Stack Under flow
Results 1 to 10 of 10
    look if there's a part of your code ended with a return but uncalled by a Gosub
    well this is the only thing that make sense to me.
    Will be easier to say if you post your code Here.
    sinoteq's Avatar
    sinoteq Guest
    Default GOTO and GOSUB
    Sep 2005
    Hernando,Florida USA
    Default goto and gosub
    HI Sinoteq
    There is one gosub and one return. so I would think the return
    would go back to GETKEY. Yes
    Or did I not understand your comment.
    Wayne
    start:
    LED1=0 '
    GoSub getkey
    getkey:
    kp1=0 'Clear kp1
    after Main, should have a goto start or something like that
    But i didn't get any error within MicroCode Studio using MPASM but get error with PM about WDTCON and LCDCON... in the PM M16F91X.inc file it miss those two lines
    WDTCON		    equ     105h
    LCDCON		    equ     107h
    but shouldn't be the cause IMO
    Sep 2005
    Default Mplab Sim
    Hi Steve
    You only get the error if you use the MPLAB SIM tool or program the PIC
    and install it in the board.
    Wayne
    So to be clear does
    GoSub getkey
    Goto Start     ' <=== Add this line
    getkey:
    kp1=0 'Clear kp1
    fix the problem... i guess yes !?!
    Sep 2005
    Talking stack under flow
    Hi Steve (MR. E)
    Yes that did work and thank you very much for the help.
    But one more thing WHY and what is a stack underflow?
    Again Thanks
    Wayne
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 21:42
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  3. Stack over flow with IF THEN RETURN ENDIF???
    By kdoske in forum mel PIC BASIC Pro
    Last Post: - 9th December 2007, 18:20
  4. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 05:05
  5. 48 level Software Stack
    Last Post: - 30th November 2003, 02:07
