https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299
Anyone implemented "query number of files" function?
I want to add this to alarm clock, as alarm tone storage, so user should get number of files, to properly choose the desired tone.
I have it running with software serial port, but facing some issues.
Based on code above:
This works, however, it requires at least 500ms pause between each statements, or they're ignored.Code:serout portc.5,t9600, [$7e,$ff,$06,$06,$00,$00,$07,$fe,$ee,$ef] pause 500 serout portc.5,t9600, [$7e,$ff,$06,$03,$00,$00,$02,$fe,$f6,$ef]
Is this normal?
also, I have read the datasheet, but can't understand, which bit, based on which logic I should change in code above, to select another track, or change volume?
for example, in this code, posted above, which selects #3, #2, #1 songs in a folder, I can clearly see
Code:hserout [$7e,$ff,$06,$03,$00,$00,$03,$fe,$f5,$ef] hserout [$7e,$ff,$06,$03,$00,$00,$02,$fe,$f6,$ef] hserout [$7e,$ff,$06,$03,$00,$00,$01,$fe,$f7,$ef]
But why there are $F5, $F6, $F7 bytes also changing at the end of the code?
Looking at the data sheet page 6, in post #1.
Play a track 7E FF 06 14 00 10 FF FD D8 EF , without checksum 7E FF 06 14 00 10 FF EF 10 FF = folder 1 track 255, The upper nibble "1" specifies the folder. The lower 3 nibbles are the track number so F1 11 would be folder 15, track 273
Volume change the 1E byte from 0 to FF to set the valume
Specify volume 7E FF 06 06 00 00 1E FE D7 EF , without checksum 7E FF 06 06 00 00 1E EF Specified volume is level 30 =0X1E
Looking at the data sheet againBut why there are $F5, $F6, $F7 bytes also changing at the end of the code?
There are to two ways to send a command, one with checksum 10 bytes and the other without checksum 8 bytes.
Thanks, to which datasheet you refer to? My module is different, sorry for confusion. I'm using this: https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299
And how to play without any folder at all? i.e. all files are just on the SD card?
See the PDF file in the first post of this thread. It looks like the same module as you have. As far as folders for mp3, I have no knowledge. Maybe you can can use 0?
Thanks! I've sorted it out and using now without checksum and it works fine.
However, the issue with slow acceptance of statements persists...
