Nokia lcd include , small footprint to suit pic16's
Results 1 to 40 of 111
    Default Re: Nokia lcd include , small footprint to suit pic16's
    turns out that testing the bit vars "inverted" and "bigtext" was not always working after the asm section in gcga subroutine .this only shows up when some vars are pushed out of bank 0 .I can not establish the failure mechanism ,seems i'm just guessing what "CHK?RP" AND "RST?RP" macros actually do . I can't find their definitions anywhere . making the vars into bytes and manually setting correct bank fix the issue.
    here is a more complex demo and an amended nokia include file to test and overcome this issue
    Jun 2005
    West Australia
    Hi Richard,
    I have compile errors with your new code, NB I've renamed them to NOKIA_DEMO#6 to avoid confusion with previous versions:
    [ERROR] nokia_demo#6.pbp (184) : Syntax error
    [ERROR] nokia_demo#6.pbp (195) : Syntax error
    [ERROR] nokia_demo#6.pbp (195) : Redefiniton of LABEL RJUSTBUFF
    which is:
        RJUSTBUFF  buff,4        ;http://support.melabs.com/forum/picbasic-pro-compiler-3-0-and-later/usercommand/983-strtok-usercmd
        RJUSTBUFF  buff,2   ;http://support.melabs.com/forum/picbasic-pro-compiler-3-0-and-later/usercommand/983-strtok-usercmd
    What have I missed?
    Bill
    What have I missed?
    you can't use my RJUSTBUFF user command unless you include the file that defines it .
    it can be found at the link in the comment ,its included with the strtok code
    http://support.melabs.com/forum/picb...strtok-usercmd
    Jun 2005
    West Australia
    Hi Richard,
    Excellent work, thank you. I found my problem - the "strtok.pbpmod" Inc file I used was the older version, somehow I missed the update further down the page on that link.
    All works well, now I need to get my head around how you've performed the magic and modify the code to suit my layout and various pages of information shown on the Nokia display.
    Once again many thanks for the help, you are indeed an asset to the forum.
    Cheers,
    Bill
    because I forgot to post it
    Aug 2005
    Michigan, USA
    Richard & gang... Just wanted to mention that my prototype board for the 5110 display works great and my "minimal" XC8 demo program ended up using 370 words of memory, including 240 words for the packed 5x7 font table.
    Also just got my little 128x32 SSD1306 I2C OLED display running with a 16F1823. Man, these OLED displays are really nice. A "bare bones" XC8 program + packed 5x7 font table uses 485 words of memory so a bit more 'overhead' for the low-level SSD1306 controller and I2C functions. However, the 2-pin interface more than makes up for the extra code (grin). Not sure how useful a 5x7 font will be on these little displays...
    Cheerful regards, Mike
Size:  536.6 KBName:  SSD1306 #1.jpg
    well done mike
    have you tried your code on a pic18 yet ?
    I have come unstuck , can't stop xc8 either overwriting my font , or saying it won't fit or just deciding not to include it at all .
    wasted days on this . there must be a how to use psect manual somewhere
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. 16F946 pcb footprint (64 tqfp)
    By nomad in forum Schematics
    Last Post: - 8th September 2009, 12:14
  3. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 21:37
  4. Nokia 3310 LCD
    By barkerben in forum General
    Last Post: - 10th December 2005, 20:08
  5. Small LCD module,character
    Last Post: - 27th November 2005, 19:13
