Csantex, I do not see where you are setting the HIGH and LOW priority interrupts. This is the code I use for setting HIGH and LOW priority inetrrupts.
DEFINE USE_LOWPRIORITY 1
INCLUDE "C:\PBP\INCLUDES\DT_INTS-18.bas" ' Interrupt Control routines
INCLUDE "C:\PBP\INCLUDES\ReEnterPBP-18.bas" ' Interrupt Control routines
INCLUDE "C:\PBP\INCLUDES\ReEnterPBP-18LP.bas" ; Include if using Low Pr. PBP INTS
asm
;----[High Priority Interrupts]-----------------------------------------------
INT_Handler TMR1_INT, _TIMR1, PBP, yes
INT_CREATE ; Creates the High Priority interrupt processor
;----[Low Priority Interrupts]------------------------------------------------
INT_LIST_L macro ; IntSource, Label, Type, ResetFlag?
INT_Handler TX1_INT, _UARTTX1, PBP, no
INT_Handler RX1_INT, _UARTRX1, PBP, no
INT_Handler TX2_INT, _UARTTX2, PBP, no
INT_Handler RX2_INT, _UARTRX2, PBP, no
INT_CREATE_L ; Creates the LOW Priority interrupt processor
@ INT_ENABLE RX1_INT ; Enable RX UART Interrupts
@ INT_ENABLE RX2_INT ; Enable RX UART Interrupts
@ INT_ENABLE TMR1_INT ; Enable Timer 1 Interrupts
GOTO STARTLOOP
' Interrupt Routines *
TIMR1: 'INTERRUPT SERVICE ROUTINE FOR TIMER 1
@ INT_RETURN
UARTRX1: 'INTERRUPT SERVICE ROUTINE FOR UART RECEIVER
@ INT_RETURN
UARTTX1: 'INTERRUPT SERVICE ROUTINE FOR UART TRANSMITTER
@ INT_RETURN
UARTRX2: 'INTERRUPT SERVICE ROUTINE FOR UART RECEIVER
@ INT_RETURN
UARTTX2: 'INTERRUPT SERVICE ROUTINE FOR UART TRANSMITTER
@ INT_RETURN
' Subroutines *
