HSEROUT not working @ 40 MHz
Results 1 to 8 of 8
    Default Found the problem
    After looking through the pbppic18.lib file I noticed that the problem was with the line HSER_TXSTA 24h. It should be HSER_TXSTA 20h.
    mmm yes no toaster hamburger after all. I bet you use HSER_BAUD instead of HSER_SPBRG right?
    IF SO it's probably caused by the internal calculation of the SPBRG value.
    Wich BaudRate you wanted to use??? Did you look in the datasheet for the SPBRG value with the TXSTA you did???
    I'm just curious about that one.
    Just to satisfy your curiosity Mr E
    DEFINE  HSER_BAUD 9600
    DEFINE  HSER_CLROERR 1
    DEFINE  HSER_RCSTA 90h
    DEFINE  HSER_TXSTA 20h
    HEHE i was right... I post a SPBRH Calc on this forum to help to figure out.
    BTW here's a short explanation. Using the Calc @9600 baud with 40MHZ with TXSTA = $24 give a SPBRG of 255 with error % 1.725. If you decrease this value the error % increase, so increasing SPBRG will reduce the error %... as SPBRG is a Byte register, you can't or you'll be OUT OF RANGE
    Warning[202] c:\pbp\pbppic18.lib 7695: Argument out of range. Least significant bits used.
    This is where it's coming from
    NOW using SPBRG=20 @40MHZ 9600 bauds gives a SPBRG=64 and error % 0.16
    I'm Satisfied now
    Can you post a link to this Calc. This could come in handy in the future.
    here's the link for the download... on this forum
    http://www.picbasic.co.uk/forum/atta...tachmentid=316
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 19:12
  3. Need help multiplexing EUSART output
    Last Post: - 7th April 2008, 19:17
  4. help
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2005, 20:42
  5. Need once your help one please
    Last Post: - 9th February 2005, 20:33
