Better code check before compile?
Results 1 to 30 of 30
    Default Re: Better code check before compile?
    Even more simple.
    Just add different label for subroutines, say, subroutines should start with SUB statement, after the label. At compile time, do check and that's all.
    Sep 2009
    Then 80% of my programs wouldn't compile. I often use multiple entry point in same sub. And have only one return at end.
    Or the reverse. Have one entry and multiple exits:
    gosub test
    test:
    if x=1 then
       a=1
    if x=2 then
       a=2
    So you're doing it wrong - same for overlapping for-next cycles
    If you mean my example, OK, it is a not efficient one but I was trying to show that you can have many Returns from the same sub.
    Sure it can be made more compact or efficient, but still. Compiler has difficult time to check this for errors.
    Ok, here is an example (not exact syntax, just to get idea)
    MAINCODE: 'do something
    high PORTC.0
    PAUSE 500
    low PORTC.0
    Pause 500
    GOSUB CHECKER
    GOTO MAINCODE
    CHECKER:
    TOGGLE PORTD.0
    In above example, if we remove RETURN, it will compile fine in PBP, but will produce unusable code. But even on ZX Spectrum, it would give us "Gosub without return" error, and save our time.
    Agreed. This is easy to check, but above we stated other cases that are difficult to check.
    So a sub-without-return check in whole is not easy to implement. I suppose... Maybe Charles knows better to justify it.
  1. Code check and refinement suggestions?
    Last Post: - 31st July 2013, 03:37
  2. Replies: 4
    Last Post: - 24th January 2007, 23:20
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Can some one please check my code out thanks
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 09:19
  5. Code check (sorry)
    By barkerben in forum General
    Last Post: - 30th November 2004, 16:54
