Interesting! This is what I get when I connect a commercial USB-to-MIDI interface
Connection Status : 0x01 (Device is connected)
Port Chain : 5-2
PortAttributes : 0x00000000
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : Samengesteld USB-apparaat
Device Path : \\?\usb#vid_1a86&pid_752d#5&11561f21&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_1A86&PID_752D\5&11561F21&0&2
Hardware IDs : USB\Vid_1a86&Pid_752d&Rev_0254 USB\Vid_1a86&Pid_752d
Driver KeyName : {36FC9E60-C465-11CF-8056-444553540000}\0042 (GUID_DEVCLASS_USB)
Driver : system32\DRIVERS\usbccgp.sys (Version: 5.1.2600.6437 Date: 2013-08-09)
Driver Inf : C:\WINDOWS\inf\usb.inf
Legacy BusType : PNPBus
Class : USB
Class GUID : {36FC9E60-C465-11CF-8056-444553540000} (GUID_DEVCLASS_USB)
Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Service : usbccgp
Enumerator : USB
Location Info : USB2.0-MIDI
Manufacturer Info : (Standaard USB Host Controller)
Capabilities : 0x84 (Removable, SurpriseRemovalOK)
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
Address : 2
Power State : D0 (supported: D0, D3, wake from D0)
Child Device 1 : USB-audioapparaat
DevicePath : \\?\usb#vid_1a86&pid_752d&mi_00#6&8f9c2ed&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}
KernelName : \Device\00000082
Device ID : USB\VID_1A86&PID_752D&MI_00\6&8F9C2ED&0&0000
Class : MEDIA
+++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags
GlobalDisableSerNumGen : REG_BINARY 01
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\1A86752D0254
osvc : REG_BINARY 00 00
---------------- Connection Information ---------------
Connection Index : 0x02 (2)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x01
Device Address : 0x01 (1)
Is Hub : 0x00 (no)
Device Bus Speed : 0x01 (Full-Speed)
Number Of Open Pipes : 0x02 (2 pipes to data endpoints)
Pipe[0] : EndpointID=2 Direction=OUT ScheduleOffset=0 Type=Bulk
Pipe[1] : EndpointID=2 Direction=IN ScheduleOffset=0 Type=Bulk
Data (HexDump) : 02 00 00 00 12 01 10 01 00 00 00 08 86 1A 2D 75 ..............-u
54 02 00 02 00 01 01 01 00 01 00 02 00 00 00 01 T...............
00 00 00 09 05 02 02 20 00 00 00 00 00 00 09 05 ....... ........
82 02 20 00 00 00 00 00 00 .. ......
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x110 (USB Version 1.10)
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x08 (8 bytes)
idVendor : 0x1A86
idProduct : 0x752D
bcdDevice : 0x0254
iManufacturer : 0x00 (No String Descriptor)
iProduct : 0x02 (String Descriptor 2)
Language 0x0409 : "USB2.0-MIDI"
iSerialNumber : 0x00 (No String Descriptor)
bNumConfigurations : 0x01 (1 Configuration)
Data (HexDump) : 12 01 10 01 00 00 00 08 86 1A 2D 75 54 02 00 02 ..........-uT...
00 01 ..
------------------ Configuration Descriptor -------------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x0075 (117 bytes)
bNumInterfaces : 0x02 (2 Interfaces)
bConfigurationValue : 0x01 (Configuration 1)
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0x80
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0x30 (96 mA)
Data (HexDump) : 09 02 75 00 02 01 00 80 30 09 04 00 00 00 01 01 ..u.....0.......
00 00 09 24 01 00 01 09 00 01 01 09 04 01 00 02 ...$............
01 03 00 00 07 24 01 00 01 51 00 06 24 02 01 02 .....$...Q..$...
00 06 24 02 01 03 00 06 24 02 02 06 00 09 24 03 ..$.....$.....$.
01 07 01 06 01 00 09 24 03 02 04 01 02 01 00 09 .......$........
24 03 02 05 01 03 01 00 09 05 02 02 20 00 00 00 $........... ...
00 06 25 01 02 02 03 09 05 82 02 20 00 00 00 00 ..%........ ....
05 25 01 01 07 .%...
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00
bAlternateSetting : 0x00
bNumEndpoints : 0x00 (Default Control Pipe only)
bInterfaceClass : 0x01 (Audio)
bInterfaceSubClass : 0x01 (Audio Control)
bInterfaceProtocol : 0x00
iInterface : 0x00 (No String Descriptor)
Data (HexDump) : 09 04 00 00 00 01 01 00 00 .........
------ Audio Control Interface Header Descriptor ------
bDescriptorType : 0x24 (Audio Interface Descriptor)
bDescriptorSubtype : 0x01 (Header)
bcdADC : 0x0100
wTotalLength : 0x0009 (9 bytes)
bInCollection : 0x01
baInterfaceNr[1] : 0x01
Data (HexDump) : 09 24 01 00 01 09 00 01 01 .$.......
bInterfaceNumber : 0x01
bNumEndpoints : 0x02 (2 Endpoints)
bInterfaceSubClass : 0x03 (MIDI Streaming)
Data (HexDump) : 09 04 01 00 02 01 03 00 00 .........
- MIDI Adapter Class specific MS Interface Descriptor -
bLength : 0x07 (7 bytes)
bDescriptorType : 0x24 (Class Specific Interface Descriptor)
bDescriptorSubtype : 0x01 (MS Header)
bcdADC : 0x0100
wTotalLength : 0x0051 (81 bytes)
Data (HexDump) : 07 24 01 00 01 51 00 06 24 02 01 02 00 06 24 02 .$...Q..$.....$.
01 03 00 06 24 02 02 06 00 09 24 03 01 07 01 06 ....$.....$.....
01 00 09 24 03 02 04 01 02 01 00 09 24 03 02 05 ...$........$...
01 03 01 00 09 05 02 02 20 00 00 00 00 06 25 01 ........ .....%.
02 02 03 09 05 82 02 20 00 00 00 00 05 25 01 01 ....... .....%..
07 .
---------------- MIDI IN Jack Descriptor --------------
bLength : 0x06 (6 bytes)
bDescriptorSubtype : 0x02 (MIDI_IN_JACK)
bJackType : 0x01 (Embedded)
bJackID : 0x02 (ID=2)
iJack : 0x00 (No String Descriptor)
Data (HexDump) : 06 24 02 01 02 00 .$....
bJackID : 0x03 (ID=3)
Data (HexDump) : 06 24 02 01 03 00 .$....
bJackType : 0x02 (External)
bJackID : 0x06 (ID=6)
Data (HexDump) : 06 24 02 02 06 00 .$....
--------------- MIDI OUT Jack Descriptor --------------
bDescriptorSubtype : 0x03 (MIDI_OUT_JACK)
bJackID : 0x07 (ID=7)
bNrInputPins : 0x01 (1 pin)
baSourceID(1) : 0x06 (input pin connected to entity ID=6)
baSourcePin(1) : 0x01 (connected to input pin number 1
Data (HexDump) : 09 24 03 01 07 01 06 01 00 .$.......
bJackID : 0x04 (ID=4)
baSourceID(1) : 0x02 (input pin connected to entity ID=2)
Data (HexDump) : 09 24 03 02 04 01 02 01 00 .$.......
bJackID : 0x05 (ID=5)
baSourceID(1) : 0x03 (input pin connected to entity ID=3)
Data (HexDump) : 09 24 03 02 05 01 03 01 00 .$.......
----------------- Endpoint Descriptor -----------------
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x02 (Direction=OUT EndpointID=2)
bmAttributes : 0x02 (TransferType=Bulk)
wMaxPacketSize : 0x0020 (32 bytes)
bInterval : 0x00 (0 ms)
bRefresh : 0x00
bSynchAddress : 0x00
Data (HexDump) : 09 05 02 02 20 00 00 00 00 .... ....
--- Class-Specific MS Bulk Data Endpoint Descriptor ---
bDescriptorType : 0x25 (Audio Endpoint Descriptor)
bDescriptorSubtype : 0x01 (MS General)
bNumEmbMIDIJack : 0x02 (2 embedded MIDI jacks)
baAssocJackID(1) : 0x02 (Jack(1) ID=2)
baAssocJackID(2) : 0x03 (Jack(2) ID=3)
Data (HexDump) : 06 25 01 02 02 03 .%....
bEndpointAddress : 0x82 (Direction=IN EndpointID=2)
bRefresh : 0x00
Data (HexDump) : 09 05 82 02 20 00 00 00 00 .... ....
bLength : 0x05 (5 bytes)
bNumEmbMIDIJack : 0x01 (1 embedded MIDI jack)
baAssocJackID(1) : 0x07 (Jack(1) ID=7)
Data (HexDump) : 05 25 01 01 07 .%...
-------------------- String Descriptors -------------------
------ String Descriptor 0 ------
bLength : 0x04 (4 bytes)
bDescriptorType : 0x03 (String Descriptor)
Language ID[0] : 0x0409 (English - United States)
Data (HexDump) : 04 03 09 04 ....
------ String Descriptor 1 ------
bLength : 0x18 (24 bytes)
Data (HexDump) : 18 03 55 00 53 00 42 00 32 00 2E 00 30 00 2D 00 ..U.S.B.2...0.-.
4D 00 49 00 44 00 49 00 M.I.D.I.
------ String Descriptor 2 ------
------ String Descriptor 3 ------
