GPS Project: PIC18F26K22 or PIC18F46K22
Results 1 to 40 of 69
Threaded View
  1. #17
    Oct 2010
    Default Re: GPS Project: PIC18F26K22 or PIC18F46K22
    TRISB = %10000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %10000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
                        'in PORTC the RC3 attached is an LED.
    setting the tris incorrectly will stop the eusarts from working
    from data sheet
    Setting the TXEN bit of the TXSTAx register enables thetransmitter circuitry of the EUSART. Clearing the SYNC
    bit of the TXSTAx register configures the EUSART for
    asynchronous operation. Setting the SPEN bit of the
    RCSTAx register enables the EUSART and
    automatically configures the TXx/CKx I/O pin as an
    output. If the TXx/CKx pin is shared with an analog
    peripheral the analog I/O function must be disabled by
    clearing the corresponding ANSEL bit.
    To be honest i didnt really understand the statement. I understand that it is not necessary to set a TRIS register at TX bit as automatically the TX configured as an output.....
    as we have already stated and configured the EUSART with the following:
    '*----------------------- | EUART 1 Configuration  | --------------------------|
            DEFINE HSER_SPBRG 160 ' 38400 Baud @ 64MHz, -0,08%
            SPBRGH = 1
    '*----------------------- | EUART 2 Configuration  | --------------------------|
            DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive
            DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
            DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
            DEFINE HSER2_SPBRG 160 ' 38400 Baud @ 64MHz, -0,08%
            SPBRGH2 = 1
            BAUDCON2.3 = 1         ' Enable 16 bit baudrate generator
    How Do we configure the rest of the TRIS bits?
    TRISB = %1X000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %1X000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
  1. PIC18F46K22 config issue
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 04:20
  2. Replies: 1
    Last Post: - 27th July 2008, 07:14
  3. Pic GPS project Demo
    By Art in forum GPS
    Last Post: - 28th October 2007, 04:05
  4. GPS project question
    By mjp130 in forum GPS
    Last Post: - 4th July 2007, 21:09
  5. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 03:52
