not that example , the lookup line might need to be lookup2 , the lookup line is not really relevant to the null termination array processing methodhave you actually tried your null termination method?
Code:OUTARRAY VAR BYTE(80) 'serial string output array BYTEIN VAR BYTE character VAR BYTE BYTEIN = 0 WHILE OUTARRAY(BYTEIN) LOOKUP2 BYTEIN,[OUTARRAY],CHARACTER ' TX_BYTES2(TX_OUTPUT2) = CHARACTER BYTEIN = BYTEIN + 1 ' GOSUB SNDCHAR2 'INCREMENT BUFFER POINTERS WEND
