How to use TM1637 chip for LED Display?
Results 1 to 14 of 14
Threaded View
  1. #3
    Default Re: How to use TM1637 chip for LED Display?
    Mike is correct
    try this , it works on a 12f1822
    note leds 2,3 and 4 show random crap since nothing is written to them
    and not using lat regs is asking for trouble
    nearly forgot dispnum = 146 ' "2" (Common anode) (10010010)
    not on my display
    dispnum = $5b ' "2" (Common anode) (01011101)
    OSCCON = %01111000 '16MHz HF, software PLL disabled
     DEFINE OSC 16
     'Port direction
     TRISA = %001000 'A.3 is input, rest are outputs.
     CM1CON0 = 0 'Disable comparator
     ANSELA = 0 'Disable A to D
     'List of Aliases
     LED var PortA.0
     DIO var LATA.1
     CLK var LATA.2
     TrisDIO VAR TrisA.1
     'List of variables
     Cnt var byte
     ByteToSend var byte 'Command or Data byte to be sent
     DispCmd var byte
     dispcmd = 64 'Command byte for displaying characters starting with the leftmost digit (0b01000000)
     Brt8Cmd var byte
     brt8cmd = 143 'Command byte for display on with maximum brightness (0b10001111)
     Dig1Addr var byte
     dig1addr = 192 'Address of digit 1 (left most) (0b11000000)
     DispNum var byte
     dispnum = $5B' "2" (Common anode) (10010010)
     'Diagnostic routine
     DiagRoutine:
     CLK=1
     for cnt = 1 to 4 'Blink LED 4 times.
     led = 1 : pause 100
     led = 0 : pause 100
     next cnt
     goto start
     'Subroutines
     StartCondition:
     clk = 0
     dio = 1
     clk = 1
     pauseus 50
     dio = 0 'DIO goes low when CLK is high.
     pauseus 50
     SendTheByte:
     clk = 0
     for cnt = 0 to 7   'Send 8 bits of data, starting with the LSB.
    dio = bytetosend.0(cnt)
    pauseus 50
    clk = 1
    pauseus 50
    clk = 0
     Next cnt
     'dio = 1
     Trisdio = 1 ' Set Data pin direction to input to receive ACK.
     pauseus 50
     clk = 1
     pauseus 50
     clk = 0
     Trisdio = 0 ' Set Data pin direction back to output.
     StopCondition:
     clk = 0
     dio = 0
     clk = 1
     pauseus 50
     dio = 1 'DIO goes high when CLK is high.
     pauseus 50
     START:
     bytetosend = dispcmd 'DispCmd (01000000) (64) = Command byte with auto increment sent before sending the digit data
     gosub startcondition
     gosub sendthebyte
     gosub stopcondition
     bytetosend = dig1addr 'Dig1Addr (11000000) (192) = Address of digit 1 (leftmost digit)
     gosub sendthebyte
     bytetosend = dispnum ' Number "2" (10010010) (146) (Common anode)
     gosub sendthebyte
     gosub stopcondition
       bytetosend = brt8cmd 'Brt8Cmd (10001111) (143) = Command for Display On with Maximum Brightness
     gosub sendthebyte
     gosub stopcondition
  1. TM1637 - display module include example
    By longpole001 in forum Code Examples
    Last Post: - 13th April 2020, 19:19
  2. 3642bh display module pinouts on tm1637 module
    By longpole001 in forum Schematics
    Last Post: - 31st July 2018, 19:09
  3. LED Matrix display
    By Art in forum General
    Last Post: - 5th October 2013, 05:06
  4. LED Bargraph chip (guitar LED bling-age) ..do with a PIC?
    Last Post: - 13th July 2009, 00:15
  5. TV Display Chip
    By zadok in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 23:17
