GPS Project: PIC18F26K22 or PIC18F46K22
Results 1 to 40 of 69
    Oct 2010
    Default Re: GPS Project: PIC18F26K22 or PIC18F46K22
    nothing , leave it alone
    OSCTUNE.6 = 1 ; Enable 4x PLL becomes non functional if CONFIG PLLCFG = ON
    Thanks i'll do so. Tonight i will post result in addition to some pictures from Oscilloscope. Lets see.
    Oct 2010
    I did the following code test in order to check communication with an uLCD 144 and the LED as before at the same port.
    I would love to use the .inc files for the Nokia 3310 or 5110 LCD but really i dont know which files are the ones match.
    Anyway i think the code works as it is and the configuration settings are ok.
    @ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of   *
                      ; crossing page boundary - make sure bits are set              *
      #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
    ;    CONFIG FOSC     = RCIO6	    ; External RC oscillator
         CONFIG FOSC     = HSHP	        ; HS oscillator (high power > 16 MHz)
    ;*---------------------------------4x PLL ENABLE--------------------------------------*|
    ;*  4X PLL Enable        *|
    ;*    CONFIG PLLCFG  = OFF	        ;Oscillator used directly                         *|
        CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4                       *|
    ;  Primary clock enable bit
    ;    CONFIG PRICLKEN = OFF	        ;Primary clock can be disabled by software
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
    ;  Fail-Safe Clock Monitor Enable bit
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
    ;    CONFIG FCMEN    = ON	        ;Fail-Safe Clock Monitor enabled
    ;  Internal/External Oscillator Switchover bit
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
    ;    CONFIG IESO     = ON	        ;Oscillator Switchover mode enabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
    ;*---------------Available configuration settings for PIC18F26K22-------------------|
    ;  Oscillator Selection bits
    ;    CONFIG FOSC = RC	    ;111X External RC oscillator, CLKOUT function on RA6
    ;    CONFIG FOSC = ECLPIO6  ;EC oscillator (low power, <500 kHz)
    ;    CONFIG FOSC = ECLP	    ;EC oscillator, CLKOUT function on OSC2 (low power, <500 kHz)
    ;    CONFIG FOSC = ECMPIO6  ;EC oscillator (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = ECMP	    ;EC oscillator, CLKOUT function on OSC2 (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = INTIO7   ;Internal oscillator block, CLKOUT function on OSC2
    ;    CONFIG FOSC = INTIO67  ;Internal oscillator block
    ;    CONFIG FOSC = RCIO6    ;External RC oscillator
    ;    CONFIG FOSC = RC	    ;External RC oscillator, CLKOUT function on OSC2
    ;    CONFIG FOSC = ECHPIO6  ;EC oscillator (high power, >16 MHz)
    ;    CONFIG FOSC = ECHP	    ;EC oscillator, CLKOUT function on OSC2 (high power, >16 MHz)
    ;    CONFIG FOSC = HSMP	    ;HS oscillator (medium power 4-16 MHz)
    ;    CONFIG FOSC = HSHP	    ;HS oscillator (high power > 16 MHz)
    ;    CONFIG FOSC = XT	    ;XT oscillator
    ;    CONFIG FOSC = LP	    ;LP oscillator
    ;*  -----------------------------   |  [PROTECTED OPTION FUSES]  |  ------------------------------------  |
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define  OSC 64
            INCLUDE "modedefs.bas"
            INCLUDE"ALLDIGITAL.pbp"
    OSCCON    = %01110000   ; 64Mhz
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    TRISA = %00000000   'use TRISA to specify which pin is (1 = input) and which (0 = output)  (ALL pins are output)
    TRISB = %10000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %10000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
                        'in PORTC the RC3 attached is an LED.
    '           --------------- TRIS A-B-C ---------------
    ' PORTA.7  PORTA.6  PORTA.5  PORTA.4  PORTA.3  PORTA.2  PORTA.1  PORTA.0 |
    '  bit7     bit6     bit5     bit4     bit3     bit2     bit1     bit0   |
    '   0        0        0        0        0        0        0        0     |
    ' PORTB.7  PORTB.6  PORTB.5  PORTB.4  PORTB.3  PORTB.2  PORTB.1  PORTB.0 |
    '   1        0        0        0        0        0        0        0     |
    ' PORTC.7  PORTC.6  PORTC.5  PORTC.4  PORTC.3  PORTC.2  PORTC.1  PORTC.0 |
    '   1        0        0        0        0        0        0        0     |
    PORTA = 0            'make low all ports at A range
    PORTB = 0            'make low all ports at B range
    PORTC = 0            'make low all ports at C range
    PORTE = 0            'make low all ports at E range
    '*----------------------- | EUART 1 Configuration  | --------------------------|
            DEFINE HSER_SPBRG 160 ' 38400 Baud @ 64MHz, -0,08%
            SPBRGH = 1
    '*----------------------- | EUART 2 Configuration  | --------------------------|
            DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive
            DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
            DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
            DEFINE HSER2_SPBRG 160 ' 38400 Baud @ 64MHz, -0,08%
            SPBRGH2 = 1
            BAUDCON2.3 = 1         ' Enable 16 bit baudrate generator
    Timeout         CON 1000
    Counter         var byte
    ser_in_data     var byte
    LED             var PORTC.3
    '                          [ LCD Initialization ]                         /
              ' FIRST TIME BOOTUP: We give plenty of time for tbe LCD '
    pause 2000
    HSEROUT2[$55]      ' uOLED Initialize this is the 'U' character of autoband rate to LCD
    Hserin2  timeout,main,[wait(6)]
    hserout2[$56,$01]  ' this is the Version info --> '01 10 17 28 28   -->> "(("
    Hserin2  timeout,main,[wait(1),wait(16),wait(23),wait(40),wait(40)]
    HSEROUT2 [$45]    ' clear the LCD
    hserout2[$73,$00,$03,$11,$ff,$ff," Leonardo Bilalis",$00]
    hserout2[$73,$02,$06,$10,$ff,"     Copyright 2018",$00]
    Hserout2[$4F,01]
    Start:
    for counter = 1 to 100
    HSEROUT2 [$73,$03,$02,$11,$ff,$ff,"Counter:", #counter,$00]
    pause 10
    next counter
    ;gosub main ---> i did commented this as from Ioannis's advice.
    high LED
    low LED
    This is a bad programing.
    You use a gosub to main but there is no return from the main.
    Delete the line gosub main as there is no point.
    Be very careful with such commands, as it is common to novice programmers this error. Your program will crash with no obvious reason.
    Oct 2010
    Oppps , i didnt notice.
    Thanks Ioanni. As you see i have also configured the First EUART. There will be placed either the GPS module or the SD card.
    P.S. didnt have a time tonight to do the test and post pictures from the oscilloscope. Will do that tomorrow.
    setting the tris incorrectly will stop the eusarts from working
    from data sheet
    Setting the TXEN bit of the TXSTAx register enables the
    transmitter circuitry of the EUSART. Clearing the SYNC
    bit of the TXSTAx register configures the EUSART for
    asynchronous operation. Setting the SPEN bit of the
    RCSTAx register enables the EUSART and
    automatically configures the TXx/CKx I/O pin as an
    output. If the TXx/CKx pin is shared with an analog
    peripheral the analog I/O function must be disabled by
    clearing the corresponding ANSEL bit.
    Oct 2010
    from data sheet
    Setting the TXEN bit of the TXSTAx register enables thetransmitter circuitry of the EUSART. Clearing the SYNC
    To be honest i didnt really understand the statement. I understand that it is not necessary to set a TRIS register at TX bit as automatically the TX configured as an output.....
    as we have already stated and configured the EUSART with the following:
            SPBRGH = 1
            SPBRGH2 = 1
    How Do we configure the rest of the TRIS bits?
    TRISB = %1X000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %1X000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
    when you read
    output.
    in the eusart section it means its unnecessary to clear the tris bit for the tx pin, keep in mind that on some chips clearing the tx pin tris bit
    will stop the eusart from working . I prefer to form good habits ,although the 18f26k22 does not seem to object and functions either way .
  1. PIC18F46K22 config issue
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 04:20
  2. Replies: 1
    Last Post: - 27th July 2008, 07:14
  3. Pic GPS project Demo
    By Art in forum GPS
    Last Post: - 28th October 2007, 04:05
  4. GPS project question
    By mjp130 in forum GPS
    Last Post: - 4th July 2007, 21:09
  5. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 03:52
