if you need a pause then you are not doing it rightCode:ROTARY: ' PAUSE 15 ' Needed for smooth rotary encoder operation OLDR = PORTB & $30 ' Mask other and get only Ports B4 and B5 GOSUB ROTARY1 RETURN
Code:;IF BUT = 0 THEN GOTO MENU2 ' This is the wrong way to get out, overflow error !!! ' I need to get out of this loop when the button is pressed !!! IF BUT = 0 THEN buttonState=1
IF NEWR = $30 THEN ROTARY1 ' Same value - no movement (need to eliminate this) ??
assuming last state was $20 or $10 or 0 how can you tell direction ?
you need to save the last state and compare that with the newstate
this thread has re/switch code and is worth a study
http://www.picbasic.co.uk/forum/showthread.php?t=23840
