Nokia lcd include , small footprint to suit pic16's
Results 1 to 40 of 111
Threaded View
  1. #11
    Oct 2010
    Default Re: Nokia lcd include , small footprint to suit pic16's
    i have a question regarding the library and the code for the nokia 3310.
    for the following code:
    ARRAYWRITE speed [dec var1,dec2 var2,0]
    LCDSTR x,y, buff
    VAR1 is a byte and VAR2 is a byte as well. Those two numbers are presenting the Speed in format VAR1,VAR2 (where VAR1 can be any number from 0 to infinity, and VAR2 can be any number from 0 to 99)
    In case that the VAR1 gets the variable from 0 to =<255 the it can be used as a byte.
    My problem is that i need this floating number for ex. speed = 50,86 to get it as an integer speed = 5086. May i have your help please?
    If i set speed (VAR1 VAR2) as word then the following command
    LCDSTR x,y, speed
    does not accept word.
    Could you please help me to get the speed as an integer and read it as it is.
    For my program i'm testing:
    if speed is > 5086 then limit ; 50,86
    thanks once again.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. 16F946 pcb footprint (64 tqfp)
    By nomad in forum Schematics
    Last Post: - 8th September 2009, 11:14
  3. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 20:37
  4. Nokia 3310 LCD
    By barkerben in forum General
    Last Post: - 10th December 2005, 19:08
  5. Small LCD module,character
    Last Post: - 27th November 2005, 18:13
