* Project: Nokia 5110 16F1823 Demo *
* Source: Nokia_5110_Packed_v2.c *
* Author: Mike McLaren, K8LH *
* (C)2013: Micro Application Consultants *
* Date: 23-May-2018 *
* Experimental Nokia 5110 LCD display driver demo using a 96 *
* character packed 2.5-word-per-character 5x7 font table. *
* IDE: MPLAB 8.92 (tabs = 4) *
* Lang: SourceBoost BoostC v7.30, Lite/Free version *
#include <system.h>
#pragma DATA _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _MCLRE_ON
#pragma DATA _CONFIG2, _PLLEN_OFF & _LVP_OFF
#pragma CLOCK_FREQ 8000000 // 8 MHz INTOSC
* function prototypes *
* typedef, defines, and macros *
#define rst porta.0 // RA0 = 5110 'reset'
#define dat porta.1 // RA1 = 5110 'din'
#define clk porta.2 // RA2 = 5110 'clk'
#define ce portc.0 // RC0 = 5110 'ce'
#define dc portc.1 // RC1 = 5110 'dc'
#define putlcd(x) asm movlw x \
asm call putwreg()
#define putcmd(x) dc = 0; \
asm movlw x \
asm call putwreg()
* variables & packed 2.5-word-per-character 5x7 font table/array *
#pragma DATA 1024,
0x0000, 0x0000, 0x0000, 0x005F, 0x0000, // 32 ' ' '!'
0x0007, 0x0007, 0x0014, 0x3F94, 0x3F94, // 34 '"' '#'
0x122A, 0x3FAA, 0x0923, 0x0988, 0x3262, // 36 '$' '%'
0x1B49, 0x2AA2, 0x2800, 0x0283, 0x0000, // 38 '&' '''
0x001C, 0x1141, 0x0000, 0x20A2, 0x0E00, // 40 '(' ')'
0x0A08, 0x1F08, 0x0A08, 0x043E, 0x0408, // 42 '*' '+'
0x0050, 0x1800, 0x0008, 0x0408, 0x0408, // 44 ',' '-'
0x0060, 0x3000, 0x0020, 0x0808, 0x0202, // 46 '.' '/'
0x1F51, 0x24C5, 0x1F00, 0x217F, 0x2000, // 48 '0' '1'
0x2161, 0x28C9, 0x2321, 0x20C5, 0x25B1, // 50 '2' '3'
0x0C14, 0x097F, 0x0827, 0x22C5, 0x22B9, // 52 '4' '5'
0x1E4A, 0x24C9, 0x1801, 0x3889, 0x0283, // 54 '6' '7'
0x1B49, 0x24C9, 0x1B06, 0x24C9, 0x149E, // 56 '8' '9'
0x0036, 0x1B00, 0x0000, 0x2B36, 0x0000, // 58 ':' ';'
0x0414, 0x1141, 0x0014, 0x0A14, 0x0A14, // 60 '<' '='
0x0041, 0x1114, 0x0402, 0x00D1, 0x0486, // 62 '>' '?'
0x1949, 0x3CC1, 0x1F7E, 0x0891, 0x08FE, // 64 '@' 'A'
0x3FC9, 0x24C9, 0x1B3E, 0x20C1, 0x20A2, // 66 'B' 'C'
0x3FC1, 0x20A2, 0x0E7F, 0x24C9, 0x24C1, // 68 'D' 'E'
0x3F89, 0x0489, 0x00BE, 0x20C9, 0x24FA, // 70 'F' 'G'
0x3F88, 0x0408, 0x3F80, 0x20FF, 0x2080, // 72 'H' 'I'
0x1040, 0x20BF, 0x00FF, 0x0414, 0x1141, // 74 'J' 'K'
0x3FC0, 0x2040, 0x207F, 0x010C, 0x017F, // 76 'L' 'M'
0x3F84, 0x0410, 0x3FBE, 0x20C1, 0x20BE, // 78 'N' 'O'
0x3F89, 0x0489, 0x033E, 0x20D1, 0x10DE, // 80 'P' 'Q'
0x3F89, 0x0CA9, 0x2346, 0x24C9, 0x24B1, // 82 'R' 'S'
0x0081, 0x3F81, 0x00BF, 0x2040, 0x203F, // 84 'T' 'U'
0x0FA0, 0x2020, 0x0FBF, 0x2038, 0x203F, // 86 'V' 'W'
0x3194, 0x0414, 0x3187, 0x0470, 0x0407, // 88 'X' 'Y'
0x30D1, 0x24C5, 0x2180, 0x3FC1, 0x2080, // 90 'Z' '['
0x0104, 0x0410, 0x1000, 0x20C1, 0x3F80, // 92 '\' ']'
0x0202, 0x0082, 0x0240, 0x2040, 0x2040, // 94 '^' '_'
0x0001, 0x0104, 0x0020, 0x2A54, 0x2A78, // 96 '`' 'a'
0x3FC8, 0x2244, 0x1C38, 0x2244, 0x2220, // 98 'b' 'c'
0x1C44, 0x2248, 0x3FB8, 0x2A54, 0x2A18, // 100 'd' 'e'
0x047E, 0x0481, 0x010C, 0x2952, 0x293E, // 102 'f' 'g'
0x3F88, 0x0204, 0x3C00, 0x227D, 0x2000, // 104 'h' 'i'
0x1040, 0x223D, 0x007F, 0x0828, 0x2200, // 106 'j' 'k'
0x0041, 0x3FC0, 0x007C, 0x0218, 0x0278, // 108 'l' 'm'
0x3E08, 0x0204, 0x3C38, 0x2244, 0x2238, // 110 'n' 'o'
0x3E14, 0x0A14, 0x0408, 0x0A14, 0x0C7C, // 112 'p' 'q'
0x3E08, 0x0204, 0x0448, 0x2A54, 0x2A20, // 114 'r' 's'
0x023F, 0x2240, 0x103C, 0x2040, 0x107C, // 116 't' 'u'
0x0E20, 0x2020, 0x0E3C, 0x2030, 0x203C, // 118 'v' 'w'
0x2228, 0x0828, 0x220C, 0x2850, 0x283C, // 120 'x' 'y'
0x2264, 0x2A4C, 0x2200, 0x0436, 0x2080, // 122 'z' '{'
0x0000, 0x3F80, 0x0000, 0x20B6, 0x0400, // 124 '|' '}'
0x0808, 0x0410, 0x0478, 0x2341, 0x2378 // 126 '~' ''
void putwreg() // send byte, msb first (15 words)
{ char work; //
asm movwf _work //
char n = 0; ce = 0; // spi enable on
do // send 8 bits
{ clk = 0; dat = 0; // "
if(work.7) dat = 1; // "
clk = 1; work <<= 1; // "
n++; // "
} while(n.3 == 0); // "
ce = 1; // spi enable off
void RdFlash() // bank 3 (inserted by compiler)
{ asm bcf _eecon1,CFGS // not 'config' memory |03
asm bsf _eecon1,EEPGD // select 'program' memory |03
asm bsf _eecon1,RD // initiate read operation |03
asm nop // required nop |03
asm nop // " |03
asm incf _eeadrl,F // bump EEADR |03
asm rlf _eedatl,W // move b7 into Carry |03
asm rlf _eedath,W // wreg = the 7 bit hi byte |03
asm bcf _eedatl,7 // eedatl = the 7 bit lo byte |03
void WrChar(char ascii) // for packed 2.5 word 5x7 font
{ dc = 1; // set lcd 'data' mode
asm movlw -32 // ascii 32..127 minus offset |00
asm addwf _ascii,F // font array index, 0..95 |00
asm lsrf _ascii,W // int(ascii *= 2.5) -> 0..237 |00
asm addwf _ascii,W // " |00
// asm movlb 3 // bank 3 (inserted by compiler) |03
asm movwf _eeadrl // flash address lo, 0..237 |03
asm movlw 1024/256 // table address hi |03
asm movwf _eeadrh // flash address hi |03
* Extract five bytes of pattern data from three memory words. *
* Odd characters use word 0 lo, 1 hi + lo, and 2 hi + lo while *
* even characters use word 0 hi + lo, 1 hi + lo, and 2 hi. A *
* sixth blank (zero) byte is sent for inter-character spacing. *
asm call RdFlash() // read 1st word |03
// asm movlb 0 // bank 0 (inserted by compiler) |00
asm btfss _ascii,0 // odd char? yes, skip, else |00
asm call putwreg() // send hi byte (even character) |00
// asm movlb 3 // bank 3 |03
asm movf _eedatl,W // |03
asm call putwreg() // send lo byte |00
asm call RdFlash() // read 2nd word |03
asm call putwreg() // send hi byte |00
asm call RdFlash() // read 3rd word |03
// asm movlb 0 // bank 0 |00
asm btfsc _ascii,0 // even char? yes, skip, else |00
asm call putwreg() // send lo byte (odd characters) |00
asm movlw 0 // |00
asm call putwreg() // send blank 6th column |00
void WrChar(rom char *data) // overload function for strings
{ char ndx = 0; //
while(data[ndx++]) // while not end-of-string
WrChar(wreg); //
* main setup *
void main()
{ ansela = 0; // adc off for digital I/O
anselc = 0; // "
trisa = 0; // porta all outputs except RA3/MCLR
trisc = 0; // portc all outputs
ce = 1; // 5110 'ce' off
rst = 1; // 5110 'rst' off
osccon = 0b01110000; // set INTOSC to 8 MHz
* initialize Nokia 5110 LCD display *
delay_ms(30); //
rst = 0; rst = 1; // 5110 'reset' pulse
putcmd(0x20+0x01); // function set: extended instructions
putcmd(0x80+0x30); // set Vop (contrast), 0..127
putcmd(0x04+0x02); // set temperature coefficient, 0..3
putcmd(0x10+0x03); // Set bias system, 0..7
putcmd(0x20+0x00); // function set: standard instructions
putcmd(0x08+0x04); // display control: normal mode
* test the LCD and the print string overload function. *
putcmd(0x80+0x20); // set DDRAM X address, 0..83
putcmd(0x40+0x02); // set DDRAM Y address, 0..5
WrChar('H'); // write ascii character
WrChar("ello"); // write ascii string
* main loop *
while(1) //
