GPS Project: PIC18F26K22 or PIC18F46K22
Results 1 to 40 of 69
    Oct 2010
    Default Re: GPS Project: PIC18F26K22 or PIC18F46K22
    Richard, bardon me. Still im confused from your answer.
    I understand the part of setting up the EUSART, automatically we make the TX port as an output.
    My question is, what do we do with the rest of the TRISB and TRISC bits apart from the RX/TX.
    TRISA = %00000000   'use TRISA to specify which pin is (1 = input) and which (0 = output)  (ALL pins are output)
    TRISB = %10000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %10000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
                        'in PORTC the RC3 attached is an LED.
    '           --------------- TRIS A-B-C ---------------
    ' PORTA.7  PORTA.6  PORTA.5  PORTA.4  PORTA.3  PORTA.2  PORTA.1  PORTA.0 |
    '  bit7     bit6     bit5     bit4     bit3     bit2     bit1     bit0   |
    '   0        0        0        0        0        0        0        0     |
    ' PORTB.7  PORTB.6  PORTB.5  PORTB.4  PORTB.3  PORTB.2  PORTB.1  PORTB.0 |
    '   1        0        0        0        0        0        0        0     |
    ' PORTC.7  PORTC.6  PORTC.5  PORTC.4  PORTC.3  PORTC.2  PORTC.1  PORTC.0 |
    '   1        0        0        0        0        0        0        0     |
    I feel like i'm missing something. Sorry for my questions, but i would like to be sure i understand every part of the code. And when i configure the ports as an input or outputs, or Digital/Analogue, i need to know exactly what am i doing.
    In our case as we want to configure the EUSART, as you stated from the manual -datasheet, we have automatically the TX pin as an output. But dont we continue to specify the other pins with the TRIS command?
    that would depend entirely on what you want do with each pin , if and only if you need it to be an output clear the corresponding tris bit
    Oct 2010
    Thanks a lot for your answer. I guess we cant leave unassigned the bits. Normally as far as i have learned from what i have read in this forum, it is better to configure the bits of each port and give an Input or Output direction in addition to high or low stage.
    there is no such state , pins are either inputs or outputs or analog inputs , outputs can only be high or low
    if you have no reason to use a pin as an output then leave as an input , if you have no reason to use a pin as a digital input you can leave it analog
    the pic chip won't care. the pic chip does not care if outputs are high or low its only what they connect to that cares , it up to you to initialise the pins
    in use to the correct type/state and direction to match the requirement of what they connect to and then make sure they stay that way.
    Oct 2010
    now it is clear. Really appreciate your help.
    Thanks a lot Richard.
    I have my doubts on leaving inputs floating.
    Usually if I have any unused ports, I turn them as outputs and clear them.
    If they are inputs, maybe enable the pull ups if any or tie them to ground.
    A floating pin can cause troubles in certain cases.
    if your program is adversely affected by an unused pin then your code is incomplete and needs more debugging
    No the program itself but on the total current consumption as the CMOS do not like to be float.
  1. PIC18F46K22 config issue
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 03:20
  2. Replies: 1
    Last Post: - 27th July 2008, 06:14
  3. Pic GPS project Demo
    By Art in forum GPS
    Last Post: - 28th October 2007, 03:05
  4. GPS project question
    By mjp130 in forum GPS
    Last Post: - 4th July 2007, 20:09
  5. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 02:52
