GPS Project: PIC18F26K22 or PIC18F46K22
Results 1 to 40 of 69
    Default Re: GPS Project: PIC18F26K22 or PIC18F46K22
    I have my doubts on leaving inputs floating.
    Usually if I have any unused ports, I turn them as outputs and clear them.
    If they are inputs, maybe enable the pull ups if any or tie them to ground.
    A floating pin can cause troubles in certain cases.
    if your program is adversely affected by an unused pin then your code is incomplete and needs more debugging
    No the program itself but on the total current consumption as the CMOS do not like to be float.
    Especially when in the presence of stray RF. They make rather nice antenna's.
    EN82fn
    Oct 2010
    Ok then what is the most professional way in most of the cases to configure the pins?
    Should we make all the non used pins as an outputs - low stage?
    its my understanding that pins left as inputs and tied or pulled down to vss will minimise current consumption.
    when i'm breadboarding a design I let them float and have never had an issue , if you accidently plug something
    into a input pin at least smoke is not released.
    Depends. If you care about minimum current as is the case in battery operated devices, then yes. Do set them as inputs with proper pull up enabled inside the PIC or a large size output.
    I found that makes no difference, at least for the chips I used, to set them as outputs logic low, and use no pull up or down. Pull up/down can also contribute to current consumption.
    I attach the page 2-4 of the Tips and Tricks, file DS01146B regarding I/O that has more info on this.
    Oct 2010
    I believe that any input pin must be pulled either up or down depends on the use. If there is a switch normally most of the people, pull up a resistor at the input pin, and the switch goes to ground.
    Now for the rest of the pins personally if the pins are output and digital, i leave them floating, but i use the command:
    PORTx = low
    Just read Ioannis previous post. It is really useful info. Thanks a lot.
  1. PIC18F46K22 config issue
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 03:20
  2. Replies: 1
    Last Post: - 27th July 2008, 06:14
  3. Pic GPS project Demo
    By Art in forum GPS
    Last Post: - 28th October 2007, 03:05
  4. GPS project question
    By mjp130 in forum GPS
    Last Post: - 4th July 2007, 20:09
  5. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 02:52
