Nokia lcd include , small footprint to suit pic16's
Results 1 to 40 of 111
    Default Re: Nokia lcd include , small footprint to suit pic16's
    doesn't the demo show that with the contrast and backlight stuff ?
    what have you tried ?
    Oct 2010
    I havent tried the demo. Just download the txt.
    As far as i understant it is using the command
    ARRAYWRITE BUFF [dec C,0]
    LCDSTR x,y, buff
    i tried and it worked.
    a = 1
    b = 2
    c = a+b
    have you read the pbp manual and understood the syntax for
    Output Modifiers for Formatting Strings using arraywrite ?
    its all there
    Oct 2010
    Hi Richard,
    my fault, yes i have read the arraywrite - arrayread command and corrected the code in my previous edited message.
    Many thanks.
    Oct 2010
    i have a question regarding the library and the code for the nokia 3310.
    for the following code:
    ARRAYWRITE speed [dec var1,dec2 var2,0]
    LCDSTR x,y, buff
    VAR1 is a byte and VAR2 is a byte as well. Those two numbers are presenting the Speed in format VAR1,VAR2 (where VAR1 can be any number from 0 to infinity, and VAR2 can be any number from 0 to 99)
    In case that the VAR1 gets the variable from 0 to =<255 the it can be used as a byte.
    My problem is that i need this floating number for ex. speed = 50,86 to get it as an integer speed = 5086. May i have your help please?
    If i set speed (VAR1 VAR2) as word then the following command
    LCDSTR x,y, speed
    does not accept word.
    Could you please help me to get the speed as an integer and read it as it is.
    For my program i'm testing:
    if speed is > 5086 then limit ; 50,86
    thanks once again.
    i will start here
    you do it exactly the same way as for a lcd display
    buff var byte[6] ; 4dig+dp+null
    speed var word
    ARRAYWRITE buff,[dec2 speed/100,".",dec2 speed//100 ,0]
    LCDSTR x,y, buff
    LCDSTR x,y, speed
    correct lcdstr str buffer var ,const str
    from the inc file
    USERCOMMAND "LCDC" ;X,Y,CHR 0 < X < 84 , 0 < Y < 7 , 31 < CHR > 127
    USERCOMMAND "LCDCLR" ;clear LCD
    USERCOMMAND "LCDSTR" ;STRING @ X,Y or Constant String
    USERCOMMAND "LCDCMD" ;cmd BYTE TO LCD
    USERCOMMAND "LCDDAT" ;DATA BYTE TO LCD
    i might preempt the next question
    leading zero's and right justifying fields
    http://support.melabs.com/forum/picb...strtok-usercmd
    Oct 2010
    im not in front of the circuit and computer in order to test it.
    i havent done it as it following /100 and //100 (remainder)
    buff var byte[6] ; 4dig+dp+nullspeed
    var word
    ARRAYWRITE buff,[dec2 speed/100,"."dec2 speed//100 ,0]
    LCDSTR x,y, buff
    I have used it with "." like the following in the loop and i get it right on the LCD as 50,86 for example. :
    I need on the screen the right "floating" value.
    ARRAYWRITE speed [dec var1,".",dec2 var2,0]
    LCDSTR x,y, speed
    then i send the code to sub label
    speedlimit:
    and i havent used "."
    i sent the command like:
    having that it was not possible to use speed as word.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. 16F946 pcb footprint (64 tqfp)
    By nomad in forum Schematics
    Last Post: - 8th September 2009, 12:14
  3. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 21:37
  4. Nokia 3310 LCD
    By barkerben in forum General
    Last Post: - 10th December 2005, 20:08
  5. Small LCD module,character
    Last Post: - 27th November 2005, 19:13
