DT Elapsed Timer Question
Results 1 to 12 of 12
    Dec 2010
    Melbourne Australia
    Default Re: DT Elapsed Timer Question
    Richard,
    so, the last link: take the stopwatch example (from a layperson's perspective), I can't see significant difference in overhead between say this and the elapsed timer example but I'm probably missing something? Like, am I correct in concluding there's a awful lot going on for when an interrupt is triggered like saving system variables and whatnot, or as in your stopwatch code, both the timer1 and timer3 interrupts call a PBP subroutine with assembler commands within and because of this, the system variables don't require backup and restoring after each interrupt activation? Apologies for what might be dumb questions, I'm trying to get my head around this.
    Troy
    correct there is not much overhead difference when pbp interrupts are used , main point was to show that time accuracy using time stamps is easy versus trying to fudge clock counts
    so that elapsed_int could be used without modification and also to show that conversion to h:m:s is not too difficult
    the main difference between asm and pbp interrupts is whats entailed in ReEnterPBP.bas code . its up to the user to determine if the application can tolerate the overhead or a more efficient method need be developed
    Dec 2010
    Melbourne Australia
    So, if I was to make an interrupt routine that only incremented a... say 16 bit variable - say 3 or 4 lines of assembler and that's all it did - would I be risking too much to not back up the system variables?
    if your isr's only use asm code then there is no need to back up any pbp working registers at all , mcu context must always be saved and restored in the isr process. most advanced core pic's have auto context save/restore otherwise that need to be added to the isr process too, refer to your datasheet
    Dec 2010
    Melbourne Australia
    Thanks again Richard. I might have crack at a bleeding minimum overhead routine over the weekend and see what happens.
  1. Elapsed Timer findings
    By Art in forum General
    Last Post: - 23rd August 2024, 07:40
  2. DT Elapsed Timer
    Last Post: - 15th December 2017, 00:21
  3. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  4. SPWM and Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 04:16
  5. DT Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 00:17
