MP3 DFPlayer Mini and PIC MCU
Results 1 to 14 of 14
    Porto - Portugal
    Default MP3 DFPlayer Mini and PIC MCU
    Hello to all
    Does anyone in this knowledge comunnity ever used an MP3 player like "FN-M16P Embedded MP3 Audio Module" and did successfully controlled the player with a (any) PIC MCU.
    Thanks in advance
    Vicente
    nomada
    Default Re: MP3 DFPlayer Mini and PIC MCU
    This is real interesting. It looks to be rather straight forward to operate.
    EN82fn
    I have used this http://geekmatic.in.ua/pdf/Catalex_MP3_board.pdf
    ebay
    https://www.ebay.co.uk/itm/Wemos-YX5...0AAOSwatda0Odb
    TTL 3.3-5v
    Made a speaking clock with it, also used some other similar modules but not tried yours.
    Just found my youtube link to it
    forget what account I had used !!
    Are DFPlayer and FN-16 the same one?
    Anyway, here are my snippets using the DFPlayer module:
    'Set volume
    hserout [$7e,$ff,$06,$06,$00,$00,$07,$fe,$ee,$ef]   'Volume 7/30
    'Play track 3
    hserout [$7e,$ff,$06,$03,$00,$00,$03,$fe,$f5,$ef] 'Play 3rd track in folder 00. Dial tone
    hserout [$7e,$ff,$06,$03,$00,$00,$02,$fe,$f6,$ef] 'Play error tone, 2nd track in folder 00
    error:
        hserout [$7e,$ff,$06,$03,$00,$00,$01,$fe,$f7,$ef] 'Play message, 1rst track in folder 00
    start1:
        hserout [$7e,$ff,$06,$11,$00,$00,$00,$fe,$ea,$ef]' Stop playing
    The above are part of a bigger program but you get the idea of using volume and play/stop commands.
    Porto - Portugal
    Hello to all
    Ionnis you are right, soon after I started this thread, I have found that when I ordered the FN-M16P, the module I received is identified as DFPlayer Mini SKU DFR0299 or SKU 204222 depending on the supplier.
    I've tried the module and it seems to work nice (for the price), the stereo hearphones out has a very good quality not so good is the 3W powered output (mono out).
    If any of you plan to use this module do not use checksum and try each module to check if returns the power-on status, if not discard the module because it will never work good.
    Thank you (obrigado!) to you all for your replies and contribution - Dave Purola - aerostar - Ioannis
    Vicente
    nomada
    Is it possible to use it with software serial port, instead of hserout?
    And how big is delay?
    These modules also support WAV file playback, so my idea is to load a bunch of samples, say 32 different wav files, and create music keyboard
  1. Any 8 pin PIC MCU, that can use MCLR as ADCIN or output?
    Last Post: - 11th December 2016, 19:38
  2. ABS brake Pic code with 16f917 mcu
    By Foodie in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 20:58
  3. interaction between Bluetooth and PIC MCU
    By veenadari in forum Bluetooth
    Last Post: - 23rd June 2009, 15:03
  4. Block diagram for PIC based mp3 player
    By joseph Degorio in forum Schematics
    Last Post: - 18th December 2007, 16:13
  5. mini speaker
    By Ron Marcus in forum Off Topic
    Last Post: - 4th March 2007, 23:43
