TM1637 - display module include example
Results 1 to 6 of 6
    Nov 2019
    Default Re: TM1637 - display module include example
    Following my original post and code example, I hand-wired a 4x4 pushbutton keypad into the TM1637 to experiment with its key scanning capability. The attached photo shows how this turned out.
    I interfaced this display keypad with a Microchip Curiosity Board for code development and discovered a problem with the original code that was apparently a collision between the change in uC, the PBP Shiftout command, bit-banging and port pin propagation delay. In other words, I think I encountered a "read-modify-write" episode.
    In the code example provided here, I've remedied this problem by using the "LATx.x" function instead of "PORTx.x" in the bit-banging subroutines. This is explained a bit more in the header commentary.
    The keypad code shifts in the key byte, derives a 2-digit number "01" through "16", and displays the number on the display.
    '*  Name    : TM1637_Include_File_CB_Keys.PBP                               *
    '*  Author  : Roberts                                               *
    '*  Notice  : Hack it as you wish                                   *
    '*  Date    : 12/06/2019                                            *
    '*  Version : 1.0                                                   *
    '*  Notes   : Include File Library for TM1637 Write Subroutine      *
    '*          : THIS VERSION FOR MICROCHIP CURIOSITY BOARD PIC16F1619 *
    '*          : This version adds TM1637 Key Scan Reading             *
    ' THIS IS A REVISED TM1637 DEMO PROGRAM DEVELOPED WHILE PORTING THE ORIGINAL PROGRAM TO THE CURIOSITY BOARD AND ITS
    ' PIC16F1619.  AS ORIGINALLY WRITTEN, THE PROGRAM DID NOT OUTPUT CORRECTLY TO THE DISPLAY DUE TO APPARENT INTERFERENCE
    ' ON THE SDA AND SCK PINS WHEN THESE PINS EXIST ON THE SAME PORT.  THIS TURNED OUT TO BE A READ/MODIFY/WRITE PROBLEM
    ' THAT WAS AFFECTED BY THE STARTSEQ, ACKSEQ, AND STOPSEQ BIT BANGING.  THIS PROBLEM WAS REMEDIED BY DECLARING ADDITIONAL
    ' VARIABLES SDA1 AND SCK1 AS LATX.X's WHILE KEEPING THE ORIGINAL VARIABLES USED BY THE SHIFTOUT COMMAND, SDA AND SCK,
    ' AS PORTX.X's.  THIS ALLOWS THE BIT BANGING TO OCCUR WITHOUT THE READ/MODIFY/WRITE COMPLICATIONS.
    ' SOLVING THIS PROBLEM WAS EVASIVE BECAUSE THE ORIGINAL PROGRAM WORKED WHEN SDA AND SCK USED PORTS C.4 AND C.5 ON THE
    ' pic16F1619, BUT NOT WHEN ANY OTHER COMMON PORT PINS WERE USED.  THE ORIGINAL PROGRAM DID WORK WHENEVER SDA AND SCK
    ' WERE ON DIFFERENT PORTS.
    ' The subroutine LEDOUT implements the write sequence consisting of a write command (CMD1=$40) followed by the address
    ' command (CMD2=$C0), the 4 digits CHR1 - CHR4, and terminating with CMD3=$8A which turns the display ON and sets its
    ' brightness level.  The PBP command SHIFTOUT is used to send these commands and characters, thus avoiding bit-banging
    ' them.
    ' The 3 subroutines StartSeq, AckSeq, and StopSeq perform the requisite bit banging on the SDA and SCK outputs before
    ' and after the PBP SHIFTOUT command.
    ' This demo code writes to all 4 digits in the TM1637's "auto-increment" mode. The digits could be individually
    ' addressed using the TM1637's "fixed address" mode (see TM1637 spec sheet).
    ' This code works with a 4-digit TM1637 based LED display that has handwired into a 16 key keypad arranged in in an
    ' 8x2 wired matrix per the TM1637 spec sheet.  LED and keypad assemblies are available in similar wiring arrangements
    ' (usually 6 digits and 6 switches), and this code should be adaptable.  There are also TM1628 based displays and
    ' keypad assemblies, but the TM1638 uses a different 3-wire interface, so this code is not TM1638 compatible.
    ' This program initially writes "----" to the display. When any of the 16 keys are pressed, the key number (01 - 16)
    ' is display on the center 2 digit locations, such as "-06-" for switch number 6.  The switch number remains on the
    ' display until the key is released, whereupon the display returns to "----".
    ' A utility LED flashes at 5/sec on/off to indicate looping.  Key response can be altered by changing/deleting this.
    ' A THORUGH READING AND COMPREHENSION OF THE TM1637 DATA SHEET IS HELPFUL!
    ' Below are the hexadecimal segment codes corresponding to decimal values
    '  0     1     2     3     4     5     6     7     8     9
    ' 0x3F  0x06  0x5B  0x4F  0x66  0x6D  0x7D  0x07  0x7F  0x67
    '********************************Declare Variables and Constants**********************************************
    ' Place the PIC initialization INCLUDE file here (See PBP PIC Configuration Files)
    INCLUDE "PIC16F1619_Initialize.pbp"
    ANSELB = 000000
    TRISB = 000000
    SDA Var PORTB.4                  'Serial data port pin
    SCK Var PORTB.6                  'Serial clock port pin
    SDA1 Var LATB.4                  'Serial data latch
    SCK1 Var LATB.6                  'Serial clock latch
    HIGH SDA
                                     'These are the 4 commands used by the TM1637 controller:
    CMD1 CON $40                     'CMD1=$40 is the write command
    CMD2 CON $C0                     'CMD2=$C0 is the start digit position(left most)
    CMD3 CON $8A                     'CMD3=$8A is the end command that turns the display on and sets brightness
                                     '(CMD3=$8F for max brightness - see TM1637 spec sheet)
    CMD4 CON $42                     'CMD4=$42 is the read key command
    KEYNO VAR BYTE                   'KEYNO is the byte value from the keypad
    CHR1 CON $40                     'Characters 1 and 4 are set to "-"
    CHR4 CON $40
    CHR2 VAR BYTE                    'The key number 1 through 16 are displayed as characters 2 and 3
    CHR3 VAR BYTE
    CHR2 = $40 : CHR3 = $40          'Characters 2 and 3 are initialized as "-"
    '************************************Subrouting LEDOUT*********************************************************
    LEDOUT:                                             'This subrountine outputs all 4 characters to the LED
        GOSUB StartSeq                                  'SHIFTOUT Mode 0 works - LSB first, clock normally low
        SHIFTOUT SDA, SCK, 0, [CMD1]                    'This shifts out the 8-bit write command character $40
        GOSUB AckSeq
        GOSUB StopSeq
        GOSUB StartSeq                                  'This shifts out the 8-bit command character $C0 that places
        SHIFTOUT SDA, SCK, 0, [CMD2]                    'the first character CHR1 in the leftmost digit location
        GOSUB AckSeq                                    'and then writes all 4 digits.
        SHIFTOUT SDA, SCK, 0, [CHR1]                    'SHIFTOUT CHR1-CHR4 to fill the display left to right
        GOSUB AckSeq                                    'TM1637 auto-increment mode
        SHIFTOUT SDA, SCK, 0, [CHR2]
        GOSUB AckSeq
        SHIFTOUT SDA, SCK, 0, [CHR3]
        GOSUB AckSeq
        SHIFTOUT SDA, SCK, 0, [CHR4]
        GOSUB AckSeq
        GOSUB StopSeq
        GOSUB StartSeq
        SHIFTOUT SDA, SCK, 0, [CMD3]                    'The output sequence ends with CMD3 which turns on the display
        GOSUB AckSeq                                    'and set the brightness duty cyle
        GOSUB StopSeq
             HIGH PortA.2                               'Flash utility LED to indicate program is looping while idle
             PAUSE 100                                  'Delete, change port assignment or comment out if not desired
             LOW PORTA.2
             PAUSE 100
    'The following section of code reads the keypad byte. If no key is pressed the KEYNO byte default value is $FF
    'Delete this section of code if keypad reading is not required
        GOSUB StartSeq                                  'Send StartSeq to TM1637
        SHIFTOUT SDA, SCK, 0, [CMD4]                    'Send the Read keypad command CMD4 = $42
        GOSUB AckSeq                                    'Send AckSeq
        SHIFTIN SDA, SCK, 0, [KEYNO]                    'Shiftin the byte value as variable KEYNO (see TM1637 Data Sheet)
        GOSUB StopSeq                                   'Send StopSeq
        IF KEYNO = $FF THEN                             'KEYNO = $FF means no key is pressed
            CHR2 = $40 : CHR3 = $40                     'Set 2nd & 3rd display characters to "-"
            GOTO LEDOUT                                 'LEDOUT outputs "----" to the display
          KEYNO = KEYNO >> 4                            'If KEYNO is not $FF, shift keypad matrix value right 4 bits
                                                        'Lookup characters 2 and 3 from keypad matrix value
                                                        'CHR2 will be either "0" or "1"
                                                        'CHR3 will be a value "0" through "9"
                                                        'Together CHR2 and CHR3 will display "01" through "16"
          ' Lookup command lists map the 4-bit keypad code to the 7-segment hex codes (see header comments) for key numbers
          ' "01" through "16" (see map table below)
          LOOKUP KEYNO, [$06,$06,$06,$06,$3F,$3F,$3F,$3F,$06,$06,$3F,$06,$3F,$3F,$3F,$3F], CHR2   '2nd display digit
          LOOKUP KEYNO, [$7D,$6D,$4F,$66,$7F,$07,$6D,$7D,$5B,$06,$67,$3F,$66,$4F,$06,$5B], CHR3   '3rd display digit
    ' Each key has a unique 4-bit value KEYNO that is used to derive its decimal key number.  Lookup commands map the KEYNO
    ' value (0000 to 1111) to the key number (1 to 16) 7-segment hex code.  For example, S5's KEYNO value is 7, and requires
    ' "05" to be displayed. The 8th values in the Lookup lists are therefore CHR2 = 0x3F ("0") and CHR3 = 0x7D ("5").
    ' Key:              S1      S2      S3      S4      S5      S6      S7      S8         Switch Numbers 1 - 8
    ' Matrix Loc:     K1/SG1  K2/SG1  K2/SG5  K1/SG5  K1/SG2  K2/SG2  K2/SG6  K1/SG6       TM1637 Matrix Location
    ' Key Hex Code:    0xEF    0xF7    0xD7    0xCF    0x6F    0x77    0x57    0x4F        Non-reversed hex code
    ' 4-bit Value:     0x0E    0x0F    0x0D    0x0C    0x06    0x07    0x05    0x04        Hex Code shifted right 4-bits
    ' CHR2:           0 0x3F  0 0x3F  0 0x3F  0 0x3F  0 0x3F  0 0x3F  0 0x3F  0 0x3F       Digit value and LED 7 Seg Code
    ' CHR3:           1 0x06  2 0x5B  3 0x4F  4 0x66  5 0x6D  6 0x7D  7 0x07  8 0x7F       Digit value and LED 7 Seg Code
    ' Lookup:           15      16      14      13       7       8       6       5         Place in Lookup List
    '        = DEC[4-bit value +1]
    ' Key:              S9      S10     S11     S12     S13     S14     S15    S16         Switch Numbers 9 - 16
    ' Matrix Loc:     K1/SG3  K2/SG3  K2/SG7  K1/SG7  K1/SG4  K2/SG4  K2/SG8  K1/SG8       TM1637 Matrix Location
    ' Key Hex Code:    0xAF    0xB7    0x97    0x8F    0x2F    0x37    0x17    0x0F        Non-reversed hex code
    ' 4-bit Value:     0x0A    0x0B    0x09    0x08    0x02    0x03    0x01    0x00        Hex Code shifted right 4-bits
    ' CHR2:           0 0x3F  1 0x06  1 0x06  1 0x06  1 0x06  1 0x06  1 0x06  1 0x06       Digit value and LED 7 Seg Code
    ' CHR3:           9 0x67  0 0x3F  1 0x06  2 0x5B  3 0x4F  4 0x66  5 0x6D  6 0x7D       Digit value and LED 7 Seg Code
    ' Lookup:           11      12      10       9       3       4       2       1         Place in Lookup List
    '************************************** End of Keypad Reading ****************************************************
    GOTO LEDOUT              'Loop forever and display the keypad number being pressed
    'Subroutines StartSeq, AckSeq and StopSeq write to the port latches to avoid read/modify/write problems.
    '****************************************Subroutine StartSeq*******************************************************
     StartSeq:
       HIGH SCK1
       HIGH SDA1             'The Start sequence takes SDA1 low and then SCK1 low 5 uSec later
       PAUSEUS 5
       LOW SDA1
       PAUSEUS 5
    '**************************************Subroutine AckSeq*********************************************************
     AckSeq:
     SDA = PORTB.4
        LOW SCK1             'The ACK waits for the TM1637 to assert low on SDA1
        PAUSEUS 5            'and then replies with a 5 uSec ACK pulse on SCK1
         IF SDA = 0 THEN
            HIGH SCK1
            PAUSEUS 5
            LOW SCK1
    '****************************************Subroutine StopSeq******************************************************
     StopSeq:
        LOW SCK1             'The stop sequence takes SCK1 high and then SDA1 high 5 uSec later
        LOW SDA1
        PAUSEUS 5
        HIGH SCK1
        PAUSEUS 5
        HIGH SDA1
        PAUSEUS 5
    '*****************************************End of Subroutine Programs**********************************************
  1. Tm1637 libary - has it been done
    By longpole001 in forum PBP3
    Last Post: - 4th August 2018, 12:25
  2. 3642bh display module pinouts on tm1637 module
    By longpole001 in forum Schematics
    Last Post: - 31st July 2018, 18:09
  3. Graphic LCD display module design advice
    By munromh in forum General
    Last Post: - 21st March 2013, 20:55
  4. Do you have to initialize an on-Screen Display module?
    Last Post: - 28th April 2011, 00:53
  5. Replies: 1
    Last Post: - 27th July 2008, 06:14
