Help with 24C01C and LCD
Results 1 to 3 of 3
    andyfive's Avatar
    andyfive Guest
    Unhappy Help with 24C01C and LCD
    Hello everyone. First off, I would like to thank everyone here for sharing their knowledge, and helping others.
    As for my problem:
    I'm trying to write ASCII values to a 24C01C eeprom, and then retreive them, and send them to an lcd. All I can seem to display is funny "y" characters, with dots above them.
    I've read my manual, and searched the internet, to no avail. Any help would be appreciated. P.S. Heres the code.
    'PIC 16F84, 24C01C
    define lcd_bits 4
    define lcd_dreg portb
    define lcd_dbit 4
    define lcd_rsreg porta
    define lcd_rsbit 0
    define lcd_ereg porta
    define lcd_ebit 1
    define lcd_lines 2
    define lcd_commandus 2000
    define lcd_dataus 50
    scl var porta.2
    sda var porta.3
    control con %10100000
    address var byte
    x var byte
    a var byte
    address = 0
    lcdout $fe, 1
    i2cwrite sda, scl, control, address, "A", "n", "d", "y"
    for a = 0 to 3
    i2cread sda, scl, control, a, x
    lcdout x
    next a
    first observation
    should be
    i2cwrite sda, scl, control, address, ["A", "n", "d", "y"]
    but i've never tried to use that way of writing ASCII character. I feel you must place them in an array before and then shoot the array
    something like
    MyArray var byte[4]
    MyArray[0]="A"
    MyArray[1]="n"
    MyArray[2]="d"
    MyArray[3]="y"
    i2cwrite sda, scl, control, address, [str MyArray\4]
    Use Bracket for I2Cread too... it's in the manual
    andyfive's Avatar
    andyfive Guest
    Post Thanks!
    Wow...Thanks. That fixed it! lol I think I should go through the manual a few more times...
