which op-amp?
Results 1 to 3 of 3
Thread: which op-amp?
    Jun 2004
    Question which op-amp?
    Trying to link a KMC-10 magnetic current sensor to a 16F73 ADC input, but also need a 0 to 10 volt aux output.
    Because the sensor is a bridge (output in mV) am using a classic differential amplifier (1 op-amp, 4 resistors). To keep circuit simple decided to use a single ended op-amp, powered from a 7812 regulator.
    Choosing the best op-amp proving a nightmare (no probs if I had a -12V rail), just unable to get the output to be 0V for no current I/P. So far had best results from a LM383, TLC271 and CA3160.
    Wondered what amplifer others use for sensor signal conditioning?
    We are currently using Intersils CA3140E and CA3240E. Both parts seem to work really good. The only problem that we seen was if we did not have a 100 ohm resistor on the output and a small AC signal back fed it would smoke it. With the 100R resistor in series it works flawless. We on use 2 resistors in ours which seems to work pretty good.
    google search gives me
    http://cms.hlplanar.de/data-live-pla...ng/KMC1_20.pdf
    TL072 should work and it's very cheap
  1. PIC 16f877 A/D conversion Allegro ACS712
    By DavyJones in forum General
    Last Post: - 4th June 2011, 04:54
  2. small dc signal amplifier schematic need
    By phoenix_1 in forum Schematics
    Last Post: - 8th May 2009, 03:32
  3. Help with using op amp as a sine-to-square converter!
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 12th March 2009, 16:06
  4. Serin2 - All I Need Is 8 Numbers....
    By SOMRU in forum Serial
    Last Post: - 14th December 2006, 13:50
  5. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
