16F1827 - Slow Clock
Results 1 to 5 of 5
    Default 16F1827 - Slow Clock
    Apparently there is something I do not see. And is 3.30 am...
    The following settings make the PIC run at 1/4 the speed it is supposed to.
    #config
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _LVP_OFF & _STVREN_OFF ;& _BORV_25
    #endconfig
    DEFINE OSC 32
    If I set the DEFINE OSC at 8 then the speed is as expected. But the above config is for 8 x 4 PLL = 32MHz...
    Where am I wrong?
    Default Re: 16F1827 - Slow Clock
    osccon=$70
    or
    & _PLLEN_OFF
    osccon=$F0
    also
    it takes a little time for pll to stabilise
    while !oscstat.6 : wend ;wait for pll ready
    Hmm, I did OSCCON=$F0 but at the same time & _PLLEN_ON.
    Does it matter?
    you would think not , but I have been using mplabx/mcc mostly lately and for some chips it does indeed matter it seems.
    soft selecting pll always works so that's what i'm used to doing ,
    And it does work as expected!
    Thanks Richard.
  1. Misbehaving HPWM on 16F1827
    By J. Mark Wolf in forum mel PIC BASIC Pro
    Last Post: - 20th January 2012, 00:32
  2. 16F1827 Errata
    By Ioannis in forum General
    Last Post: - 23rd March 2011, 21:42
  3. 16F1827 setup
    By Macgman2000 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2011, 23:04
  4. 16F1827 ASM Interrupt
    By abbtech in forum mel PIC BASIC Pro
    Last Post: - 16th February 2011, 06:47
  5. 16F1827 voltage issue
    Last Post: - 28th January 2011, 12:42
