Hi Richard,
Thanks for the fix on the single char problem, it works well but I've found another problem...
When I add DT Ints the big characters don't work, I tried with and without using mssp but same result.
Also there's something strange taking place with the led backlight insomuch as I need to sprinkle port pin enable code immediately following any lcd write (with or without DT Ints). I tried changing LCD_LIGHT from A.0 to A.1 (while leaving it connected to A.0) with no difference - does the Inc file employ any commands for the light?
Here's the edited code:
Is the Inc file compatible with DT Ints?Code:#CONFIG ; 16F1847. __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _BOREN_OFF __config _CONFIG2, _PLLEN_OFF & _LVP_OFF #ENDCONFIG @ ERRORLEVEL -306 ; turn off crossing page boundary message ; --- *** Oscillator *** --------------------------------------------------- define OSC 32 OSCCON = %11110000 ; 32 MHz, ANSELA = 0 ; all digital ANSELB = 0 ; all digital TRISA=%00000000 'TRISB=%00000000 TRISB=%11101011 ; Encoder inputs on B5-7 ch var byte BUFF VAR BYTE [10] ;DEFINES FOR DISPLAY use font7x5_16.bas or font7x5_18.bas for pic18 #DEFINE PIC16 1 #define use_mssp 1 ; much faster and less words (1027 vs 1106). lcdheight con 5 ; 6 PAGES lcdwidth con 83 ; 84 PIXELS WIDE LCD_RST var LATA.4 LCD_DC var LATA.3 LCD_CE var LATA.6 LCD_LIGHT var LATA.0 LCD_CLK var LATB.4 ' SCK1 pin needs to be set as dig o/p LCD_DIN var LATB.2 ' SDO1 pin needs to be set as dig o/p ;--------------ONLY IF MSSP NOT USED--------------- ' LCD_CLK var Portb.4 ' Clock ' LCD_DIN var Portb.2 ' Data Include "Modedefs.bas" INCLUDE "DT_INTS-14.bas" ' Base Interrupt System INCLUDE "ReEnterPBP.bas" ' Include if using PBP type interrupts Include "nokia_ds.INC" ' bring it in include "font7x5_16.bas" 'include "font7x5_16 edit degC.BAS" ; use @ to access degC symbol. ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler IOC_INT, _Rot_Encoder, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE IOC_INT ; Port Change Interrupt '========================== MAIN Routine ============================== gosub lcd_init LCDCLR ARRAYWRITE BUFF,["READY",0] LCDSTR 5,0,BUFF PortA.0 = 0 ' turn on backlight. PAUSE 1000 LCDCLR PAUSE 1000 looper: LCDCLR PortA.0 = 0 ' turn on backlight. bigtxt = 1 ; double size chrs LCDSTR 0,0,"Noki+12" LCDSTR 0,2,"345678@" bigtxt = 0 ; normal size chrs ' LCDSTR 52,3,"Demo" ' LCDSTR 0,4,"With@MSSP xfer" LCDSTR 0,4,"Hi" PortA.0 = 0 ' turn on backlight. ' LCDSTR 0,5,"Dble Size Chrs" ' LCDSTR 0,5," " ; this doesn't compile - causes errors and warnings wherever used. LCDC 0,5,"a" ; use LCDC for single chars. PortA.0 = 0 ' turn on backlight. PAUSE 1000 GOTO looper Rot_Encoder: ' if PortB.7 = 0 then ' Check if Encoder pushbutton was pushed. ' ButtPush = 1 ' Set the flag for a quick exit. ' Old_Bits = New_Bits ' Equalize the disturbance the pushbutton caused. @ INT_RETURN ; Exit accordingly. ' endif END
Bill
