PID Filter Coefficient
Results 1 to 6 of 6
    Dec 2019
    Stuart, FL USA
    Default Re: PID Filter Coefficient
    Thanks for the reply Henrik,
    I thought that I might have to disable that feature in Simulink. The PID Tuner should still be able to generate the optimum P, I, and D gains.
    I can add noise filtering (a few R's and C's) to my thermocouple amplifier that senses the flame temperature and provides the feedback signal.
    If you or anyone comes across a way to provide some first order filtering in the digital domain for a PIC16F1937 for this application, I would love to see it!
    Thanks again,
    Jacob
    Take a look at Tracy Allens pages on math (and other stuff) routines for the BasicStamp, specifically this page when digital filtering is covered. I've adopted one of the routines for PBP. I believe, at one point, I stuck that routine to the output of the PID filter but I've never posted it and I don't think I've done/tested anything with it. I'll leave you with the filter itself for you to what you want with.
    '*  Name    : LowPassFilter.pbp                                 *
    '*  Author  : Henrik Olsson                                     *
    '*  Notice  : Copyright (c) 2010 Henrik Olsson 2010             *
    '*  Date    : 2010-09-01                                        *
    '*  Notes   : Adopted from Tracy Allens BS2Math pages.          *
    '--Variables accessed from "outside"--
    LowPassFilter_Constant VAR BYTE
    LowPassFilter_Input VAR WORD
    LowPassFilter_Output VAR WORD
    '--Variable used internally
    Filter_Sign VAR BIT
    Filter_Value VAR WORD
    Filter_Z VAR WORD
    Filter_Y VAR WORD
    '--User must set LowPassFilter_Constant to 0-9 and then GOSUB InitLowPassFilter before
    '--calling the actual filter routine.
    pid_LP_Filter_Init:
    Select Case LowPassFilter_Constant
    CASE 0
     Filter_Value = 65535
    Case 1
     Filter_Value = 32768
    Case 2
     Filter_Value = 21846
    Case 3
     Filter_Value = 16384
    Case 4
     Filter_Value = 13108
    Case 5
     Filter_Value = 10923
     Case 6
     Filter_Value = 9363
     Case 7
     Filter_Value = 8192
     CASE 8
     Filter_Value = 7282
     Case 9
     Filter_Value = 6554
    End Select
    LowPassFilter:
    If LowPassFilter_Constant = 0 then
        LowPassFilter_Output = LowPassFilter_Input
        Goto LowPassFilterDone
    'Max difference between current filter output and a new input to the filter
    'is 2048 so it's recomended to all input values clamped to +/-1024 or unexpected
    'results may occur,
    'Complete filter executes in 174-177 cycles----
    'Multiply input by 16 (shift left by 4) then subtract the current output (times 16) to get the difference. (47 cycles)
    Filter_Z = LowPassFIlter_Input << 4
    Filter_Z = Filter_Z - Filter_Y
    'Get the sign of the difference then convert to ABSolute value (7 cycles).
    Filter_Sign = Filter_Z.15               ' sign of the difference          (4 cycles)
    Filter_Z = abs Filter_Z                 ' magnitude of the difference     (3 cycles)
    'Add then divide. Basically this is the same as A=(A+1)/2, A=(A+2)/3, A=(A+3)/4 etc.
    'All in all 52 cycles.
    Filter_Z = Filter_Z + LowPassFilter_Constant  '(52 cycles including ** operation on next line
    Filter_Z = Filter_Z ** Filter_Value
    'Now the value is scaled and needs to be added to or subtracted from the output. (8 or 10 cycles)
    If Filter_Sign then
      Filter_Y = Filter_Y - Filter_Z
      Filter_Y = Filter_Y + Filter_Z
    Filter_Sign = Filter_Y.15           ' sign of total output  (4 cycles)
    'Get absoulte value and divide by 16 to scale down the value to the same scale
    'as the original input value. Then re-apply the sign. (50 or 52 cycles)
    LowPassFilter_Output = (ABS Filter_Y) >> 4
    If Filter_Sign then LowPassFilter_Output = -LowPassFilter_Output    '(4 or 7 cycles)
    LowPassFilterDone:
  1. PID-filter routine (2nd try).
    By HenrikOlsson in forum Code Examples
    Last Post: - 3rd October 2018, 08:53
  2. PID help
    Last Post: - 4th November 2011, 07:32
  3. Pid
    By colarsson in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 11:18
  4. digital filter
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 15th September 2004, 02:28
  5. RC Filter
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2004, 14:49
