DT Elapsed Timer Question
Results 1 to 12 of 12
    Dec 2010
    Melbourne Australia
    Default Re: DT Elapsed Timer Question
    So, if I was to make an interrupt routine that only incremented a... say 16 bit variable - say 3 or 4 lines of assembler and that's all it did - would I be risking too much to not back up the system variables?
    if your isr's only use asm code then there is no need to back up any pbp working registers at all , mcu context must always be saved and restored in the isr process. most advanced core pic's have auto context save/restore otherwise that need to be added to the isr process too, refer to your datasheet
    Dec 2010
    Melbourne Australia
    Thanks again Richard. I might have crack at a bleeding minimum overhead routine over the weekend and see what happens.
  1. Elapsed Timer findings
    By Art in forum General
    Last Post: - 23rd August 2024, 07:40
  2. DT Elapsed Timer
    Last Post: - 15th December 2017, 00:21
  3. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  4. SPWM and Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 04:16
  5. DT Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 00:17
