EEPROM Issue
Results 1 to 14 of 14
Thread: EEPROM Issue
    Default Re: EEPROM Issue
    write 132,CB is not correct. You have to write 132,$CB.
    OK
    No, CB is the name of my variable, not the value.
    Do you have (or can you add) a debug port (EUSART, SEROUT, DEBUG)?
    If so, then print the value of your variable out before calling the write routine, before executing the write command, after executing the write command, read the value back immediately after and print it out again.
    Is CB declared as a BYTE?
    If you're indexing arrays somewhere then doublecheck that you're not writing outside the range of the array.
    OK
    CB is declared as a BYTE. I checked the arrays' indexing several times. I have a spread sheet with all the variables listed, size (BIT, BYTE, etc), USB ID#, the internal code used to communicate each variable with other PICs on the board (there are a total of 6), and some other criteria. I've been working on this project for the past several years. It's due in less than 2 weeks.
    I decided to rebuild the HIDmaker side of things. I found several variables, including arrays, that were structured as signed bytes. I'm dealing with the sign in software and forgot I did that earlier. I will be totally revamping it around the proper non-signed bytes and try again.
    This makes me wondering, how can one follow every detail in a large program.
    Too many variables and chances are something will go wrong.
    much easier in C
    local vars and scope make life easier , user defined structures remove all doubt
    Local vars is a dream (and in wish list) for PBP.
    I think with a bit of creativity, structures can be implemented with arrays in PBP also.
    Not specific to data structures though.
  1. SPI SS Issue
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 17th October 2014, 00:04
  2. IF-THEN issue
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 12th February 2014, 22:09
  3. EEPROM or DATA issue with 16F1503
    By scasale in forum mel PIC BASIC Pro
    Last Post: - 11th October 2013, 04:46
  4. 12F675 - another issue
    Last Post: - 26th August 2011, 19:26
  5. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 08:52
