Stack Under flow
Results 1 to 10 of 10
    Sep 2005
    Hernando,Florida USA
    Red face Stack Under flow
    I seem to have a problem with the stack.
    But a stack under flow ??
    When my program get to a return I get this message
    "Stack under flow error occurred from instruction at 0x000126"
    the return instruction is at 0x000126.
    The tools are PIC Pro 2.46 MPLAB 7.20 and the device is 16F913
    Just don't know where to start with this problem.
    I start the program, it will go through the getkey loop 2 times
    and then give me the stack error. then it resets and starts over.
    Define osc 8
    OSCCON = %01110001 'SET FOR INTERNAL CLK @8 MHz
    WDTCON = %00000000
    LCDCON = %01000000
    LCDSE0 = %00000000
    LCDSE1 = %00000000
    ANSEL = 0
    CMCON0 = $07
    TRISB=%00001111 'set PORTb, 1=input, 0=output
    TRISC=%11110000 'set PORTc, 1=input, 0=output
    TRISA=%11100100 'set PORTa, 1=input, 0=output
    PORTB.4=0 ' set portb pin 4 low for LED sink
    PORTA.0=0
    INTCON = %00000000 'Turn interrups off
    kp VAR BYTE 'Key press value
    kp1 VAR BYTE 'Key press
    LED1 VAR PORTA.0
    LED2 VAR PORTA.1
    LED3 VAR PORTA.3
    LED4 VAR PORTA.4
    LEDCOM VAR PORTB.4
    TESTPIN VAR PORTC.5
    COL1 VAR PORTC.0 'KeyPad col1
    COL2 VAR PORTC.1 'KeyPad col2
    COL3 VAR PORTC.2 'KeyPad col3
    COL4 VAR PORTC.3 'KeyPad col4
    ROW VAR BYTE
    i VAR BYTE 'for next variable
    start:
    LED1=0 '
    LED2=0 ' set all leds to Off
    LED3=0 '
    LED4=0 '
    LEDCOM=0
    kp=16
    kp1=0
    LED1 = 1
    Pause 500
    LED2 = 1
    Pause 500
    LED3 = 1
    Pause 500
    LED4 = 1
    Pause 500
    LED1 = 0
    LED2 = 0
    LED3 = 0
    LED4 = 0
    GoSub getkey
    getkey:
    kp1=0 'Clear kp1
    'col4
    PORTC=%00000111 'Make PORTC.3 low PINs .0.1.2 High
    kp1 = PORTB & $0f
    IF kp1=14 Then kp=13
    IF kp1=13 Then kp=14
    IF kp1=11 Then kp=15
    IF kp1=7 Then kp=15
    IF kp1<>15 Then debounce
    'col3
    PORTC=%00001011 'Make PORTC.2 low PINs .3.1.0 High
    kp1 = PORTB & $0f
    IF kp1=14 Then kp=3
    IF kp1=13 Then kp=6
    IF kp1=11 Then kp=9
    IF kp1=7 Then kp=12
    'col2
    PORTC=%00001101 'Make PORTC.1 low PINs .3.2.0 High
    kp1 = PORTB & $0f
    IF kp1=14 Then kp=2
    IF kp1=13 Then kp=5
    IF kp1=11 Then kp=8
    IF kp1=7 Then kp=10
    'col1
    PORTC=%00001110 'Make PORTC.0 low PINS .3.2.1 High
    kp1 = PORTB & $0f
    IF kp1=14 Then kp=1
    IF kp1=13 Then kp=4
    IF kp1=11 Then kp=7
    IF kp1=7 Then kp=11
    GoTo nokey
    debounce:
    pause 50
    row = PORTB & $0f
    if row = $f then showkp
    goto debounce
    showkp: For i = 1 to kp
    High led1
    Pause 500
    Low led1
    Pause 500
    Next i
    'DTMFout PORTC.5,[kp]
    nokey:
    look if there's a part of your code ended with a return but uncalled by a Gosub
    well this is the only thing that make sense to me.
    Will be easier to say if you post your code Here.
    sinoteq's Avatar
    sinoteq Guest
    Default GOTO and GOSUB
    Sep 2005
    Default goto and gosub
    HI Sinoteq
    There is one gosub and one return. so I would think the return
    would go back to GETKEY. Yes
    Or did I not understand your comment.
    Wayne
    start:
    LED1=0 '
    GoSub getkey
    getkey:
    kp1=0 'Clear kp1
    after Main, should have a goto start or something like that
    But i didn't get any error within MicroCode Studio using MPASM but get error with PM about WDTCON and LCDCON... in the PM M16F91X.inc file it miss those two lines
    WDTCON		    equ     105h
    LCDCON		    equ     107h
    but shouldn't be the cause IMO
    Sep 2005
    Default Mplab Sim
    Hi Steve
    You only get the error if you use the MPLAB SIM tool or program the PIC
    and install it in the board.
    Wayne
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 21:42
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  3. Stack over flow with IF THEN RETURN ENDIF???
    By kdoske in forum mel PIC BASIC Pro
    Last Post: - 9th December 2007, 18:20
  4. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 05:05
  5. 48 level Software Stack
    Last Post: - 30th November 2003, 02:07
