Error when compiling with DT_INTS_3_4b"
Results 1 to 29 of 29
    Default Re: Error when compiling with DT_INTS_3_4b"
    Well Tumbleweed, I just couldn't wait to try it out. It all looks good. The only error I got when compiling was "undefined symbol":
    ; check to make sure program fits 26-5-2018
    #if $ > DEVICE_ROM
    error "program code exceeds flash size. change LOADER_SIZE_MIN"
    #endif
    I just commented them out and away we go....
    Once again, Thanks for the mod's.
    EN82fn
    Aug 2011
    That's odd... I don't get that.
    That size check is there to make sure the loader doesn't grow bigger than what's reserved (this one's a bit larger at 512 bytes vs 384).
    What version of mpasmx are you using? I was using 5.77
    It says, V5.778 in the toolchain. I did notice and have worked on trying to get the bootloader to work with usart2 with no success. I don't understand why?
    I have attached the modified version. Maybe if you can, take a look?
    EN82fn
    Aug 2011
    All of the control registers for UART1 are in the access bank so you can get away with not using banksel to get to them.
    UART2 registers are in a different bank (bank 14, 0x0E99-0x0E9F) so you have to load the BSR (ie BANKSEL RC2STA) to access them.
    You can still use UART1 but assign it to different pins with the PPS... that would be a lot easier (and smaller) than adding all the code to get at UART2.
    Tumbleweed, I think I will go the ( BANKSEL RC2STA) route because I use the uart1 for different communications to remote arrays. Thanks for the advice, I should have seen that. I am by no means an asm guru but I do know enough to get into trouble.....
    EN82fn
    Well, This has been a prosperous morning as I have the bootloader running on com2. For this project I need to bootload it over Bluetooth. Thanks so much Tumbleweed for the advice. I can see a whole new future with these K40's.... Thanks...
    EN82fn
  1. Replies: 0
    Last Post: - 14th November 2013, 04:32
  2. Error while compiling
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 20th April 2013, 18:01
  3. Replies: 1
    Last Post: - 30th March 2012, 05:13
  4. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 05:14
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
