Normal i/o required on portc , pin6, 7 18f27k40
Results 1 to 16 of 16
    Aug 2011
    Default Re: Normal i/o required on portc , pin6, 7 18f27k40
    Dave, I think the PPS1WAY config bit only controls whether or not you can change the PPSLOCK bit once you've written to it to set it.
    If you never lock the pps in the first place then you don't need to unlock it, so that setting shouldn't matter.
    Feb 2012
    PERTH AUSTRALIA
    hi dave
    well setting
    RC6PPS = 0
    RC7PPS = 0
    allowed the pins to work as I/O on portc pins6,7, in this case both pins are outputs
    prior to the above command both pins were high by default and only dipped 0.7v when asked to change to a low state , which made me consider they were acting as usart1 pins
    I did not have to unlock the pps
    i have not set the lock pps bit in the config
    also PMD4 - Usart was not active , but still the pins were effected , but thats not a big surprise
    so what other PPS port pins need to be set to 0 on each port before they can be used as standard i/o , clearly not all as other port pins have responded as expected from TRIS, perhasp is it is just the USART's ???
    or should the standard approach for each port be ,to set RxyPPS = 0 , done in each port section, and only changed from 0 / command removed when a PPS fuction is required on those pins
    table 17.1. at POR shows for PPS inputs port pins , this appears to override TRIS settings until RxyPPS = 0 is set , thus allowing TRIS standard i/o of those pins ???
    If table 17.2 has no POR for outputs , then i should not need to to do RxyPPS = 0 before the port worked as standard I/O , but clearly i needed to do it so that USART1 was not effected on portc,pin6, 7 ?
    a little confusing
    cheers
    Sheldon
    Aug 2011
    I'm staring at a 27K40.
    I have config PPS1WAY off.
    No pps, no nothing but:
    trisc.7 = 0
    portc.7 = 1
    portc.7 = 0
    trisc.6 = 0
    portc.6 = 1
    portc.6 = 0
    and the pins go high and low for me.
    Feb 2012
    PERTH AUSTRALIA
    hi tumbleweed, i will look further
    but here is what i have , which i agree with you PPS should not effect portC with the config i have
    but i without the RC6pps =0 ,RC7PPS= 0 the pins are definitely not responding as i/o pins
    I have silicon 0 sample from microchip btw , but that should not be a factor
    at time of testing the pins dont have any other components connected to outputs except a cro
    ' config for 18F27K40
    ;----- CONFIG1L Options --------------------------------------------------
        CONFIG FEXTOSC   = OFF	           ; External Oscillator not enabled
        CONFIG RSTOSC    = HFINTOSC_64MHZ  ; HFINTOSC with HFFRQ = 64 MHz and CDIV = 1:1
    ;----- CONFIG1H Options --------------------------------------------------
        CONFIG CLKOUTEN  = OFF	           ; CLKOUT function is disabled I/O fuction on OSC2
        CONFIG CSWEN     = ON	           ; Writing to NOSC and NDIV is allowed ( software can change OSC type and speed as required after POR)
        CONFIG FCMEN     = OFF	           ; Fail-Safe Clock Monitor disabled
    ;----- CONFIG2L Options --------------------------------------------------
        CONFIG MCLRE     = EXTMCLR	       ; If LVP = 0, MCLR pin is MCLR; If LVP = 1, RE3 pin function is input - used a s reset by CCT
        CONFIG PWRTE     = ON	           ; Power up timer enabled - provides 66ms timeout on POR or Brown out reset
        CONFIG LPBOREN   = OFF	           ; LPBOR disabled  ( Low Power Brown Out Reset disabled)
        CONFIG BOREN     = ON	           ; Brown-out Reset Enabled according to SBOREN
    ;----- CONFIG2H Options --------------------------------------------------
        CONFIG BORV      = VBOR_245	       ; Brown-out Reset Voltage (VBOR) set to 2.45V
        CONFIG ZCD       = OFF	           ; ZCD disabled. Zero Cross Detect can be enabled by setting the ZCDSEN bit of ZCDCON
        CONFIG PPS1WAY   = OFF	           ; PPSLOCK bit can be set and cleared repeatedly (subject to the unlock sequence)
        CONFIG STVREN    = ON	           ; Stack full/underflow will cause Reset
        CONFIG DEBUG     = OFF	           ; Background debugger disabled
        CONFIG XINST     = OFF	           ; Extended Instruction Set and Indexed Addressing Mode disabled
    ;----- CONFIG3L Options --------------------------------------------------
        CONFIG WDTCPS    = WDTCPS_31	   ; Divider ratio 1:65536; software control of WDTPS
        CONFIG WDTE      = OFF	           ; WDT Disabled -  Watch Dog Timer disabled
    ;----- CONFIG3H Options --------------------------------------------------
        CONFIG WDTCWS    = WDTCWS_7	       ; window always open (100%); software control; keyed access not required
        CONFIG WDTCCS    = LFINTOSC	       ; WDT reference clock is the 31.0 kHz LFINTOSC
    ;----- CONFIG4L Options --------------------------------------------------
        CONFIG WRT0      = OFF	           ; Block 0 (000800-003FFFh) not write-protected
        CONFIG WRT1      = OFF	           ; Block 1 (004000-007FFFh) not write-protected
        CONFIG WRT2      = OFF	           ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG WRT3      = OFF	           ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG WRT4      = OFF	           ; Block 4 (010000-013FFFh) not write-protected
        CONFIG WRT5      = OFF	           ; Block 5 (014000-017FFFh) not write-protected
        CONFIG WRT6      = OFF	           ; Block 6 (018000-01BFFFh) not write-protected
        CONFIG WRT7      = OFF	           ; Block 7 (01C000-01FFFFh) not write-protected
    ;----- CONFIG4H Options --------------------------------------------------
        CONFIG WRTC      = OFF	           ; Configuration registers (300000-30000Bh) not write-protected
        CONFIG WRTB      = OFF	           ; Boot Block (000000-0007FFh) not write-protected
        CONFIG WRTD      = OFF	           ; Data EEPROM not write-protected
        CONFIG SCANE     = ON	           ; Scanner module is available for use, SCANMD bit can control the module
        CONFIG LVP       = OFF	           ; HV on MCLR/VPP must be used for programming
    ;----- CONFIG5L Options --------------------------------------------------
        CONFIG CP        = OFF	           ; UserNVM code protection disabled
        CONFIG CPD       = OFF	           ; DataNVM code protection disabled
    ;----- CONFIG5H Options --------------------------------------------------
    ; not used
    ;----- CONFIG6L Options --------------------------------------------------
       CONFIG EBTR0      = OFF	          ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
       CONFIG EBTR1      = OFF	          ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
       CONFIG EBTR2      = OFF	          ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
       CONFIG EBTR3      = OFF	          ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
       CONFIG EBTR4      = OFF	          ; Block 4 (010000-013FFFh) not protected from table reads executed in other blocks
       CONFIG EBTR5      = OFF	          ; Block 5 (014000-017FFFh) not protected from table reads executed in other blocks
       CONFIG EBTR6      = OFF	          ; Block 6 (018000-01BFFFh) not protected from table reads executed in other blocks
       CONFIG EBTR7      = OFF	          ; Block 7 (01C000-01FFFFh) not protected from table reads executed in other blocks
    ;----- CONFIG6H Options --------------------------------------------------
       CONFIG EBTRB      = OFF	          ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    ' ----------------  Setup All Define statements ------------
        DEFINE OSC 32               ' Timing referance for pause , pauseus commands
        DEFINE ADC_BITS 10          ' Number of bits in ADCIN result - Required for adcin command
        DEFINE PULSIN_MAX 2000      ' Maximum counts( clock ticks) allowed before pulsin times out( 2000 ^ 1.25us =  2.5 ms)
        DEFINE HSER_PORT 2          ' Hser port 2 use
        DEFINE HSER2_RXREG PORTB    ' USART 2 RX - Set PPS Register port B
        DEFINE HSER2_RXBIT 7        '
        DEFINE HSER2_TXREG PORTB
        DEFINE HSER2_TXBIT 6
        DEFINE HSER2_RCSTA 90h      ' Hser2 receive status init
        DEFINE HSER2_TXSTA 24h      ' Hser2 transmit status init
        DEFINE HSER2_BAUD 19200     ' Hser2 baud rate
     '---------------- PERIPHERAL PIN SELECT MODULE -----------------------
        RC6PPS = 0
        RC7PPS = 0
    '---------------- PERIPHERAL MODULE DISABLE -----------------------
    '   Note Bit value 0 = ENABLE , 1 = DISABLED   POR = 0
    	PMD0 = %00111010	'Bit7-Sys clock(Fosc) to Peripherals , Bit6 FVRMD -Fixed Voltage Ref Module
                            'Bit5 - HLVD Module, Bit4- CRCMD - CRC Module
                            'Bit3 - SCANMD - NVM Memory Scanner Module , Bit2- NVMMD -NVM module
                            'Bit1 - CLKR - Clock Referance , Bit0 IOCMD
        PMD1 = %11111100	'Bit7=N/A ,Bit6=TMR6 ,Bit5=TMR5,Bit4=TMR4,
                            'Bit3=TMR3,Bit2=TMR2,Bit1=TMR1,Bit0=TMR0
        PMD2 = %11011111	'Bit7=N/A ,Bit6=DAC ,Bit5=ADC , Bit4=N/A, Bit3=N/A, Bit2= CMP2, Bit1=CMP1,Bit0=ZCD Zero Cross Detect
        PMD3 = %11111111	'Bit7-4=N/A, Bit3=PWM4, Bit2=PWM3, Bit1=CCP2, Bit0=CCP1
        PMD4 = %01111111	'Bit7= UART2, Bit6= UART1, Bit5= MSSP2 , Bit4=MSSP1,Bit3-1 =N/A , Bit0= CWG1 ( Comparitor Output shutdown )
    	PMD5 = %11111111	'Bit7-1= N/A , Bit0 = DSM (Data Signal Module)
      '  -------   Port C Settings & directions  ----------
        ANSELC  = %00000000          ' Set Port C Analog bit7-0 = ANC7-0 / 0 = digital ,1= Analog
        TRISC   = %00000100          ' 1= Digital Input / 0= Digital Outputs  ANC7 = spare_tx1 output when IR-TX
        IOCCN   = %00000000          ' IOC Negative Edge Trigger Select RC7-RC0  0 = diabled 1 = enabled POR = 0
        WPUC    = %00000000          ' Set Week Pullups on Digital inputs POR =0
        INLVLC  = %11111111          ' Set Input levels - Schmitt = 1 / TTL = 0  POR = 1
        SLRCONC = %11111111          ' Set Slew Rate 1 = Rate Limited  0 = Max rate POR =1
        IOCCP   = %00000000          ' IOC Positive Edge Trigger Select RC7-RC0  0 = diabled 1 = enabled POR = 0
        ODCONC  = %00000000          ' Open Drain 0 = Output drives both High and Low signals  1= Output drives Low going signals only POR = 0
      ' -------   Setup port C Variables  ----------
        SCK           VAR LATC.0       ' Clock pin (output to RF modual)
        SI            Var LATC.1       ' Master Out  - Module Data in pin       (input  to RF Modual)
        SO            Var PORTC.2      ' Master In   - Module Data out pin      (output of RF Modual)
        FLASH1_CE     con 19'= LATC.3  ' Chip select FLASH chip ( low)
        BUZ           var LATC.4       ' Buzzer
       IR_TX_OUT     VAR LATC.5        ' IR-TX_out  when IR-TX
       IR_TX_HI_PWR  VAR LATC.6        ' IR_TX_HI when IR-TX
       SPARE_TX1     VAR LATC.7        ' spare Output when IR_TX mode
       LATA.0[FLASH1_CE] = 1      ' Active Low so set High to start
    Aug 2011
    FWIW, the chip I ran that simple example on was rev A2 silicon.
    This isn't your problem here, but I'd be careful using that syntax to access a bit in LATC.
    I've seen chips where the LATx (and other port related regs) aren't contiguous in memory so that would fail.
    FWIW Microchip have changed the format of device/siliocon rev for 10F2xK40/42, so watch out for that. These devices are quite new so the errata may not be complete, I see no downside in setting up the PPS of all the pins you are going to use, whether it's necessay or not.
    George
  1. Replies: 10
    Last Post: - 26th July 2018, 05:14
  2. 18f27k40 - adc settings
    By longpole001 in forum PBP3
    Last Post: - 12th July 2018, 12:34
  3. 18f4550 portc.4 and portc.5 problem
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 12th October 2008, 21:52
  4. 16f877 portc.6 & portc.7
    By DavyJones in forum mel PIC BASIC Pro
    Last Post: - 12th January 2008, 05:38
  5. HOW do you initialize PortC to normal I/O??
    By Len in forum mel PIC BASIC Pro
    Last Post: - 11th June 2005, 19:56
