18f27k40 - adc settings
Results 1 to 6 of 6
    Feb 2012
    PERTH AUSTRALIA
    Default 18f27k40 - adc settings
    hI GUYS ,
    Wondered if anyone has working ADC code that setup the new k40 chips that would be good for a starting reference
    he current code uses ADCIN , but now the structure has changed not sure if it will be the best way for the new K40 chip
    There are lot of new registers in The ADC in this chip which i am working though
    and would like to make use of the new computational operation , to remove the way i currently do average of ADC readings
    Cheers
    sheldon
    OK
    Default Re: 18f27k40 - adc settings
    ; --- *** ADC Related SFRs *** -----------------------------------------------------------------------------------------
    ADCON0 = %10010100 ;.7 = 1/0, .0 = GO
    ADPCH = %00010101 ;For Keypad, ANC5
    ADC VAR WORD
    ADCON0.0 = 1
    DO
    LOOP WHILE ADCON0.0 = 1
    ADC.HIGHBYTE = ADRESH
    ADC.LOWBYTE = ADRESL
    Feb 2012
    PERTH AUSTRALIA
    mike that may work ok , for most i guess , just all the other settings , as clock source, tad rate , internal ref , gain multilpier options on VFR using the count register for samples options , this chip has a lot of stuff in the adc
    also note the errata on the adc issues for this chip which may be of interest as well
    guess i am still reading and noting stuff in the program , not just for this program but for others that will eventually migrate to the k40 range
    just wish microchip had made the k42 with 64/80 pin options , with the more than 128k LOL , just wishing
    studdiing what i can on this new chip
    Why Yes Sheldon I do. Try this configuration, It is for operation in CLASIC mode.
    EN82fn
    Feb 2012
    PERTH AUSTRALIA
    thanks dave for the adc registers , also pickup on some other setting that ill show in the config , although they are not changed from POR
    i am still working out notes on the release pbp3.1.1 on the 18fxxk40 series
    i need hserout2 using usart2 on the PPS default pins , seem the default pins may lock out the ICSP if not changed ??
    THIS FILE HAS BEEN UPDATED FOR PBP 3.1.1
    The function of the 18FxxK40 devices differs somewhat from other PIC18 parts.
    Because of this, the following commands are configured a bit differently when
    executed on the 18FxxK40 devices.
    HPWM
    Use the following PBP DEFINE statements to specify the output pins for HPWM.
    Check the Microchip datasheet (Peripheral Pin Select PPS) for the pins allowed
    on each CCP/PWM channel. The PPS peripheral will automatically be configured
    for the specified output pin upon execution of HPWM. When used on devices other
    than the 18FxxK40, these defines will only control the Data Direction SFRs (TRIS).
    These defines set PPS SFRs only once at program initialization. You may
    change the PWM output pin at any pint in your program code by modifying
    the PPS SFRs.
    DEFINE CCP1_REG PORTC 'Channel-1 port
    DEFINE CCP1_BIT 2 'Channel-1 bit
    DEFINE CCP2_REG PORTC 'Channel-2 port
    DEFINE CCP2_BIT 1 'Channel-2 bit
    DEFINE CCP3_REG PORTC 'Channel-3 port
    DEFINE CCP3_BIT 3 'Channel-3 bit
    DEFINE CCP4_REG PORTG 'Channel-4 port
    DEFINE CCP4_BIT 3 'Channel-4 bit
    DEFINE CCP5_REG PORTG 'Channel-5 port
    DEFINE CCP5_BIT 4 'Channel-5 bit
    DEFINE CCP6_REG PORTE 'Channel-6 port
    DEFINE CCP6_BIT 6 'Channel-6 bit
    DEFINE CCP7_REG PORTE 'Channel-7 port
    DEFINE CCP7_BIT 7 'Channel-7 bit
    CCP and PWM peripherals are both supported by HPWM.
    DEFAULT CCP PINS SET FOR UNUSED HPWM CHANNELS! If CCP_REG DEFINEs are set
    for unused channels, either explicitly or by default, the ports/pins specified
    as CCP/PWM outputs may not function as normal I/O until the PPS SRFs are cleared
    in your program code. To remove a default setting, define the CCPx_REG as 0,
    for example:
    DEFINE CCP2_REG 0 'Channel-2 UNUSED
    DEFINE CCP2_BIT 0 'Channel-2 bit
    DEFINE CCP3_REG 0 'Channel-3 UNUSED
    DEFINE CCP3_BIT 0 'Channel-3 bit
    DEFINE CCP4_REG 0 'Channel-4 UNUSED
    DEFINE CCP4_BIT 0 'Channel-4 bit
    Default output pins if no DEFINE is used:
    2xK40 4xK40 6xK40
    CCP1 RC2 RC2 RC2
    CCP2 RC1 RC1 RC1
    CCP3/PWM3 RC6* RD1 RC3
    CCP4/PWM4 RA7 RA7 RG3
    CCP5 RG4
    PWM6 RE6
    PWM7 RE7
    * Note that default CCP3/PWM3 setting on 28-pin devices conflicts with the default
    TX1 setting described below.
    HSEROUT/HSEROUT2
    Use the following PBP DEFINE statements to specify the output pins for HSEROUT
    and HSEROUT2. Check the Microchip datasheet (Peripheral Pin Select PPS) for the
    pins allowed on each EUSART. The PPS peripheral will automatically be configured
    for the specified RX/TX pins only once after reset or power up. This allows the
    PPS SFRs to be changed at runtime to relocate the RX/TX pins as needed. These
    defines will have no effect when code is executed on devices other than the
    18FxxK40.
    DEFINE HSER_RXREG PORTC
    DEFINE HSER_RXBIT 7
    DEFINE HSER_TXREG PORTC
    DEFINE HSER_TXBIT 6
    DEFINE HSER2_RXREG PORTB
    DEFINE HSER2_RXBIT 5
    DEFINE HSER2_TXREG PORTB
    DEFINE HSER2_TXBIT 4
    2xK40 4xK40 6xK40
    RX1 RC7 RC7 RC7
    TX1 RC6* RC6 RC6
    RX2 RB5** RB5** RG2
    TX2 RB4** RB4** RG1
    * Note that default TX1 setting on 28-pin devices conflicts with the default
    CCP3/PWM3 setting described above.
    ** RX2/TX2 defaults changed for some devices in PBP 3.1.1 to avoid ICSP lockout.
    I2CREAD/I2CWRITE
    The memory map of the 18F4xK40 forces PBP to reduce the I2CREAD/I2CWRITE clock
    frequency slightly to allow I2C operation on PORTE pins. If you aren't using
    I2CREAD/I2CWRITE on PORTE, you may use the following define to maximize the
    clock frequency on ports A, B, C and D.
    DEFINE I2C_ONLYABCD 1
    This define has no effect on 18F2xK40 and 18F6xK40 devices.
    Sheldon, I have never had ICSP lockout issues with the 18F27K40 devices. I rarely use the ICSP option anyways as I always use a boot loader.
    EN82fn
  1. settings check please
    Last Post: - 19th March 2015, 23:51
  2. ADC values above 4095 for 12 bit ADC
    By longpole001 in forum mel PIC BASIC Pro
    Last Post: - 1st February 2015, 22:24
  3. ADC problem on 18F46K22 device using all 28 ADC pins
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 20:22
  4. Back again... 'lil help with ADC settings
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 18th July 2010, 20:11
  5. 18F4580 settings
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 27th March 2010, 15:59
