
            movwf   T2
            movf    T1,  W
            movwf   FSR
            movf    T2,  W
            call    LAND
            movwf   T2
            movwf   T2   + 1
            movf    _atrig, W
            sublw   000h
            btfss   STATUS, Z
            movlw   -1
            xorlw   0ffh
            movwf   T3
            movf    T2,  W
            iorwf   T2  + 1, W
            movwf   FSR
            movf    T3,  W
            call    LAND
            movwf   T3
            movwf   T3   + 1
            clrwdt
            movf    T3,  W
            iorwf   (T3)  + 1, W
            btfsc   STATUS, Z
            goto    L00001
            movlw   low (001h)
            movwf   _ticker
            movlw   low (001h)
            movwf   _atrig
    L00001
    _Test2
            movf    _ticker, W
            movwf   R0
            movlw   low (096h)
            call    CMPGTB
            movwf   T1
            movf    _ard, W
            movwf   R0
            movlw   low (08Ch)
            call    CMPLTB
            movwf   T2
            movf    T1,  W
            movwf   FSR
            movf    T2,  W
            call    LAND
            movwf   T2
            movwf   T2   + 1
            movf    _atrig, W
            sublw   000h
            btfss   STATUS, Z
            movlw   -1
            xorlw   0ffh
            movwf   T3
            movf    T2,  W
            iorwf   T2  + 1, W
            movwf   FSR
            movf    T3,  W
            call    LAND
            movwf   T3
            movwf   T3   + 1
            clrwdt
            movf    T3,  W
            iorwf   (T3)  + 1, W
            btfsc   STATUS, Z
            goto    L00003
            movlw   low (001h)
            movwf   _ticker
            movlw   low (001h)
            movwf   _atrig
    L00003
    As far as I can see they are identical, meaning atrig will only get set to 1 if the evaulation is true. So I don't know what might be happening in CuriousOnes case because as far as I can see it IS working as CuriousOne expects - which I did NOT expect.
    Sep 2009
    ... which I did NOT expect.
    Same here
  1. Code check and refinement suggestions?
    Last Post: - 31st July 2013, 03:37
  2. Replies: 4
    Last Post: - 24th January 2007, 23:20
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Can some one please check my code out thanks
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 09:19
  5. Code check (sorry)
    By barkerben in forum General
    Last Post: - 30th November 2004, 16:54
