Serial data sent to 16F627A being read incorrectly by PIC?
Results 1 to 7 of 7
    Default Re: Serial data sent to 16F627A being read incorrectly by PIC?
    just tried your code on a 16f648a , works perfectly from my pc usb through tty converter to pic , you must have polarity of signal screwed up.
    The difference between 2389 and 2400 would not seem a big deal, it only 0.5% (if my maths right, which is unlikely)
    George
    Jun 2005
    I traced out the board and realized another component sitting between the board input and PIC was inverting the signal. The board is being re-purposed from a different use so I was able to bypass that and everything is working as expected. Thanks
  1. how to buffer serial data on pic?
    By kiteman in forum mel PIC BASIC Pro
    Last Post: - 29th March 2010, 20:07
  2. How to read PIC serial no. from EEPROM with PBP?
    Last Post: - 11th December 2009, 11:27
  3. Forward Serial Data from pic to pc
    By Muller in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 22:46
  4. How to read Serial number programmed into PIC
    By freddayz in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2008, 03:36
  5. PIC to PIC Serial data using Cat5 cable
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2007, 03:42
