PCF8563 date data corrupted
Results 1 to 3 of 3
    Nov 2011
    Default PCF8563 date data corrupted
    PIC16F628, Pic Basic Pro 2.60, Pickit programmer
    Good day ,
    Below is my code to read the PCF8563:
    I2Cread SDA,SCL,rtcadd,rtcloc,[secs,minu,hrs,DoM,doW,mon,year]
    gosub waita 'read D&T data then wait 10ms
    write $20,secs,minu,hrs, DoM,doW,mon,year 'write D&T data to F628 eeprom
    When I read the data in the F628 eeprom I get correct minutes seconds and hours but the DoM,dOW,mon,year
    data is corrupt. Every time I run that code the calendar data changes to something different and sometimes
    some of the data is correct.
    When I set alarms they work correctly.
    When I replace the PCF8563 with a DS1307 and change the addresses accordingly, the program works perfectly.
    I want to use this PCF8563 because it has alarms and battery voltage sensing that the DS1307 doesn't have.
    I have also tried 3k3 resistors on SCL & SDA instead of 4k7 but that made no difference.
    Can somebody help please.
    Default Re: PCF8563 date data corrupted
    you need to mask off the bits that are not used for the value being returned
        minu = minu & $7f
        hrs  = hrs  & $3f
        Dow  = dow  & 7
        Dom  = dom  & $3f
        mon  = mon  & $1f
    Nov 2011
    Thank you very much Richard , your advice fixed my problem.
    I am so happy 'cause I really like this chip.
    Now I can apply my mind to getting an interrupt every minute which
    appears to be quite cumbersome.
    Hebe
  1. My date this weekend.
    By Christopher4187 in forum Off Topic
    Last Post: - 29th January 2008, 16:45
  2. Bootloader corrupted at low voltage
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 14:56
  3. Array data being corrupted
    By caverman in forum mel PIC BASIC Pro
    Last Post: - 17th March 2006, 04:22
  4. calculate with date
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 14th October 2005, 16:49
  5. 16F88.bas corrupted
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 26th April 2005, 17:21
