more i2c and mcp23017
Results 1 to 27 of 27
    Jun 2011
    Indian Harbour Nova Scotia
    Default more i2c and mcp23017
    I have a bunch of LEDs with anodes tied to Vcc through resistors. The cathodes are tied to the outputs of an MCP23107 port expander. I'm using the same setup I had for Arduino that worked, so I know this setup works.
    Trying to get it going in Pic Basic Pro is not working. I have simplified my program to very, very basics to eliminate any "distractions". Here it is:
    #config
     __CONFIG _CONFIG1, _HS_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CPD_OFF & _BOR_ON & _IESO_ON & _FCMEN_ON & _LVP_OFF
     __CONFIG _CONFIG2, _BOR40V & _WRT_OFF
    #endconfig
    define LOADER_USED 1
    DEFINE OSC 4                 '4 MHz crystal on LabX1, not the processor speed
    'TRISC =     %00000000
    SDA         VAR PORTC.4        'i2c data line, 16F887
    SCL         VAR PORTC.3        'i2c clock line  16F887
    addr        var byte           'address of port expander
     INIT:
    addr = $42
    I2CWRITE SDA,SCL,addr,[$00,$00] 'set for all output
    MAIN:
         I2CWRITE SDA,SCL,addr,[$09, $00]
         I2CWRITE SDA,SCL,addr,[$09, $ff]
    Why doesn't this blink the LEDs I have attached to the PE. When I check voltage, it never drops to zero. I've scoped my SDA and SCL lines and they are working fine. I have 5 volts (4.9 actually) on the chip, and the address for this one is $42 (address A1 is high).
    I'm using a LabX1 with 16F887 mcu. I'm expecting all the lights to blink but none do. (I've played with the GPI0 register, making it $12 instead of $09)
    What am I missing? Arduino spoiled me by providing me with libraries that did all the work!
    Aug 2011
    Default Re: more i2c and mcp23017
    The chip powers up with the IOCON register = 0, so you need to use the "IOCON.BANK=0" column of table 3-1 for the register addresses.
    That puts GPIOA at address $12, not $09.
    a largely meaningless statement, an Arduino lib could do all sorts of unmentionable things to anything it comes into contact with
    it needs to be
    I'm using this <library> found here <link to lib> with this setup init() function connected this way <schematic or description>
    eg
    #include <RFM12B.h>
    // By default the SPI-SS line used is D10 on Atmega328. You can change it by calling .SetCS(pin) where pin can be {8,9,10}
    #define NODEID           1  //network ID used for this uniy
    #define NETWORKID       99  //the network ID we are on
    //lib  https://github.com/LowPowerLab/RFM12B
     radio.Initialize(NODEID, RF12_433MHZ, NETWORKID);
    Jun 2011
    I'm using this library: Centipede, found here: http://macetech.com/store/index.php?...products_id=23, with this setup: (this code for 5 different boards). PCB board layout attached.Name:  RGBModelPoint (1).jpg
Size:  135.9 KB I have 5 of these RGB boards using the code below without issue, but I can't get a simpler version (the PBP code) with monochrome LEDs working.
    /*PointsRGBTEST This is working copy.
    RGB test BF29April2018
    Code to check new RGB Points PCB as precursor to the big Star.
    Test of matrix RGB activation. Uses MCP23017 I2C port expanders
    at addresses 20 to 24 and special RGB Star point model. Sequences
    through 7 colors (see below) for 16 lights. Does all one color
    for 16, then next color for same 16. Note RED overwhelms other colors
    so blue or green mixed in show red, instead of magenta and yellow.
    #include <Wire.h>
    #include <Centipede.h>
    Centipede CS;
    const int pins[3] = {//9,10,11 are DIO pins for RGB transistors. Active high turns transistor on.
    9, 10, 11 //use 9, 10, 11 because these are PWM pins on UNO
    int x = 50;//delay between LEDs on/off //
    int i;
    byte b;
    byte p;
    const byte rgb[7] = {0x02, 0x04, 0x08, 0x05, 0x06, 0x0C, 0x0E,}; //00000010= 0x02
    //Red overpowers other lights when lit in combination, eg with green or blue.
    /*const byte Red = ~0x02; //0B00000010 Red on PB1 pin 9 of Uno invert bits 1 here is on, but must be zero for relay
    const byte Green = ~0x04; //0B00000100 Green on PB2 pin 10
    const byte Blue = ~0x08; //0B00001000 Blue on PB3 pin 11
    const byte Magenta = ~0x05; //0B00001010 red and blue
    const byte Yellow = ~0x06; //0B00000110 red and green
    const byte Cyan = ~0x0C; //0B00001100 blue and green
    const byte All = ~0x0E; //0B00001110 all lights should be white
    const byte Seg0 = ~0x01; //0B00000100 Segment 0 on PD0, pin 0 of UNO
    const byte Seg1 = ~0x02; //0B00001000 Segm*/
    void setup() {
    Wire.begin(); // start I2C
    CS.initialize();
    for (byte p = 0; p < 5; p++)//initialize all 5 port expanders
    { CS.portMode(p, 0x00);} //
    // initialize the I/O pins as outputs
    for (int i = 0; i < 3; i++) {
    pinMode(pins[i], OUTPUT);
    void loop()
    for (byte b = 0; b < 7; b++)
    PORTB = rgb[b]; //cycle 7 colors on pins 9,10,11
    for (int p = 0; p < 16; p++)//16 needed to display LED 15
    {CS.portMode(1, 0x00);
    CS.digitalWrite(p, HIGH);//toggle light ON
    delay(x);
    CS.digitalWrite(p, LOW); //turn light OFF
    delay(x);
    Jun 2011
    Yeah, I saw that but $12 didn't work either. Output just won't go low. I measure 3.5 volts or so with my DMM on all GPA pins.
    Jun 2011
    This is what I get on SDA and SCL with that short program.
    Jun 2011
    I put a label at the end of my i2C write statement to flash an LED if there is no acknowledge from the chip.
    there is NO acknowledge...the LED is flashing. So that's a result I will work with. I have extra port expanders (all pretested) and 16F887s.
    Update:
    Changed out port expanders: no change
    Changed out 16F887: no change
    Changed SDA and SCL port from PortC.4 and PortC.3 to PortA.5 and PortA.4: works. Acknowledge led is OFF>
    Any insight into why PortC didn't work but PortA does? ON the LabX1, C.4 and C.3 are designated for I2C.
    for what its worth
    this works for me
    sda VAR PORTA.1
    scl VAR PORTA.2
    trisa.5=0
    '  pause 2000
    '    Debug "Start",13 ,10
    addr var byte ;mcp control address
    reg var byte  ;mcp register
    da var byte   ;gpioa data
    da=$f8
    addr = $40
    reg=0
    I2CWRITE SDA,SCL,addr,reg,[$00] 'set gpioa all output
    reg=9
    LOOOP:
    I2CWRITE SDA,SCL,addr,reg,[da]
    da=da+1
    GOTO LOOOP
    Jun 2011
    Despite the superiority of PBP and Mecanique IDE, working with the i2c commands is a bear! Struggled for a week on it, still no go. Went back to Arduino, and still cursing at all the syntax. However, a quick hookup and I have 80 LEDS spread across 5 boards (PCB above), running all kinds of patterns in COLOR without issue. It's basically the code I submitted (for Arduino) except the CS.digitalWrite is repeated 5 times, once for each board. I've got 20 pages of code done in Arduino, couldn't get one light to light up consistently with PBP.
    Thanks anyway. Going to the Arduino forum now to find out how to create functions (subroutines) to make my code trim and proper.
    would you care to provide some code to demonstrate a i2cread/write command that exhibits some problem
    I find it always works as documented .
    I suspect that you have no idea of what the centipede library actually does behind the scenes and that
    you are attempting pbp code based on that total lack of understanding. maybe if you posted some code
    help would be offered all we have seen so far is just totally wrong.
    good luck with your endeavours on the Arduino forum , they just love posts with no code
    Oct 2009
    I also found that they get arsy if you give them too much. I didn't get much joy from the three arduino forums I posted on when porting my thermostat code to the platform. They also don't provide code for you if you're stuck, they expect you to work that part out when they've told you what to do, and if you are new to the platform and still find the syntax strange.
    I found the guys on this forum a lot more friendlier and supportive. It's just a shame that PBP lacks the native support for most modern things - but I2C is one of the basics and I've never had issues when using it to talk to LED driver chips etc.
    Deleted, reformulated with complete code in next post.
    I cleaned my code up, so it's really apparent what I'm trying to do.
    I still won't blink the 16 LEDs.
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    define  CCP1_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_REG    PORTB
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
        HPWM 3, 8, 1953
    addr        var byte : addr      = %01000000        ' $40
    IOCONreg    var byte : IOCONreg  = $05
    IOCONdat    var byte : IOCONdat  = %10110000
    '   bit 7   1 = The registers associated with each port are separated into different banks.
    '   bit 6   0 = The INT pins are not connected. INTA is associated with PORTA and INTB is associated with PORTB
    '   bit 5   1 = Sequential operation disabled, address pointer does not increment.
    '   bit 4   1 = Slew rate disabled
    '   bit 3   0 = Disables the MCP23S17 address pins.
    '   bit 2   0 = Active driver output (INTPOL bit sets the polarity.)
    '   bit 1   0 = Active-low
    '   bit 0   Unimplemented: Read as ‘0’
        I2CWRITE PinSDA2,PinSCL2,addr,IOCONreg,[IOCONdat]
    IODIRAreg   var byte : IODIRAreg = $00
    IODIRAdat   var byte : IODIRAdat = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,IODIRAreg,[IODIRAdat] 'set GPIOA all output
    IODIRBreg   var byte : IODIRBreg = $10
    IODIRBdat   var byte : IODIRBdat = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,IODIRBreg,[IODIRBdat] 'set GPIOB all output
    GPIOAreg    var byte : GPIOAdat    var byte
    GPIOBreg    var byte : GPIOBdat    var byte
    LOOOP:
        GPIOAreg    = $09 : GPIOAdat    = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,GPIOAreg,[GPIOAdat]
        GPIOBreg    = $19 : GPIOBdat    = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,GPIOBreg,[GPIOBdat]
        pause 250
        GPIOAreg    = $09 : GPIOAdat    = %11111111
        GPIOBreg    = $19 : GPIOBdat    = %11111111
        pause 250
        GOTO LOOOP
    The HPWM is for a IRFZ44N that i use to pulse the LED grounds. I have a simple LED on it to confirm that it's operating.
    Tried with OLAT registers, no joy.
    DEFINE OSC 32
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
        HPWM 3, 8, 1953
    OLATAreg    var byte : OLATAdat    var byte
    OLATBreg    var byte : OLATBdat    var byte
    LOOOP:
        OLATAreg    = $0A : OLATAdat    = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,OLATAreg,[OLATAdat]
        OLATBreg    = $1A : OLATBdat    = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,OLATBreg,[OLATBdat]
        pause 250
        OLATAreg    = $0A : OLATAdat    = %11111111
        OLATBreg    = $1A : OLATBdat    = %11111111
        pause 250
        GOTO LOOOP
    It won't let me add info to my previous post above:
    16F18877
    MCP23017
    Using 1K/130pF on SCL/SDA as mentioned on p.5 of datasheet (they use 135pF).
    I didn't quite understand what they meant with the Bank A/B at first.
    I've now tried with both versions, and still no blinky.
    DEFINE OSC 32
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
        HPWM 3, 8, 1953
    IOCONdat    var byte : IOCONdat  = %00110000      ' Bank=0
    'IOCONdat    var byte : IOCONdat  = %10110000      ' Bank=1
        I2CWRITE PinSDA2,PinSCL2,addr,IOCONreg,[IOCONdat] : pauseus 1
    IODIRAreg   var byte : IODIRAreg = $00      ' Bank=0
    'IODIRAreg   var byte : IODIRAreg = $00      ' Bank=1
        I2CWRITE PinSDA2,PinSCL2,addr,IODIRAreg,[IODIRAdat] : pauseus 1 'set GPIOA all output
    IODIRBreg   var byte : IODIRBreg = $01      ' Bank=0
    'IODIRBreg   var byte : IODIRBreg = $10      ' Bank=1
        I2CWRITE PinSDA2,PinSCL2,addr,IODIRBreg,[IODIRBdat] : pauseus 1 'set GPIOB all output
    LOOOP:
        OLATAreg    = $14 : OLATAdat    = %00000000      ' Bank=0
    '    OLATAreg    = $0A : OLATAdat    = %00000000      ' Bank=1
        I2CWRITE PinSDA2,PinSCL2,addr,OLATAreg,[OLATAdat] : pauseus 1
        OLATBreg    = $15 : OLATBdat    = %00000000      ' Bank=0
    '    OLATBreg    = $1A : OLATBdat    = %00000000      ' Bank=1
        I2CWRITE PinSDA2,PinSCL2,addr,OLATBreg,[OLATBdat] : pauseus 1
        pause 250
        OLATAreg    = $14 : OLATAdat    = %11111111      ' Bank=0
    '    OLATAreg    = $0A : OLATAdat    = %11111111      ' Bank=1
        OLATBreg    = $15 : OLATBdat    = %11111111      ' Bank=0
    '    OLATBreg    = $1A : OLATBdat    = %11111111      ' Bank=1
        pause 250
        GOTO LOOOP
    The example you refer to used and expected iocon.bank to = 1 , why i chose that and how it got that way are lost into the mystery of time. [probably some weird dev board]
    this simulates ok for bank=0
    #CONFIG    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_OFF & _FCMEN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
    DEFINE OSC 32
    ANSELB = 0
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
    GPIOAdat    var byte
    GPIOBdat    var byte
    addr        var byte
    reg   var byte
    dat   var byte
    ; UNCOMMENT EITHER SECTION BANK=0 OR BANK=1     NOT BOTH
    ;START IOCON.BANK=0
    reg = 0
    dat = 0
    I2CWRITE PinSDA2,PinSCL2,addr,reg,[dat] 'set GPIOA all output
    reg = 1
    dat = 0
    I2CWRITE PinSDA2,PinSCL2,addr,reg,[dat] 'set GPIOB all output
    LOOOP:
        reg    = $12 : GPIOAdat    = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,reg,[GPIOAdat]
        reg    = $13      : GPIOBdat    = %00000000
        I2CWRITE PinSDA2,PinSCL2,addr,reg,[GPIOBdat]
        pause 250
        reg    = $12 : GPIOAdat    = %11111111
        reg    = $13 : GPIOBdat    = %11111111
        pause 250
        GOTO LOOOP
    end   ;IOCON.BANK=0
     ;START IOCON.BANK=1  ; NOT TESTED BANK=1 NOT SUPPORTED IN SIMULATOR
    'reg = $A
    'dat = %10100000
    'I2CWRITE PinSDA2,PinSCL2,addr,reg,[dat]
    'reg = 0
    'dat = 0
    'I2CWRITE PinSDA2,PinSCL2,addr,reg,[dat] 'set GPIOA all output
    'reg = $10
    'dat = 0
    'I2CWRITE PinSDA2,PinSCL2,addr,reg,[dat] 'set GPIOB all output
    'LOOOP:
    '    reg    = $9 : GPIOAdat    = %00000000
    '    I2CWRITE PinSDA2,PinSCL2,addr,reg,[GPIOAdat]
    '    reg    = $19      : GPIOBdat    = %00000000
    '    I2CWRITE PinSDA2,PinSCL2,addr,reg,[GPIOBdat]
    '    pause 250
    '    reg    = $9 : GPIOAdat    = %11111111
    '    reg    = $19 : GPIOBdat    = %11111111
    '    pause 250
    '    GOTO LOOOP
    'end     ;IOCON.BANK=1
    Argh, won't let me add a comment.
    Apparently I still hadn't understood how I'm supposed to set the register for IOCON.
    Latest attempt, still no workie.
    DEFINE OSC 32
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
        HPWM 3, 8, 1953
    IOCONAreg    var byte : IOCONAreg  = $0A        ' Bank=0
    IOCONBreg    var byte : IOCONBreg  = $0B        ' Bank=0
    'IOCONAreg    var byte : IOCONAreg  = $05        ' Bank=1
    'IOCONBreg    var byte : IOCONBreg  = $15        ' Bank=1
    '   bit 7   0 = The registers associated with each port are separated into different banks.
        I2CWRITE PinSDA2,PinSCL2,addr,IOCONAreg,[IOCONdat]
        I2CWRITE PinSDA2,PinSCL2,addr,IOCONBreg,[IOCONdat]
    LOOOP:
        pause 250
        pause 250
        GOTO LOOOP
    Aug 2011
    For the MCP23017 28-pin DIP package make sure you have connections to:
    RESETn (pin 18)
    A2, A1, A0 (pins 17, 16, 15) - these should be pulled low (GND) for address $40... they should not be left floating
    There should also be pullups to VDD on SCL (pin 12) and SDA (pin 13)
    RESETn (pin 18)
    Yup, reset, a0, a1 and a2 pulled down.
    I had sda and scl pulled up as in the datasheet, even tried 4K7 like is commonly used, nothing worked
    Streamlined code even more:
    DEFINE OSC 32
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
        HPWM 3, 8, 1953
    IOCONAreg    var byte
    IOCONBreg    var byte
    IODIRAreg    var byte
    IODIRBreg    var byte
    OLATAreg     var byte
    OLATBreg     var byte
    IOCONdat     var byte
    IODIRdat     var byte
    OLATdat      var byte
        if IOCONdat.7 = 0 then      ' Bank=0
            IOCONAreg  = $0A
            IOCONBreg  = $0B
            IODIRAreg  = $00
            IODIRBreg  = $01
            OLATAreg   = $14
            OLATBreg   = $15
        else                        ' Bank=1
            IOCONAreg  = $05
            IOCONBreg  = $15
            IODIRAreg  = $00
            IODIRBreg  = $10
            OLATAreg   = $0A
            OLATBreg   = $1A
    IODIRdat = %00000000                                   'set GPIO all output
        I2CWRITE PinSDA2,PinSCL2,addr,IODIRAreg,[IODIRdat]
        I2CWRITE PinSDA2,PinSCL2,addr,IODIRBreg,[IODIRdat]
    LOOOP:
        OLATdat    = %00000000                             ' LEDs ON
        I2CWRITE PinSDA2,PinSCL2,addr,OLATAreg,[OLATdat]
        I2CWRITE PinSDA2,PinSCL2,addr,OLATBreg,[OLATdat]
        pause 200
        OLATdat    = %11111111                             ' LEDs OFF
        pause 200
        GOTO LOOOP
    No longer need to mess with comments to change BANK setting. I just flip bit in IOCONdat and IF takes care of the rest.
    Quadruple checked everything, still no blinky blink.
    Changed to GPIO instead of LAT as per Dave's suggestion here:
    https://www.picbasic.co.uk/forum/sho...6693#post96693
    Also played with the syntax (register now part of the list of data).
    DEFINE OSC 32
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
        HPWM 3, 8, 1953
    IOCONAreg    var byte
    IOCONBreg    var byte
    IODIRAreg    var byte
    IODIRBreg    var byte
    GPIOAreg     var byte
    GPIOBreg     var byte
    IOCONdat     var byte
    IODIRdat     var byte
    GPIOdat      var byte
            IOCONAreg  = $0A
            IOCONBreg  = $0B
            IODIRAreg  = $00
            IODIRBreg  = $01
            GPIOAreg   = $12
            GPIOBreg   = $13
        else                        ' Bank=1
            IOCONAreg  = $05
            IOCONBreg  = $15
            IODIRAreg  = $00
            IODIRBreg  = $10
            GPIOAreg   = $09
            GPIOBreg   = $19
        I2CWRITE PinSDA2,PinSCL2,addr,[IOCONAreg,IOCONdat]
        I2CWRITE PinSDA2,PinSCL2,addr,[IODIRAreg,IODIRdat]
        I2CWRITE PinSDA2,PinSCL2,addr,[IOCONBreg,IOCONdat]
        I2CWRITE PinSDA2,PinSCL2,addr,[IODIRBreg,IODIRdat]
    LOOOP:
        GPIOdat    = %00000000                             ' LEDs ON
        I2CWRITE PinSDA2,PinSCL2,addr,[GPIOAreg,GPIOdat]
        I2CWRITE PinSDA2,PinSCL2,addr,[GPIOBreg,GPIOdat]
        pause 200
        GPIOdat    = %11111111                             ' LEDs OFF
        pause 200
        GOTO LOOOP
    Tried with both Bank settings, still no good.
    I'm quickly running out of crazy ideas.
    Logic Probe readings of SCL/SDA lines.
    DEFINE OSC 32
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    PinSCL2     VAR PortB.1
    PinSDA2     VAR PortB.2
        HPWM 3, 8, 1953
    IOCONAreg    var byte
    IOCONBreg    var byte
    IODIRAreg    var byte
    IODIRBreg    var byte
    GPIOAreg     var byte
    GPIOBreg     var byte
    IOCONdat     var byte
    IODIRdat     var byte
    GPIOdat      var byte
            IOCONAreg  = $0A
            IOCONBreg  = $0B
            IODIRAreg  = $00
            IODIRBreg  = $01
            GPIOAreg   = $12
            GPIOBreg   = $13
        else                        ' Bank=1
            IOCONAreg  = $05
            IOCONBreg  = $15
            IODIRAreg  = $00
            IODIRBreg  = $10
            GPIOAreg   = $09
            GPIOBreg   = $19
                           ' Image 1
        pause 50
                           ' Image 2
    LOOOP:                 ' Image 3
        GPIOdat    = %00000000                             ' LEDs OFF
        pause 200
                           ' Image 4
        GPIOdat    = %11111111                             ' LEDs ON
        pause 400
        GOTO LOOOP
    Image 1:
    Name:  I2C IOCONa.png
    Image 2:
    Name:  I2C IOCONb.png
    (next 2 images in next post)
    Weird how 2 statements generate 3 groups of pulses (I expected 1 to 1 ratio).
    Image 3:
    Name:  I2C LEDoff.png
    Image 4:
    Name:  I2C LEDon.png
    Aug 2011
    Typo? RESETn is a low-active input so it wants a pullup, not pulldown...
    The traces show you're getting a NAK to the first byte (chip address), so that needs to get fixed before anything else.
    ...RESETn is a low-active input so it wants a pullup...
    ...insert facepalm emote here...
    Who knows how long this thing has been working.
    Weeeeee!
  1. need help with PBP, I2C and MCP23017
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 20th May 2018, 01:01
  2. I2C two master on one I2C display
    By Kmt in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2014, 21:44
  3. I2C question w/ MCP23017 Port Expanders
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 26th December 2012, 06:47
  4. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 15:01
  5. I2C, little help please
    By gluphus in forum Serial
    Last Post: - 15th March 2006, 05:32
