Error when compiling with DT_INTS_3_4b"
Results 1 to 29 of 29
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Error when compiling with DT_INTS_3_4b"
    the IOC had the reset done in it prior, as i have had issues with that on the 27k40
    , but timer1, timer0,RX2 did not have any resets and were ok before they went to low priorty ISR
    Aug 2011
    That's odd... I don't see anything different about TMR0 or TMR1 in the file I have.
    There's no point in trying to clear RCxIF... that bit is read-only and will be set as long as there's a character in the receive FIFO. The only way to clear it is to read RCxREG.
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Error while compiling
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 20th April 2013, 17:01
  3. Replies: 1
    Last Post: - 30th March 2012, 04:13
  4. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 04:14
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
