MIDI Descriptor for USB communication
Results 1 to 17 of 17
Threaded View
  1. #4
    Default Re: MIDI Descriptor for USB communication
    You apparently have or have access to a commercial MIDI-to-USB interface. Several USB monitor will generate a descriptor of a connected device (albeit not in exactly PBP format). I have several installed and if you're interested I will see if any for free/trial one will do that.
    For example USB Device Tree generates this for a Pickit2
    =========================== USB Port1 ===========================
    Connection Status : 0x01 (Device is connected)
    Port Chain : 3-1-2-1
    ======================== USB Device ========================
    +++++++++++++++++ Device Information ++++++++++++++++++
    Device Description : USB Input Device
    Device Path : \\?\usb#vid_04d8&pid_0033#7&2f97cc0d&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    Device ID : USB\VID_04D8&PID_0033\7&2F97CC0D&0&1
    Hardware IDs : USB\VID_04D8&PID_0033&REV_0002 USB\VID_04D8&PID_0033
    Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0051 (GUID_DEVCLASS_HIDCLASS)
    Driver : system32\DRIVERS\hidusb.sys (Version: 6.1.7601.17514 Date: 2010-11-21)
    Driver Inf : C:\Windows\inf\input.inf
    Legacy BusType : PNPBus
    Class : HIDClass
    Class GUID : {745a17a0-74d3-11d0-b6fe-00a0c90f57da} (GUID_DEVCLASS_HIDCLASS)
    Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
    Service : HidUsb
    Enumerator : USB
    Location Info : Port_#0001.Hub_#0006
    Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(1)#USB(2)#USB( 1)
    Container ID : {6b462c36-dc86-11e9-b239-f4b7e2dd97cc}
    Manufacturer Info : (Standard system devices)
    Capabilities : 0x84 (Removable, SurpriseRemovalOK)
    Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
    Problem Code : 0
    Power State : D0 (supported: D0, D2, D3, wake from D0, wake from D2)
    Child Device 1 : HID-compliant device
    DevicePath : \\?\hid#vid_04d8&pid_0033#8&cbf5855&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    KernelName : \Device\00000112
    Device ID : HID\VID_04D8&PID_0033\8&CBF5855&0&0000
    Class : HIDClass
    +++++++++++++++++ Registry USB Flags +++++++++++++++++
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\usbflags\04D800330002
    osvc : REG_BINARY 00 00
    SkipContainerIdQuery : REG_BINARY 00 00 00 00
    ---------------- Connection Information ---------------
    Connection Index : 0x01 (1)
    Connection Status : 0x01 (DeviceConnected)
    Current Config Value : 0x01
    Device Address : 0x1C (28)
    Is Hub : 0x00 (no)
    Device Bus Speed : 0x01 (Full-Speed)
    Number Of Open Pipes : 0x02 (2 pipes to data endpoints)
    Pipe[0] : EndpointID=1 Direction=IN ScheduleOffset=0 Type=Interrupt
    Pipe[1] : EndpointID=1 Direction=OUT ScheduleOffset=0 Type=Interrupt
    ---------------------- Device Descriptor ----------------------
    bLength : 0x12 (18 bytes)
    bDescriptorType : 0x01 (Device Descriptor)
    bcdUSB : 0x200 (USB Version 2.00)
    bDeviceClass : 0x00 (defined by the interface descriptors)
    bDeviceSubClass : 0x00
    bDeviceProtocol : 0x00
    bMaxPacketSize0 : 0x08 (8 bytes)
    idVendor : 0x04D8 (Microchip Technology Inc.)
    idProduct : 0x0033
    bcdDevice : 0x0002
    iManufacturer : 0x01 (String Descriptor 1)
    Language 0x0409 : "Microchip Technology Inc."
    iProduct : 0x02 (String Descriptor 2)
    Language 0x0409 : "PICkit 2 Microcontroller Programmer"
    iSerialNumber : 0x03 (String Descriptor 3)
    Language 0x0409 : "Љ"
    bNumConfigurations : 0x02 (2 Configurations)
    ------------------ Configuration Descriptor -------------------
    bLength : 0x09 (9 bytes)
    bDescriptorType : 0x02 (Configuration Descriptor)
    wTotalLength : 0x0029 (41 bytes)
    bNumInterfaces : 0x01 (1 Interface)
    bConfigurationValue : 0x01 (Configuration 1)
    iConfiguration : 0x02 (String Descriptor 2)
    bmAttributes : 0x80
    D7: Reserved, set 1 : 0x01
    D6: Self Powered : 0x00 (no)
    D5: Remote Wakeup : 0x00 (no)
    D4..0: Reserved, set 0 : 0x00
    MaxPower : 0x32 (100 mA)
    ---------------- Interface Descriptor -----------------
    bDescriptorType : 0x04 (Interface Descriptor)
    bInterfaceNumber : 0x00
    bAlternateSetting : 0x00
    bNumEndpoints : 0x02 (2 Endpoints)
    bInterfaceClass : 0x03 (HID - Human Interface Device)
    bInterfaceSubClass : 0x00 (None)
    bInterfaceProtocol : 0x00 (None)
    iInterface : 0x00 (No String Descriptor)
    ------------------- HID Descriptor --------------------
    bDescriptorType : 0x21 (HID Descriptor)
    bcdHID : 0x0001 (HID Version 0.01)
    bCountryCode : 0x00 (00 = not localized)
    bNumDescriptors : 0x01
    Descriptor 1:
    bDescriptorType : 0x22 (Class=Report)
    wDescriptorLength : 0x001D (29 bytes)
    Error reading descriptor : ERROR_GEN_FAILURE
    ----------------- Endpoint Descriptor -----------------
    bLength : 0x07 (7 bytes)
    bDescriptorType : 0x05 (Endpoint Descriptor)
    bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
    bmAttributes : 0x03 (TransferType=Interrupt)
    wMaxPacketSize : 0x0040 (64 bytes)
    bInterval : 0x01 (1 ms)
    bEndpointAddress : 0x01 (Direction=OUT EndpointID=1)
    bConfigurationValue : 0x01 (Configuration 1) *!*ERROR: Configuration 1 is defined more than once
    bmAttributes : 0x80
    Descriptor 1:
    ----------------- Device Qualifier Descriptor -----------------
    Error : ERROR_GEN_FAILURE
    -------------------- String Descriptors -------------------
    ------ String Descriptor 0 ------
    bLength : 0x04 (4 bytes)
    bDescriptorType : 0x03 (String Descriptor)
    Language ID[0] : 0x0409 (English - United States)
    ------ String Descriptor 1 ------
    bLength : 0x34 (52 bytes)
    ------ String Descriptor 2 ------
    bLength : 0x48 (72 bytes)
    ------ String Descriptor 3 ------
    George
  1. MIDI over USB
    By RuudNL in forum mel PIC BASIC Pro
    Last Post: - 11th November 2017, 23:33
  2. 2 Axes USB HID Descriptor problem
    By TronicBrain in forum USB
    Last Post: - 18th March 2014, 05:06
  3. MIDI over USB peripheral
    By aberco in forum USB
    Last Post: - 31st October 2011, 16:06
  4. MIDI to USB
    By DaveC3 in forum USB
    Last Post: - 31st March 2011, 21:38
  5. USB to MIDI module
    By Coco Sapone in forum Adverts
    Last Post: - 23rd October 2010, 18:13
