Nokia lcd include , small footprint to suit pic16's
Results 1 to 40 of 111
    Oct 2010
    Default Re: Nokia lcd include , small footprint to suit pic16's
    Hi dave,
    i solved it.
    i used the rbuf as var word
    Then i didnt add the commands for
    arraywrite rbuf,[dec speed1,dec2 speed2,0]
    i used the above command only to combine it with the following and present the number to the lcd.
    So the solutions for me is:
    checkt:
    RBUF = (SPEED1*100) + SPEED2
    IF RBUF > 5682 THEN ; THIS IS JUST AN EXAMPLE
    GOSUB LIMIT
    Thanks a lot for the help all of you.
    Oct 2010
    additional missing line from the previous message
    LCDSTR x,y, rbuf
    in any case the solution is to use the rbuf as word, multiply by 100 the speed1 and add speed2.
    i solved it.
    has not solved it at all , you cannot safely use arraywrite rbuf,[dec speed1,dec2 speed2,0] with a word var as the destination
    the destination for the text chrs generated by arraywrite m
    ust be an existing chr array big enough to contain the text generated plus a null terminator
    not doing so will lead to enormous problems
    secondy to expect the result of arraywrite to be usable as a number is absurd , its a textual chr string
    Oct 2010
    there is a missandestanding. my fault because i consfused you by using the same name for the variable SBUF and RBUF in the previous posts.
    vars.....
    SBUF var byte
    RBUF var word
    Program in the main loop includes the command:
    arraywrite SBUF, [dec speed1, dec2 speed2,0] ;
    then there is a checkSpeed LABEL
    checkSpeed:
    RBUF = (speed1*100) + speed2
    if RBUF > 5687 then; just an example
    gosub limit
    And that is what it works for me. It is under testing for a day now, and havent seen any strange behaviour.
    thanks.
    SBUF var byte
    sadly still woefully incorrect.
    that reserves 1 byte , you need at least 5 bytes
    Oct 2010
    Do you mean something like that?
    SBUF var BYTE[6]
    it is already configured.
    well done!
    you have proved yet again that code snippets are generally useless time wasters..
    this time with the nice added touch of posting snippets that bear no semblance to
    the code actually employed. a touch of genius . not
    don't know why i bother
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. 16F946 pcb footprint (64 tqfp)
    By nomad in forum Schematics
    Last Post: - 8th September 2009, 12:14
  3. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 21:37
  4. Nokia 3310 LCD
    By barkerben in forum General
    Last Post: - 10th December 2005, 20:08
  5. Small LCD module,character
    Last Post: - 27th November 2005, 19:13
