Re-using pins while still connected to MAX7219 ?
Results 1 to 7 of 7
    Default Re-using pins while still connected to MAX7219 ?
    Hello.
    I have 12F1840 which is connected to MAX7219. As amount of ports is quite low, 3 ports are wasted on driving that IC. I would like to be able to use any of these pins for reading a button or driving a buzzer. If I understand properly, if I drive MAX7219 CLK pin low, IC will be locked, no matter what happens on other pins, right?
    Aug 2009
    Paso Robles California
    Default Re: Re-using pins while still connected to MAX7219 ?
    It has been a long time since I’ve used that chip But I’m pretty sure you only need 3 pins It is a serial chip. And you may get by with using two of those pins But there will be no updating of the display
    It's in the data sheet.
    Load-Data Input. The last 16 bits of serial data are latched on LOAD’s rising edge.
    So, Just hold the LOAD pin low until you have the new data shifted into the MAX7219. You can use the clock and data pins as you wish as long as the LOAD pin is low.
    EN82fn
    Thanks, that's excellent idea.
    I want to attach button which will pull that pin low, when pressed. Since pin is already connected to IC, do I still need pull up resistor?
    Why yes you do and don't forget to set the pin as an INPUT.
    EN82fn
    Thanks, I have another idea.
    What I use data pin for beeper? I think I can connect emitter follower thru capacitor to that pin, and buzzer to emitter follower? MAX7219 data speed should be high enough, so buzzer won't play anything while transferring the data?
    Sep 2009
    Probably you will get audible click on start and stop of data transition, and probably some noise during.
    You may implement this
    https://www.romanblack.com/shift1.htm
    Also you could use SPI port expander, and and use inverted CS signal to drive it. Or some additional transistor circuit to activate buzzer only when LOAD is low.
  1. World’s First Internet Connected Lawnmower
    By MichelJasmin in forum Ethernet
    Last Post: - 11th June 2015, 15:26
  2. DS18B20 connected to PIC16F628A
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 29th November 2011, 23:18
  3. Does it matter which way a triac is connected?
    Last Post: - 7th October 2010, 20:49
  4. PIC - 8 Pins - 6 Output Pins ?
    By DanPBP in forum Off Topic
    Last Post: - 22nd October 2007, 00:23
  5. it's possible to drive four max7221 serially connected?
    By lutherblissett in forum General
    Last Post: - 23rd November 2005, 18:38
