Nokia lcd include , small footprint to suit pic16's
Page 1 of 3 123 LastLast
Results 1 to 40 of 111
    Default Nokia lcd include , small footprint to suit pic16's
    Entire demo is 872 words ,its less than 1/3 size of other attempts and has same features and a full alpha-numeric font
    Default Re: Nokia lcd include , small footprint to suit pic16's
    Amazing work Richard.
    5*
    Jun 2005
    West Australia
    Well done Richard, Ioannis almost got it right - put a star up against your name and let's call it 6*.
    Bill
    Aug 2005
    Michigan, USA
    I agree... nicely done, Richard. I can't tell you how much I enjoy studying and learning from your code.
    I was inspired by how you compressed a 96 character 5x7 font table down to something like 288 words and I spent most of the day implementing something similar on an old 5110 demo program written in C for a 16F1823. With just basic INIT, CMD, DAT, and STR functions, the program now uses less than 500 words of program memory. I'm pretty geeked about it! Thank you...
    Take care. Have fun. Cheerful regards, Mike
    if you really want to geek it up
    changing the output routine to use the mssp module shaves another 10% off the code size
    and speeds the thing up by a factor of 10x
    din and clk need to be on sdo and sck
    this
    PAUSEUS 150
    SHiftOUT LCD_DIN,LCD_CLK,1,[LcdData]
    becomes
    PIR1.3=0
    SSP1BUF = LcdData
    WHILE !PIR1.3 : wend
    and this is added to init routine
    SSP1CON1=$21 ;$22,21,20 all work @32mhz 20 is fastest
    SSP1STAT=$40
    Aug 2005
    Michigan, USA
    Yes, I already thought about using the SPI module. The current bit-bang driver uses 14 words of memory and runs at ~190-kb/s (with 8-MHz clock). An SPI driver and its init code shouldn't be any bigger. I hope to work on an SPI driver later today. I just need to refresh my memory on the SPI modes. Looks like you're using CKE = 1 and CKP = 0, yes?
    Name:  spi modes.png
    Implementing the 'packed' font table and extracting data was surprisingly simple, though I'm coding pretty close to the metal and the results are nothing as agile or elegant as your use of the 'readcode' function. Here's an excerpt, if you're interested;
       void RdFlash()               // bank 3 (inserted by compiler)
       { asm bcf     _eecon1,CFGS   // not 'config' memory            |03
         asm bsf     _eecon1,EEPGD  // select 'program' memory        |03
         asm bsf     _eecon1,RD     // initiate read operation        |03
         asm nop                    // required nop                   |03
         asm nop                    //  "                             |03
         asm incf    _eeadrl,F      // bump EEADR                     |03
         asm btfsc   _status,Z      //  "                             |03
         asm incf    _eeadrh,F      //  "                             |03
         asm rlf     _eedatl,W      // move b7 into Carry             |03
         asm rlf     _eedath,W      // wreg = the 7 bit hi byte       |03
         asm bcf     _eedatl,7      // eedatl = the 7 bit lo byte     |03
       void WrChar(char ascii)      // WrChar() for packed 5x7 font
       { asm movf    _ascii,W       // ascii char value, 32..127      |00
         asm addlw   -32            // minus table offset             |00
         asm movwf   _ascii         // font array index, 0..95        |00
      *  multiply index by 3 (0..95 -> 0..285), add table base address,   *
      *  and stuff the result in the EEADR register pair.                 *
         asm lslf    _wreg,W        // wreg = (ascii-32)*2            |00
         asm addwf   _ascii,W       // wreg = (ascii-32)*3            |00
      // asm movlb   3              // bank 3 (inserted by compiler)  |03
         asm movwf   _eeadrl        // flash address lo               |03
         asm movlw   1024/256       // table address hi               |03
         asm btfsc   _status,C      // overflow? no, skip, else       |03
         asm addlw   1              // bump value                     |03
         asm movwf   _eeadrh        // flash address hi               |03
      *  read 3 words (6 bytes) of font pattern data from the 5x7 font    *
      *  array and write them to the Nokia 5110 LCD.                      *
         for(char i=0; i<3; i++)    //
         { RdFlash();               // read one word (2 bytes)
           putlcd(wreg);            // send hi byte
           putlcd(eedatl);          // send lo byte
       void WrChar(rom char *data)  // overload function for strings
       { char ndx = 0;              //
         while(data[ndx++])         // while not end-of-string
           WrChar(wreg);            //
      *  initialize Nokia 5110 LCD display                                *
         delay_ms(30);              //
         rst = 0;                   // 5110 'reset' pulse
         rst = 1;                   //
         dc = 0;                    // command mode
         putlcd(0x20+0x01);         // function set: extended instructions
         putlcd(0x80+0x30);         // set Vop (contrast), 0..127
         putlcd(0x04+0x02);         // set temperature coefficient, 0..3
         putlcd(0x10+0x03);         // Set bias system, 0..7
         putlcd(0x20+0x00);         // function set: standard instructions
         putlcd(0x08+0x04);         // display control: normal mode
         putlcd(0x80+0x20);         // set DDRAM X address, 0..83
         putlcd(0x40+0x02);         // set DDRAM Y address, 0..5
         dc = 1;                    // data mode
         WrChar("Hello");           // test string overload function
    Thank you again for sharing your work. Mike
    Last edited by Mike, K8LH; - 18th May 2018 at 15:49. Reason: additional code excerpt
    Jun 2005
    West Australia
    Hi Richard,
    Just taking a quick look at your Include demo and I can only write 13 characters per line successfully... if 14 then the result is a wrap around and overwriting of the first char. Example below:
    looper:
        LCDCLR
    ;    LCDSTR  6,0,"-Nokia-Demo-"      ; Line 0, position 6.
        LCDSTR  0,0,"I wonder what happens if the string is large?"  ; = Rubbish on first line and "missing quote" error message.
    ;    LCDSTR  0,0,"I wonder what?"    ; = "? wonder what" [14 chars]
        LCDSTR  0,0,"I wonder what"     ; = "I wonder what" [13 chars only]
        LCDC   0,4,"'"                  ; Line 4, position 0.
        LCDC   25,5,"8"                ; Line 5, position 25.
        PAUSE 1000
        GOTO looper
    I'll test more later today and let you know if I find anything else needing a tweak. Again, great job.
    Bill
    yes probably, but here is a new version with double size chr capability and mssp and font unpacking in asm [like in my ks0108 code]
    its not been texted on a pic18 , but its blisteringly fast on the 16f1847, and will fill screen fully
    thanks go to blll [wjsmarine] for donation of hardware for this project, enjoy
    Jun 2005
    West Australia
    That's impressive, Richard.
    Can you explain how your font table works and how you derived those values in each column please? What limits the size of the table one can create?
    I'd like to learn from it and maybe if I can get my head around the process find a way to smooth out the double size characters (particularly 0-9, the degree symbol and C) - I'm guessing you are working your magic to achieve double size by math so it probably means making a larger table to accommodate these.
    An indication of smooth characters is shown in the pic attached, made with the previous lookup table style, which consumed 4 normal sized chars' area per big one and 2 lines (as does yours) and also noting the degree C was formed as one big character. Apologies for the blurry image, not helped with the scratchy plastic over the LCD to protect the glass...
    Thanks for your patience and help.
    Bill
    I replace the _ chr with @ dw 642 , 9266 ,72 in my fonts to get a deg C chr
    correct , I know of no realistic way to smooth the result , it has been tried.
    table size is only limited by the memory available.
    if you create a large font say 14x10 for digits it would not be an unreasonable size, but would need its own routines to unpack and display
    if you plot my font on graph paper its pretty obvious how it works, the pic 18 version is easier to disassemble
    some 8x8 graphpaper
    AND an old spread sheet that did the number crunching
    Aug 2005
    Michigan, USA
    I used a spreadsheet to convert my old 5 byte per character tables, too. Works a treat...
    Name:  5x7 Font Packer-Editor-Viewer.png
    I came up with the same solution , the freely available font creators [like the mikronta one] don't really
    convert the font to the most efficient format for pic's when codespace is an issue.
    although they can be a good starting point
    Aug 2005
    Michigan, USA
    Nice job on the spreadsheet, Richard. I just finished modifying mine to format the packed font table output for either C or asm. Here's a sample;
    	0x0000,	0x0000,	0x0000,	//  32	 ' '
    	0x0000,	0x2F80,	0x0000,	//  33	 '!'
    	0x0007,	0x0007,	0x0000,	//  34	 '"'
    	0x0A7F,	0x0A7F,	0x0A00,	//  35	 '#'
    	0x122A,	0x3FAA,	0x0900,	//  36	 '$'
    	0x1193,	0x0464,	0x3100,	//  37	 '%'
    	0x1B49,	0x2AA2,	0x2800,	//  38	 '&'
    	0x0005,	0x0180,	0x0000,	//  39	 '''
    	0x001C,	0x1141,	0x0000,	//  40	 '('
    	0x0041,	0x111C,	0x0000,	//  41	 ')'
    	0x0A08,	0x1F08,	0x0A00,	//  42	 '*'
    	0x0408,	0x1F08,	0x0400,	//  43	 '+'
         dw	0x0000,	0x0000,	0x0000	;  32	 ' '
         dw	0x0000,	0x2F80,	0x0000	;  33	 '!'
         dw	0x0007,	0x0007,	0x0000	;  34	 '"'
         dw	0x0A7F,	0x0A7F,	0x0A00	;  35	 '#'
         dw	0x122A,	0x3FAA,	0x0900	;  36	 '$'
         dw	0x1193,	0x0464,	0x3100	;  37	 '%'
         dw	0x1B49,	0x2AA2,	0x2800	;  38	 '&'
         dw	0x0005,	0x0180,	0x0000	;  39	 '''
         dw	0x001C,	0x1141,	0x0000	;  40	 '('
         dw	0x0041,	0x111C,	0x0000	;  41	 ')'
         dw	0x0A08,	0x1F08,	0x0A00	;  42	 '*'
         dw	0x0408,	0x1F08,	0x0400	;  43	 '+'
    I also decided to render all 96 characters directly from the input table so that I can see at-a-glance which characters might need tweaking...
    Name:  5x7 Font Packer #2.png
    Aug 2005
    Michigan, USA
    Just finished the font render part of my spreadsheet. It renders directly from the unpacked 5-byte 'input' table. Change a byte in there and you'll see the changes immediately. Mind if I show it off, guys (see below)?
    Cheerful regards, Mike, K8LH
    Name:  Font 5x7 #1 50%.png
    Aug 2005
    Michigan, USA
    Richard... Would you be interested in seeing my driver code for font tables with 2.5 word-per-character packing instead of 3 word-per-character packing? The new '2.5' font tables use 240 words of memory (down from 288 words) and my little single file ~225 line (non-PBP) demo program now weighs in at ~406 words total memory...
    yes please, I had considered doing that but could not find a method that preserved the gain
    my attempts used half the saved space up doing the unpacking
    Aug 2005
    Michigan, USA
    First, here's how I'm packing font pattern data into 2-1/2 words within groups of 5 words;
    Name:  font pack 25.png
    In the first part of my WrChar() routine I calculate the table address by first subtracting the font table offset (32) from the ASCII character value (32..127). Then I multiply the resulting font table index (0..95) by 2.5 and add the integer result (0..237) to the font table base address. In my case, I'm using a fixed 0x0400 address for the font table so I don't need to perform the addition. I simply stuff the 0..237 value directly into EEADRL and the hi byte of the font table address into EEADRH.
    In the other half of my WrChar() routine, if the font table index is even I print the 1st word hi & lo bytes, the 2nd word hi & lo bytes, and the 3rd word hi byte. If the font table index is odd I print the 1st word lo byte, the 2nd word hi & lo bytes, and the 3rd word hi & lo bytes. You'll notice the logic is relatively simple and unrolling the print loop to accommodate the logic doesn't seem to have incurred additional program overhead.
    The new demo program (attached below) is 50 words smaller than the old (3-word-per-character) program (406 words total) so it seems I've realized the full 48 word savings from the new packed font table format.
    I hope this example provides some useful ideas and I'm sorry I can't help with PBP...
    Have fun... Cheerful regards, Mike
       *  Project: Nokia 5110 16F1823 Demo                                *
       *   Source: Nokia_5110_Packed_v2.c                                 *
       *   Author: Mike McLaren, K8LH                                     *
       *  (C)2013: Micro Application Consultants                          *
       *     Date: 23-May-2018                                            *
       *   Experimental Nokia 5110 LCD display driver demo using a 96     *
       *   character packed 2.5-word-per-character 5x7 font table.        *
       *      IDE: MPLAB 8.92 (tabs = 4)                                  *
       *     Lang: SourceBoost BoostC v7.30, Lite/Free version            *
       #include <system.h>
       #pragma DATA _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _MCLRE_ON
       #pragma DATA _CONFIG2, _PLLEN_OFF & _LVP_OFF
       #pragma CLOCK_FREQ 8000000       // 8 MHz INTOSC
       *  function prototypes                                             *
       *  typedef, defines, and macros                                    *
       #define rst porta.0          // RA0 = 5110 'reset'
       #define dat porta.1          // RA1 = 5110 'din'
       #define clk porta.2          // RA2 = 5110 'clk'
       #define ce  portc.0          // RC0 = 5110 'ce'
       #define dc  portc.1          // RC1 = 5110 'dc'
       #define putlcd(x)  asm movlw x      \
                          asm call putwreg()
       #define putcmd(x)  dc = 0;          \
                          asm movlw x      \
                          asm call putwreg()
       *  variables & packed 2.5-word-per-character 5x7 font table/array  *
       #pragma DATA 1024,
         0x0000, 0x0000, 0x0000, 0x005F, 0x0000,    //  32 ' '  '!'
         0x0007, 0x0007, 0x0014, 0x3F94, 0x3F94,    //  34 '"'  '#'
         0x122A, 0x3FAA, 0x0923, 0x0988, 0x3262,    //  36 '$'  '%'
         0x1B49, 0x2AA2, 0x2800, 0x0283, 0x0000,    //  38 '&'  '''
         0x001C, 0x1141, 0x0000, 0x20A2, 0x0E00,    //  40 '('  ')'
         0x0A08, 0x1F08, 0x0A08, 0x043E, 0x0408,    //  42 '*'  '+'
         0x0050, 0x1800, 0x0008, 0x0408, 0x0408,    //  44 ','  '-'
         0x0060, 0x3000, 0x0020, 0x0808, 0x0202,    //  46 '.'  '/'
         0x1F51, 0x24C5, 0x1F00, 0x217F, 0x2000,    //  48 '0'  '1'
         0x2161, 0x28C9, 0x2321, 0x20C5, 0x25B1,    //  50 '2'  '3'
         0x0C14, 0x097F, 0x0827, 0x22C5, 0x22B9,    //  52 '4'  '5'
         0x1E4A, 0x24C9, 0x1801, 0x3889, 0x0283,    //  54 '6'  '7'
         0x1B49, 0x24C9, 0x1B06, 0x24C9, 0x149E,    //  56 '8'  '9'
         0x0036, 0x1B00, 0x0000, 0x2B36, 0x0000,    //  58 ':'  ';'
         0x0414, 0x1141, 0x0014, 0x0A14, 0x0A14,    //  60 '<'  '='
         0x0041, 0x1114, 0x0402, 0x00D1, 0x0486,    //  62 '>'  '?'
         0x1949, 0x3CC1, 0x1F7E, 0x0891, 0x08FE,    //  64 '@'  'A'
         0x3FC9, 0x24C9, 0x1B3E, 0x20C1, 0x20A2,    //  66 'B'  'C'
         0x3FC1, 0x20A2, 0x0E7F, 0x24C9, 0x24C1,    //  68 'D'  'E'
         0x3F89, 0x0489, 0x00BE, 0x20C9, 0x24FA,    //  70 'F'  'G'
         0x3F88, 0x0408, 0x3F80, 0x20FF, 0x2080,    //  72 'H'  'I'
         0x1040, 0x20BF, 0x00FF, 0x0414, 0x1141,    //  74 'J'  'K'
         0x3FC0, 0x2040, 0x207F, 0x010C, 0x017F,    //  76 'L'  'M'
         0x3F84, 0x0410, 0x3FBE, 0x20C1, 0x20BE,    //  78 'N'  'O'
         0x3F89, 0x0489, 0x033E, 0x20D1, 0x10DE,    //  80 'P'  'Q'
         0x3F89, 0x0CA9, 0x2346, 0x24C9, 0x24B1,    //  82 'R'  'S'
         0x0081, 0x3F81, 0x00BF, 0x2040, 0x203F,    //  84 'T'  'U'
         0x0FA0, 0x2020, 0x0FBF, 0x2038, 0x203F,    //  86 'V'  'W'
         0x3194, 0x0414, 0x3187, 0x0470, 0x0407,    //  88 'X'  'Y'
         0x30D1, 0x24C5, 0x2180, 0x3FC1, 0x2080,    //  90 'Z'  '['
         0x0104, 0x0410, 0x1000, 0x20C1, 0x3F80,    //  92 '\'  ']'
         0x0202, 0x0082, 0x0240, 0x2040, 0x2040,    //  94 '^'  '_'
         0x0001, 0x0104, 0x0020, 0x2A54, 0x2A78,    //  96 '`'  'a'
         0x3FC8, 0x2244, 0x1C38, 0x2244, 0x2220,    //  98 'b'  'c'
         0x1C44, 0x2248, 0x3FB8, 0x2A54, 0x2A18,    // 100 'd'  'e'
         0x047E, 0x0481, 0x010C, 0x2952, 0x293E,    // 102 'f'  'g'
         0x3F88, 0x0204, 0x3C00, 0x227D, 0x2000,    // 104 'h'  'i'
         0x1040, 0x223D, 0x007F, 0x0828, 0x2200,    // 106 'j'  'k'
         0x0041, 0x3FC0, 0x007C, 0x0218, 0x0278,    // 108 'l'  'm'
         0x3E08, 0x0204, 0x3C38, 0x2244, 0x2238,    // 110 'n'  'o'
         0x3E14, 0x0A14, 0x0408, 0x0A14, 0x0C7C,    // 112 'p'  'q'
         0x3E08, 0x0204, 0x0448, 0x2A54, 0x2A20,    // 114 'r'  's'
         0x023F, 0x2240, 0x103C, 0x2040, 0x107C,    // 116 't'  'u'
         0x0E20, 0x2020, 0x0E3C, 0x2030, 0x203C,    // 118 'v'  'w'
         0x2228, 0x0828, 0x220C, 0x2850, 0x283C,    // 120 'x'  'y'
         0x2264, 0x2A4C, 0x2200, 0x0436, 0x2080,    // 122 'z'  '{'
         0x0000, 0x3F80, 0x0000, 0x20B6, 0x0400,    // 124 '|'  '}'
         0x0808, 0x0410, 0x0478, 0x2341, 0x2378     // 126 '~'  ''
       void putwreg()               // send byte, msb first (15 words)
       { char work;                 //
         asm movwf   _work          //
         char n = 0; ce = 0;        // spi enable on
         do                         // send 8 bits
         { clk = 0; dat = 0;        //  "
           if(work.7) dat = 1;      //  "
           clk = 1; work <<= 1;     //  "
           n++;                     //  "
         } while(n.3 == 0);         //  "
         ce = 1;                    // spi enable off
         asm nop                    //  "                             |03
       void WrChar(char ascii)      // for packed 2.5 word 5x7 font
       { dc = 1;                    // set lcd 'data' mode
         asm movlw   -32            // ascii 32..127 minus offset     |00
         asm addwf   _ascii,F       // font array index, 0..95        |00
         asm lsrf    _ascii,W       // int(ascii *= 2.5) -> 0..237    |00
         asm addwf   _ascii,W       //  "                             |00
         asm movwf   _eeadrl        // flash address lo, 0..237       |03
      *  Extract five bytes of pattern data from three memory words.      *
      *  Odd characters use word 0 lo, 1 hi + lo, and 2 hi + lo while     *
      *  even characters use word 0 hi + lo, 1 hi + lo, and 2 hi.  A      *
      *  sixth blank (zero) byte is sent for inter-character spacing.     *
         asm call    RdFlash()      // read 1st word                  |03
      // asm movlb   0              // bank 0 (inserted by compiler)  |00
         asm btfss   _ascii,0       // odd char? yes, skip, else      |00
         asm call    putwreg()      // send hi byte (even character)  |00
      // asm movlb   3              // bank 3                         |03
         asm movf    _eedatl,W      //                                |03
         asm call    putwreg()      // send lo byte                   |00
         asm call    RdFlash()      // read 2nd word                  |03
         asm call    putwreg()      // send hi byte                   |00
         asm call    RdFlash()      // read 3rd word                  |03
      // asm movlb   0              // bank 0                         |00
         asm btfsc   _ascii,0       // even char? yes, skip, else     |00
         asm call    putwreg()      // send lo byte (odd characters)  |00
         asm movlw   0              //                                |00
         asm call    putwreg()      // send blank 6th column          |00
       { char ndx = 0;              //
           WrChar(wreg);            //
       *  main setup                                                      *
       void main()
       { ansela = 0;                // adc off for digital I/O
         anselc = 0;                //  "
         trisa = 0;                 // porta all outputs except RA3/MCLR
         trisc = 0;                 // portc all outputs
         ce = 1;                    // 5110 'ce' off
         rst = 1;                   // 5110 'rst' off
         osccon = 0b01110000;       // set INTOSC to 8 MHz
         delay_ms(30);              //
         rst = 0; rst = 1;          // 5110 'reset' pulse
         putcmd(0x20+0x01);         // function set: extended instructions
         putcmd(0x80+0x30);         // set Vop (contrast), 0..127
         putcmd(0x04+0x02);         // set temperature coefficient, 0..3
         putcmd(0x10+0x03);         // Set bias system, 0..7
         putcmd(0x20+0x00);         // function set: standard instructions
         putcmd(0x08+0x04);         // display control: normal mode
      *  test the LCD and the print string overload function.             *
         putcmd(0x80+0x20);         // set DDRAM X address, 0..83
         putcmd(0x40+0x02);         // set DDRAM Y address, 0..5
         WrChar('H');               // write ascii character
         WrChar("ello");            // write ascii string
       *  main loop                                                       *
         while(1)                   //
    thanks mike , the concept works nicely
    xc8 version (393)+240 words , uses mssp1
    #include "mcc_generated_files/mcc.h"
    #include "FONT.c"
    void putwreg(char work);
    void putcmd(char x);
    void WrChar(char ascii);
    void WrStr(char *);
    void main(void) {
        // initialize the device
        SYSTEM_Initialize();
        __delay_ms(30); //
        LCD_RST_SetLow(); // 5110 'reset' pulse
        __delay_ms(1);
        LCD_RST_SetHigh(); // 5110 'reset' pulse
        __delay_ms(1);
        putcmd(0x20 + 0x01); // function set: extended instructions
        putcmd(0xc8);        // set Vop (contrast), 0..127
        putcmd(0x04 + 0x02); // set temperature coefficient, 0..3
        putcmd(0x10 + 0x03); // Set bias system, 0..7
        putcmd(0x20 + 0x00); // function set: standard instructions
        putcmd(0x08 + 0x04); // display control: normal mode
        putcmd(0x80 + 0x20); // set DDRAM X address, 0..83
        putcmd(0x40 + 0x02); // set DDRAM Y address, 0..5
        WrChar('R'); // write ascii character
        WrStr("eady");
        while (1) {
     End of File
    void putwreg(char work) // send byte, msb first (15 words)
        LCD_CE_LAT = 0; // spi enable on
        SPI1_Exchange8bit(work);
        while (!PIR1bits.SSP1IF);
        LCD_CE_LAT = 1; // spi enable off
        unsigned int dat, inx = 0x1f00;
        char i = 5;
        // char fd[6],i=5,*pt;
        //pt=fd;
        inx += ((ascii - 32)*5) >> 1;
        dat = FLASH_ReadWord(inx++);
        if (!(ascii & 1))putwreg(dat >> 7); //  *pt++=dat>>7;
        putwreg(dat & 0x7f);
        //*pt++ =(char)dat&0x7f;
        putwreg(dat >> 7);
        //*pt++=dat>>7;
        //*pt++=(char)dat&0x7f;
        dat = FLASH_ReadWord(inx);
        //*pt++=dat>>7;
        putwreg(dat >> 7);
        if (ascii & 1) putwreg(dat & 0x7f); //*pt++=(char)dat&0x7f;
        //pt=fd;
        // while(i--){
        //    putwreg(*pt++);
        putwreg(0);
    void putcmd(char x) {
        LCD_DC_SetLow();
        putwreg(x);
        LCD_DC_SetHigh();
    void WrStr(char *buff) {
            while (*buff) // while not end-of-string
                WrChar(*buff++); //
    font
    #include <xc.h>
    #asm
    PSECT strings,class=CODE,abs,delta=2
    ORG 0x1f00
    DW    0x0000, 0x0000, 0x0000, 0x005F, 0x0000    //  32 ' '  '!'
    DW    0x0007, 0x0007, 0x0014, 0x3F94, 0x3F94    //  34 '"'  '#'
    DW    0x122A, 0x3FAA, 0x0923, 0x0988, 0x3262    //  36 '$'  '%'
    DW    0x1B49, 0x2AA2, 0x2800, 0x0283, 0x0000    //  38 '&'  '''
    DW    0x001C, 0x1141, 0x0000, 0x20A2, 0x0E00    //  40 '('  ')'
    DW    0x0A08, 0x1F08, 0x0A08, 0x043E, 0x0408    //  42 '*'  '+'
    DW    0x0050, 0x1800, 0x0008, 0x0408, 0x0408    //  44 ','  '-'
    DW    0x0060, 0x3000, 0x0020, 0x0808, 0x0202    //  46 '.'  '/'
    DW    0x1F51, 0x24C5, 0x1F00, 0x217F, 0x2000    //  48 '0'  '1'
    DW    0x2161, 0x28C9, 0x2321, 0x20C5, 0x25B1    //  50 '2'  '3'
    DW    0x0C14, 0x097F, 0x0827, 0x22C5, 0x22B9    //  52 '4'  '5'
    DW    0x1E4A, 0x24C9, 0x1801, 0x3889, 0x0283    //  54 '6'  '7'
    DW    0x1B49, 0x24C9, 0x1B06, 0x24C9, 0x149E    //  56 '8'  '9'
    DW    0x0036, 0x1B00, 0x0000, 0x2B36, 0x0000    //  58 ':'  ';'
    DW    0x0414, 0x1141, 0x0014, 0x0A14, 0x0A14    //  60 '<'  '='
    DW    0x0041, 0x1114, 0x0402, 0x00D1, 0x0486    //  62 '>'  '?'
    DW    0x1949, 0x3CC1, 0x1F7E, 0x0891, 0x08FE    //  64 '@'  'A'
    DW    0x3FC9, 0x24C9, 0x1B3E, 0x20C1, 0x20A2    //  66 'B'  'C'
    DW    0x3FC1, 0x20A2, 0x0E7F, 0x24C9, 0x24C1    //  68 'D'  'E'
    DW    0x3F89, 0x0489, 0x00BE, 0x20C9, 0x24FA    //  70 'F'  'G'
    DW    0x3F88, 0x0408, 0x3F80, 0x20FF, 0x2080    //  72 'H'  'I'
    DW    0x1040, 0x20BF, 0x00FF, 0x0414, 0x1141    //  74 'J'  'K'
    DW    0x3FC0, 0x2040, 0x207F, 0x010C, 0x017F    //  76 'L'  'M'
    DW    0x3F84, 0x0410, 0x3FBE, 0x20C1, 0x20BE    //  78 'N'  'O'
    DW    0x3F89, 0x0489, 0x033E, 0x20D1, 0x10DE    //  80 'P'  'Q'
    DW    0x3F89, 0x0CA9, 0x2346, 0x24C9, 0x24B1    //  82 'R'  'S'
    DW    0x0081, 0x3F81, 0x00BF, 0x2040, 0x203F    //  84 'T'  'U'
    DW    0x0FA0, 0x2020, 0x0FBF, 0x2038, 0x203F    //  86 'V'  'W'
    DW    0x3194, 0x0414, 0x3187, 0x0470, 0x0407    //  88 'X'  'Y'
    DW    0x30D1, 0x24C5, 0x2180, 0x3FC1, 0x2080    //  90 'Z'  '['
    DW    0x0104, 0x0410, 0x1000, 0x20C1, 0x3F80    //  92 '\'  ']'
    DW    0x0202, 0x0082, 0x0240, 0x2040, 0x2040    //  94 '^'  '_'
    DW    0x0001, 0x0104, 0x0020, 0x2A54, 0x2A78    //  96 '`'  'a'
    DW    0x3FC8, 0x2244, 0x1C38, 0x2244, 0x2220    //  98 'b'  'c'
    DW    0x1C44, 0x2248, 0x3FB8, 0x2A54, 0x2A18    // 100 'd'  'e'
    DW    0x047E, 0x0481, 0x010C, 0x2952, 0x293E    // 102 'f'  'g'
    DW    0x3F88, 0x0204, 0x3C00, 0x227D, 0x2000    // 104 'h'  'i'
    DW    0x1040, 0x223D, 0x007F, 0x0828, 0x2200    // 106 'j'  'k'
    DW    0x0041, 0x3FC0, 0x007C, 0x0218, 0x0278    // 108 'l'  'm'
    DW    0x3E08, 0x0204, 0x3C38, 0x2244, 0x2238    // 110 'n'  'o'
    DW    0x3E14, 0x0A14, 0x0408, 0x0A14, 0x0C7C    // 112 'p'  'q'
    DW    0x3E08, 0x0204, 0x0448, 0x2A54, 0x2A20    // 114 'r'  's'
    DW    0x023F, 0x2240, 0x103C, 0x2040, 0x107C    // 116 't'  'u'
    DW    0x0E20, 0x2020, 0x0E3C, 0x2030, 0x203C    // 118 'v'  'w'
    DW    0x2228, 0x0828, 0x220C, 0x2850, 0x283C    // 120 'x'  'y'
    DW    0x2264, 0x2A4C, 0x2200, 0x0436, 0x2080    // 122 'z'  '{'
    DW    0x0000, 0x3F80, 0x0000, 0x20B6, 0x0400    // 124 '|'  '}'
    DW    0x0808, 0x0410, 0x0478, 0x2341, 0x2378    // 126 '~'  ''
    #endasm
    Aug 2005
    Michigan, USA
    Nice to see an XC8 example excerpt...
    May I ask where I can find information for placing DW data in XC8 at an absolute address, please? I haven't found it so far, nor can I get your example working in a 16F1823 XC8 project...
    I'm also struggling with MCC (Microsoft Code Configurator)...
    all my knowledge came from google" xc8 psect" , i have not found a good reference yet
    the xc8 use rguide/manual is severely lacking in that respect
    key elements
    ORG 0x1f00
    my example uses an asm segment in a c include file, it may be better to place the data in an asm file and include that instead
    because i have terrible trouble getting "labels" to work properly my way. [ still learning]
    mcc is a splendid thing once you get the hang of it, for the chips it supports.
    once i have created the standalone project i use mcc to set the osc and create the main.c and mcc files
    then you can add the pins/hw modules
    a saner way is, and let the linker locate the font for you
    font .c file
    #include <xc.h>
    #asm
    psect FONT_table,class=CODE,local,delta=2
      GLOBAL _FNT
    _FNT
    in main.c
    extern const char FNT;
    int addr=&FNT;
    in wrChar()
    unsigned int dat, inx = addr;
    char i = 5;
    Jun 2005
    West Australia
    Hi Richard,
    Well done to you and Mike for continuing the thread, even though what you are documenting is so far above my head I'm dizzy...
    If I can jump in here I'd like to bring your attention to an undocumented feature of your Inc file I've just discovered when converting my previous code to run it. For various reasons, but mainly leading zero suppression, I insert a space but with your Inc file I get error messages e.g.
    looper:
        LCDCLR
        bigtxt = 1     ; double size chrs
        LCDSTR 0,0,"Noki+12"
        LCDSTR 0,2,"345678@"
        bigtxt = 0     ; normal size chrs
    '    LCDSTR 52,3,"Demo"
        LCDSTR 0,4,"With@MSSP xfer"
    '    LCDSTR 0,5,"Dble Size Chrs"
        LCDSTR 0,5," "  ; this doesn't compile - causes errors and warnings wherever used.
    '    LCDSTR 0,5,32   ; same result as above (worth a try).
        PAUSE 1000
        GOTO looper
    resulting in
    [ASM ERROR] NOKIA_DEMO PPS.ASM (1701) : Illegal character (0)
    [ASM WARNING] NOKIA_DEMO PPS.ASM (1701) : Found label after column 1. (LCDSTR?CCC)
    When you have the time may I ask for this to be corrected?
    Kind regards,
    Bill
    LCDSTR 0,5," "
    its a pbp problem
    " " is not a String pbp interprets a single chr as a byte , regardless of the quotes . and its not possible to fix it
    you can simply use
    LCDC " "
    or
    LCDC 0,5," "
    to print a single character
    have a look at this
    http://support.melabs.com/forum/picb...strtok-usercmd
    it has a rightjustify user command in it,
    eg to display a 3 digit field
     arraywrite buff,[dec h,0]
        RJUSTBUFF  buff,3
        LCDSTR  36,0,BUFF
    Aug 2005
    Michigan, USA
    Ah... Thank you for the PSECT search term. Got it. I also discovered that I could use a label in the font table and access that address in my code... Very exciting stuff (grin)...
    I still need to double-check and simulate my XC8 version but so far it uses 381 words (141 code + 240 font). I didn't use MCC (Microchip Code Configurator) so it's a single file, about 235 lines, including the font table (see below).
    MCC doesn't seem to support the MSSP module on my 16F1823 so I still need to consult the datasheet before I can implement the SPI driver.
     *  Project: Nokia_Fonts                                                *
     *   Source: Nokia_Main.c                                               *
     *     Date: 25-May-2018                                                *
     *   character packed 2.5-word-per-character 5x7 font table on a        *
     *   PIC16F1823.                                                        *
     *      IDE: MPLABX v4.05                                               *
     *     Lang: XC8 v1.45, Lite/Free version                               *
    /* CONFIG1 */
      #pragma config FOSC = INTOSC  // INTOSC oscillator: I/O on CLKIN pin
      #pragma config WDTE = OFF     // Watchdog Timer Enable (WDT disabled)
      #pragma config PWRTE = OFF    // Power-up Timer Enable (PWRT disabled)
      #pragma config MCLRE = ON     // MCLR/VPP pin function is MCLR
      #pragma config CP = OFF       // Code protection is disabled
      #pragma config CPD = OFF      // Data memory code protection disabled
      #pragma config BOREN = ON     // Brown-out Reset Enable
      #pragma config CLKOUTEN = OFF // Clock Out Enable (off)
      #pragma config IESO = OFF     // Internal/External Switchover (off)
      #pragma config FCMEN = OFF    // Fail-Safe Clock Monitor Enable (off)
    /* CONFIG2 */
      #pragma config WRT = OFF      // Write protection off
      #pragma config PLLEN = OFF    // PLL Enable (4x PLL disabled)
      #pragma config STVREN = ON    // Stack Overflow/Underflow Reset Enable
      #pragma config BORV = LO      // Brown-out Reset Low Trip Point
      #pragma config LVP = ON       // Low-Voltage Programming Enable
      #include <xc.h>
      #define _XTAL_FREQ 8000000
       #define rst       RA0            // 5110 'reset'
       #define dat       RA1            // 5110 'din'
       #define clk       RA2            // 5110 'clk'
       #define ce        RC0            // 5110 'ce'
       #define dc        RC1            // 5110 'dc'
       { char work;                     //
         asm("movwf putwreg@work ");    //
         for(char n=0; n<8; n++)        //
           if(work & 128) dat = 1;      //  "
       void putcmd(char cmd)            // bank 0 (inserted by compiler)  |00
       { dc = 0;                        // command mode                   |00
         asm("call  _putwreg       ");  //                                |00
       void rdflash()                   //
       { asm("banksel EECON1       ");  // bank 3                         |03
         asm("bcf   EECON1,6       ");  // CFGS = 0 (not config)          |03
         asm("bsf   EECON1,7       ");  // EEPGD = 1 (program memory)     |03
         asm("bsf   EECON1,0       ");  // RD = 1 (initiate read)         |03
         asm("nop                  ");  // required nop                   |03
         asm("nop                  ");  //  "                             |03
         asm("incf  EEADRL,F       ");  // bump EEADR                     |03
         asm("rlf   EEDATL,W       ");  // move b7 into Carry             |03
         asm("rlf   EEDATH,W       ");  // wreg = the 7 bit hi byte       |03
         asm("bcf   EEDATL,7       ");  // eedatl = the 7 bit lo byte     |03
       void wrchar(char ascii)          //
       { dc = 1;                        // set lcd 'data' mode            |00
         asm("movlw -32            ");  // ascii 32..127 minus offset     |00
         asm("addwf wrchar@ascii,F ");  // font array index, 0..95        |00
         asm("lsrf  wrchar@ascii,W ");  // int(ascii *= 2.5) -> 0..237    |00
         asm("addwf wrchar@ascii,W ");  //  "                             |00
         asm("movlb 3              ");  // bank 3                         |00
         asm("movwf EEADRL         ");  // flash address lo               |00
         asm("movlw Font5x7/256    ");  //                                |00
         asm("movwf EEADRH         ");  // flash address hi               |00
     *   Extract five bytes of pattern data from three memory words. An     *
     *   even character uses word 0 hi + lo, 1 hi + lo, and 2 hi while      *
     *   odd characters use word 0 lo, 1 hi + lo, and 2 hi + lo.  A 6th     *
     *   blank (zero) byte is sent for inter-character spacing.             *
         asm("call  _rdflash       ");  // read 1st word (2 bytes)        |03
         asm("banksel wrchar@ascii ");  // bank 0                         |00
         asm("btfss wrchar@ascii,0 ");  // odd char? yes, skip, else      |00
         asm("call  _putwreg       ");  // send hi byte (even character)  |00
         asm("banksel EEDATL       ");  // bank 3                         |03
         asm("movf  EEDATL,W       ");  //                                |03
         asm("call  _putwreg       ");  // send lo byte                   |00
         asm("call  _rdflash       ");  // read 2nd word (2 bytes)        |03
         asm("call  _putwreg       ");  // send hi byte                   |00
         asm("call  _rdflash       ");  // read 3rd word (2 bytes)        |03
         asm("btfsc wrchar@ascii,0 ");  // even char? yes, skip, else     |00
         asm("call  _putwreg       ");  // send lo byte (odd characters)  |00
         asm("movlw 0              ");  //                                |00
         asm("call  _putwreg       ");  // send blank 6th column          |00
       void putstr(const char *str)     // put 'ROM' strings
       { char n = 0;                    //
         while(str[n++])                //
         { asm("call _putwreg  ");      //
     *   main setup                                                         *
       void main(void)
       { ANSELA = 0;                    // Analog off (digital I/O)
         ANSELC = 0;                    //  "
         TRISA = 0;                     //
         TRISC = 0;                     //
         OSCCON = 0b01110000;           // set INTOSC to 8-MHz
         __delay_ms(30);                //
         putcmd(0x20+0x01);             // function set: ext instructions
         putcmd(0x20+0x00);             // function set: std instructions
     *   test the lcd print functions                                       *
         wrchar('R');                   //
         putstr("eady");                //
     *   main loop                                                          *
         while(1)
     *   Packed 96 character 5x7 Font, 2.5-words-per-character, 240 words   *
       #asm
       PSECT myFonts, class=CODE, abs, space=0, delta=2
         ORG 700h
       Font5x7:
         dw 0x0000, 0x0000, 0x0000, 0x005F, 0x0000     ;  32 ' '  '!'
         dw 0x0007, 0x0007, 0x0014, 0x3F94, 0x3F94     ;  34 '"'  '#'
         dw 0x122A, 0x3FAA, 0x0923, 0x0988, 0x3262     ;  36 '$'  '%'
         dw 0x1B49, 0x2AA2, 0x2800, 0x0283, 0x0000     ;  38 '&'  '''
         dw 0x001C, 0x1141, 0x0000, 0x20A2, 0x0E00     ;  40 '('  ')'
         dw 0x0A08, 0x1F08, 0x0A08, 0x043E, 0x0408     ;  42 '*'  '+'
         dw 0x0050, 0x1800, 0x0008, 0x0408, 0x0408     ;  44 ','  '-'
         dw 0x0060, 0x3000, 0x0020, 0x0808, 0x0202     ;  46 '.'  '/'
         dw 0x1F51, 0x24C5, 0x1F00, 0x217F, 0x2000     ;  48 '0'  '1'
         dw 0x2161, 0x28C9, 0x2321, 0x20C5, 0x25B1     ;  50 '2'  '3'
         dw 0x0C14, 0x097F, 0x0827, 0x22C5, 0x22B9     ;  52 '4'  '5'
         dw 0x1E4A, 0x24C9, 0x1801, 0x3889, 0x0283     ;  54 '6'  '7'
         dw 0x1B49, 0x24C9, 0x1B06, 0x24C9, 0x149E     ;  56 '8'  '9'
         dw 0x0036, 0x1B00, 0x0000, 0x2B36, 0x0000     ;  58 ':'  ';'
         dw 0x0414, 0x1141, 0x0014, 0x0A14, 0x0A14     ;  60 '<'  '='
         dw 0x0041, 0x1114, 0x0402, 0x00D1, 0x0486     ;  62 '>'  '?'
         dw 0x1949, 0x3CC1, 0x1F7E, 0x0891, 0x08FE     ;  64 '@'  'A'
         dw 0x3FC9, 0x24C9, 0x1B3E, 0x20C1, 0x20A2     ;  66 'B'  'C'
         dw 0x3FC1, 0x20A2, 0x0E7F, 0x24C9, 0x24C1     ;  68 'D'  'E'
         dw 0x3F89, 0x0489, 0x00BE, 0x20C9, 0x24FA     ;  70 'F'  'G'
         dw 0x3F88, 0x0408, 0x3F80, 0x20FF, 0x2080     ;  72 'H'  'I'
         dw 0x1040, 0x20BF, 0x00FF, 0x0414, 0x1141     ;  74 'J'  'K'
         dw 0x3FC0, 0x2040, 0x207F, 0x010C, 0x017F     ;  76 'L'  'M'
         dw 0x3F84, 0x0410, 0x3FBE, 0x20C1, 0x20BE     ;  78 'N'  'O'
         dw 0x3F89, 0x0489, 0x033E, 0x20D1, 0x10DE     ;  80 'P'  'Q'
         dw 0x3F89, 0x0CA9, 0x2346, 0x24C9, 0x24B1     ;  82 'R'  'S'
         dw 0x0081, 0x3F81, 0x00BF, 0x2040, 0x203F     ;  84 'T'  'U'
         dw 0x0FA0, 0x2020, 0x0FBF, 0x2038, 0x203F     ;  86 'V'  'W'
         dw 0x3194, 0x0414, 0x3187, 0x0470, 0x0407     ;  88 'X'  'Y'
         dw 0x30D1, 0x24C5, 0x2180, 0x3FC1, 0x2080     ;  90 'Z'  '['
         dw 0x0104, 0x0410, 0x1000, 0x20C1, 0x3F80     ;  92 '\'  ']'
         dw 0x0202, 0x0082, 0x0240, 0x2040, 0x2040     ;  94 '^'  '_'
         dw 0x0001, 0x0104, 0x0020, 0x2A54, 0x2A78     ;  96 '`'  'a'
         dw 0x3FC8, 0x2244, 0x1C38, 0x2244, 0x2220     ;  98 'b'  'c'
         dw 0x1C44, 0x2248, 0x3FB8, 0x2A54, 0x2A18     ; 100 'd'  'e'
         dw 0x047E, 0x0481, 0x010C, 0x2952, 0x293E     ; 102 'f'  'g'
         dw 0x3F88, 0x0204, 0x3C00, 0x227D, 0x2000     ; 104 'h'  'i'
         dw 0x1040, 0x223D, 0x007F, 0x0828, 0x2200     ; 106 'j'  'k'
         dw 0x0041, 0x3FC0, 0x007C, 0x0218, 0x0278     ; 108 'l'  'm'
         dw 0x3E08, 0x0204, 0x3C38, 0x2244, 0x2238     ; 110 'n'  'o'
         dw 0x3E14, 0x0A14, 0x0408, 0x0A14, 0x0C7C     ; 112 'p'  'q'
         dw 0x3E08, 0x0204, 0x0448, 0x2A54, 0x2A20     ; 114 'r'  's'
         dw 0x023F, 0x2240, 0x103C, 0x2040, 0x107C     ; 116 't'  'u'
         dw 0x0E20, 0x2020, 0x0E3C, 0x2030, 0x203C     ; 118 'v'  'w'
         dw 0x2228, 0x0828, 0x220C, 0x2850, 0x283C     ; 120 'x'  'y'
         dw 0x2264, 0x2A4C, 0x2200, 0x0436, 0x2080     ; 122 'z'  '{'
         dw 0x0000, 0x3F80, 0x0000, 0x20B6, 0x0400     ; 124 '|'  '}'
         dw 0x0808, 0x0410, 0x0478, 0x2341, 0x2378     ; 126 '~'  ''
       #endasm
    mike
    mssp is pretty easy
    SSP1CON1=0x21 ;$22,21,20 all work @32mhz 20 is fastest
    SSP1STAT=0x40
    sdo and sck pins set to dig o/p
    to transfer data
    PIR1.3=0
    SSP1BUF = data
    WHILE (!PIR1.3) ;
    tried your code on 16f1847 ,its not working
    Aug 2005
    Michigan, USA
    It seems XC8 is placing my program code on top of my font table in the 0700h area of memory. More detective work (sigh)...
    Thanks for the MSSP/SPI info, Richard. I will get to that after tracking down the current problem...
    Mike
    <added>
    If you get a chance, add the "ovrld" param' to the following line and tell me if that fixes the problem, please?
       PSECT myFonts, class=CODE, abs, ovrld, space=0, delta=2
    ovrld,
    does not fix it
    even local too
    there is more wrong than just that , the putwreg function is getting called six times for the wrchar
    and only 5 times for the entire putstr call
    its a total bitch to debug with all that inline asm , the debugger just
    goes stupid
    putcmd looks fine on the logic analyser , it all goes pear shaped from then on
    Aug 2005
    Michigan, USA
    Sorry, Richard (and gang). A bug at the very top of the putchar() routine was messing up the font table address. And yes, I know assembler is a PITA... I wish I could get a gratis copy of PBP...
    Corrected version attached (375 words total). I still need to dig out my old Nokia 5110 display and test this on real hardware. I also have a tiny 128x32 I2C OLED display and a tiny 128x64 SPI OLED display to play with sometime soon.
    Nokia_Main.c.txt
    putstr still not working
    I think it should look like this, but it only works for the first call
    so I get "Re and then garbage
         while(*str)
           wrchar(*str++);
    more oddly
    strcpy(buff,"eady");
    putstr(buff);
    works with my modified routine
    putstr("eady");
    crashes the show
    void wrchar(char d)          //
         volatile char ascii=d;
    fixed it, compiler optimised ascii var out
    Aug 2005
    Michigan, USA
    Yes, your putstr() routine is better...
    While debugging I've found XC8 is using the same memory location for local variables in both the wrchar() and putstr() functions. The wrchar@ascii variable is using 70h and the putstr@str pointer is using 70h and 71h. Is this a result of my heavy use of assembly code? That is, XC8 doesn't realize those local variables need to be unique? How do I get XC8 to use unique memory locations for those local variables?
    make them static
    I think I prefer my take on this
    since:-
    the font is automatically located
    the pin/hw defines are in mcc ,therefore its simple to port to any chip that can read its own flash
    its easy to debug
    bigtext and inverted text are easily implemented
    its only 100 or so words bigger
            Product Revision  :  PIC10 / PIC12 / PIC16 / PIC18 MCUs - 1.65.2
            Device            :  PIC16F1847
            Driver Version    :  2.00
     * font.c included via ide source files
    void WrChar(char );
    void WrStr(const char *);
    void main(void) {
        __delay_ms(30); //
        __delay_ms(1);
        __delay_ms(1);
        WrStr("eady");
        while (1) {
     End of File
    void WrChar(char d) { // for packed 2.5 word 5x7 font
        uint16_t tmp, inx = (uint16_t) & FNT;
        char fd[6], j = 0, k = 3, *pt;
        inx += ((uint16_t) (d - 32)*5) >> 1;
        while (k--) {
            tmp = FLASH_ReadWord(inx++);
            fd[j + 1] = tmp & 0x7f;
            tmp <<= 1;
            fd[j] = tmp >> 8;
            j += 2;
        pt = fd;
        if ((d & 1))pt++;
        k = 5;
        // with font now stored in bufer fd its easy to have large and/or inverted text
        while (k--) {
            putwreg(*pt++);
        putwreg(0);
        LCD_DC_SetLow();
        putwreg(x);
        LCD_DC_SetHigh();
    void WrStr(const char *buff) {
            while (*buff)
                WrChar(*buff++); //
    font.c
    #include <xc.h>
    #asm
      GLOBAL _FNT
    _FNT
    #endasm
    tried a pbp version for the 5 byte compressed packed font, the unpacking done without asm
    takes more code space than the compressing saves
    inc file
    '*  Name    : NOKIA_ds5.INC                                     *
    '*  Author  : richard                                           *
    '*  Notice  :                                                   *
    '*  Date    : 26/05/2018                                        *
    '*  Version : 1.0b mssp1 version  bigtxt                        *
    '*  Notes   :  inverse text  mike 5 byte font version           *
    '*          :FOR pic 16/18       NOKIA LCD                      *
     goto overglcd
    ; adjust these definitions to suit and  place in main prg
    '#DEFINE PIC16 1  ;IF PIC18 NOT USED
    '#define use_mssp 1  ;if mssp used DON'T FORGET to set sdo and sck pins as o/p's
    ' lcdheight con 5      ;  6 PAGES
    ' lcdwidth  con 84     ; 84 PIXELS WIDE
     ;--------------ONLY IF MSSP NOT USED---------------
    ' LCD_CLK  var     Portb.4       '  Clock
    ' LCD_DIN  var     Portb.2       ' Data
    ' LCD_RST  var    PortA.4
    ' LCD_DC   var    PortA.3
    ' LCD_CE   var    LATA.6
    ' LCD_LIGHT   var PortA.0
     USERCOMMAND "LCDC"     ;X,Y,CHR  0 <  X < 84  ,   0 <  Y < 7    31 < CHR > 127
     USERCOMMAND "LCDCLR"   ;clear LCD
     USERCOMMAND "LCDSTR"   ;STRING @ X,Y  or   Constant String
     USERCOMMAND "LCDCMD"   ;cmd BYTE TO LCD
     USERCOMMAND "LCDDAT"   ;DATA BYTE TO LCD
      ;----[const String]---------------------------------------------------------------
    LCDSTR?CCS  macro Xin ,Yin,Cin
     IFNDEF  TBLPTRL
        local TheString, OverStr ; define local labels so you can call macro multiple times
        goto OverStr ; goto over string stored in FLASH, so processor can't execute that
    TheString ;label to get address of your string
        da Cin, 0 ;add string to flash at TheString address and end string with 0
    OverStr
        MOVE?CW  TheString, _glcd_bigaddress
        MOVE?CB Xin , _POSX
        MOVE?CB Yin , _POSY
        L?CALL  _GlcdUnpackStr
        data Cin, 0 ;add string to flash at TheString address and end string with 0
    OverStr
        movlw   UPPER TheString
        movwf   TBLPTRU
        movlw   HIGH TheString
        movwf   TBLPTRH
        movlw   LOW TheString
        movwf   TBLPTRL
        MOVE?CB Xin , _POSX
        MOVE?CB Yin , _POSY
        L?CALL  GLCD_Cstr_out
     ;----------------------Strings------------------------------------
    LCDSTR?CBB  macro Xin ,Yin ,Bin
        MOVE?CB Xin , _POSX
        MOVE?BB Yin , _POSY
        MOVE?CB high Bin, FSR1H ;load highbyte
        MOVE?CB low  Bin, FSR1L ;load low byte
        L?CALL  GLCD_str_out
    LCDSTR?CCB  macro Xin ,Yin ,Bin
        MOVE?CB Xin , _POSX
        MOVE?CB Yin  ,_POSY
        MOVE?CB high (Bin), FSR1H ;load highbyte
        MOVE?CB low  (Bin), FSR1L ;load low byte
        L?CALL  GLCD_str_out
    LCDSTR?BBB  macro Xin ,Yin ,Bin
        MOVE?B  Xin, _POSX
        MOVE?B  Yin, _POSY
        L?CALL  GLCD_str_out
    LCDSTR?WBB  macro Xin ,Yin ,Bin
        MOVE?WB Xin, _POSX
        MOVE?BB Yin, _POSY
        L?CALL  GLCD_str_out
    LCDSTR?WWB  macro Xin ,Yin ,Bin
        MOVE?WB Xin, _POSX
        MOVE?WB Yin, _POSY
        L?CALL  GLCD_str_out
    LCDCMD?C  macro Cin
        MOVE?CT 0,_LCD_DC
        MOVE?CB  Cin , _lcdData
        L?CALL   _lcd_byte
    LCDCMD?B  macro Cin
        MOVE?CT 0,_LCD_DC
        MOVE?BB  Cin , _lcdData
        L?CALL   _lcd_byte
    LCDCMD?W  macro Cin
        MOVE?CT 0,_LCD_DC
        MOVE?WB  Cin , _lcdData
        L?CALL   _lcd_byte
    LCDDAT?C  macro Cin
        MOVE?CT 1,_LCD_DC
        L?CALL   _lcd_byte
    LCDDAT?B  macro Cin
        MOVE?CT 1,_LCD_DC
        L?CALL   _lcd_byte
    LCDDAT?W  macro Cin
        MOVE?CT 1,_LCD_DC
        L?CALL   _lcd_byte
    LCDCLR? macro
        L?CALL   _lcd_clr
     ;----------------------Character @ X,Y ------------------------------------
    LCDC?BBB  macro Xin ,Yin , Bin
        MOVE?BB  Xin, _POSX
        MOVE?BB  Yin, _POSY
        MOVE?BB  Bin, _glcdCh
        L?CALL   _gcga
    LCDC?WBB  macro Xin ,Yin , Bin
        MOVE?WB  Xin, _POSX
        MOVE?BB  Yin, _POSY
        L?CALL   _gcga
    LCDC?WWB  macro Xin ,Yin , Bin
        MOVE?WB  Xin, _POSX
        MOVE?WB  Yin, _POSY
        L?CALL  _gcga
    LCDC?BBC  macro Xin ,Yin , Cin
        MOVE?BB  Xin, _POSX
        MOVE?BB  Yin, _POSY
        MOVE?CB  Cin ,_glcdCh
        L?CALL   _gcga
    LCDC?WBC  macro Xin ,Yin , Cin
        MOVE?WB  Xin, _POSX
        MOVE?BB  Yin, _POSY
        L?CALL   _gcga
    LCDC?CCC  macro Xin ,Yin ,Cin
        MOVE?CB  Xin ,   _POSX
        MOVE?CB  Yin,    _POSY
        MOVE?CB  Cin,   _glcdCh
        L?CALL   _gcga
    LCDC?CCB  macro Xin ,Yin ,Bin
        MOVE?CB  Xin ,  _POSX
        MOVE?CB  Yin,    _POSY
        L?CALL   _gcga
    LCDC?B  macro Bin
        L?CALL   _gcga
    GLetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
        BANKSEL 0
     IFDEF    TBLPTRL
    GLCD_Cstr_out
        tblrd   *+
        movf   TABLAT,w
        bz	GLCD_exit_Cstr_out  ; EXIT ON Null char
        CHK?RP  _glcdCh
        MOVWF   _glcdCh
        CHK?RP  _glcd_bigaddress
        movff   TBLPTRU,_glcd_bigaddress
        movff   TBLPTRH,_glcd_bigaddress+1
        movff   TBLPTRL,_glcd_bigaddress+2
        L?CALL  _gcga
        movff   _glcd_bigaddress   ,TBLPTRU
        movff   _glcd_bigaddress+1 ,TBLPTRH
        movff   _glcd_bigaddress+2 ,TBLPTRL
        bra     GLCD_Cstr_out
    GLCD_exit_Cstr_out
        BANKSEL 0
    GLCD_str_out
        movf POSTINC1, W	; Get a character
        bz	GLCD_exit_strout  ; EXIT ON Null char
        CHK?RP  _glcdCh
        MOVWF _glcdCh
        BANKSEL 0
        L?CALL _gcga
        bra    GLCD_str_out
    GLCD_exit_strout
        BANKSEL 0
    GLCD_str_out
        IFDEF BSR
            MOVIW FSR1++	; Get a character
            BTFSC STATUS,Z
            BRA	GLCD_exit_strout  ; EXIT ON Null char
            movf INDF, W	; Get a character
           BTFSC STATUS,Z
            GOTO	GLCD_exit_strout  ; EXIT ON Null char
            INCF FSR,F
        CHK?RP  _glcdCh
        MOVWF _glcdCh
        MOVE?BB FSR1L,_glcd_bigaddress
        MOVE?BB FSR1H,_glcd_bigaddress+1
        BANKSEL 0
        L?CALL _gcga
        MOVE?BB _glcd_bigaddress,FSR1L
        MOVE?BB _glcd_bigaddress+1,FSR1H
        GOTO  GLCD_str_out
    GLCD_exit_strout
        BANKSEL 0
    endasm
        glcd_bigaddress  VAR BYTE[3]
        glcdCh      var byte  'chr  DATA
        lcdData     VAR byte  'DATA
        glcdDC      VAR BYTE  'gca  var
        glcdFont    var word  'font address
        glcdOffset  VAR word  'font offset
        dsfbuff var byte[26]
        ctemp1 var word
        gl var byte
        glcdBc   var byte
        POSY        var byte  'gca  pg   address
        gy_         var byte  'gca  pg   address
        POSX        var byte  'gca  row  address
        gx_         var byte  'gca  row  address
        ctemp       var word
        glcdStrAddr var word ext
        bigtxt       var bit
        inverted      var bit
    @glcdStrAddr =   _glcd_bigaddress
    GlcdUnpackStr:
        readcode glcdStrAddr,CTEMP
        glcd_bigaddress[2]  = CTEMP&$7f
        ctemp=ctemp<<1
        glcdCh = CTEMP.HIGHBYTE
        glcdStrAddr=glcdStrAddr+1
        if   glcdCh then
            gosub gcga
            glcdCh =  glcd_bigaddress[2]
        if   glcdCh then
          gosub gcga
        goto   GlcdUnpackStr:
    lcd_init:
        @ GLetAddress _font7x5,_glcdFont
        bigtxt = 0
        inverted =0
        #ifdef use_mssp
        SSP1STAT=$40
        #endif
        LCD_CE=1
        pause 30
        Lcd_RST = 0         ' Reset LCD (HW reset)
        pause 1
        Lcd_RST = 1         ' Release Reset
    '    lcd_dc=0
        LCDCMD   $21        ' LCD EXTENDED COMMANDS
        LCDCMD   $c8        ' SET LCD Vop (CONTRAST) initial value $C8 = 200.
        LCDCMD   $06        ' SET TEMP COEFFICIENT
        LCDCMD   $13        ' LCD BIAS MODE
        LCDCMD   $20        ' LCD STANDARD COMMANDS
        LCDCMD   $08        ' LCD blank
        LCDCMD   $0c        ' LCD IN NORMAL MODE
    lcd_clr:    ' clear
          FOR  gy_ =0 TO 5
              FOR GX_=0 TO 83
                 LCDDAT  0
              NEXT
          NEXT
    lcd_byte:  'send command sequence "glcdData "
    LCD_CE=0
    #ifdef use_mssp
        PIR1.3=0
        SSP1BUF = LcdData
    #else
        PAUSEUS 150
    #endif
    LCD_CE=1
    LCDxy:    ;set LCD XY
       POSY = POSY MIN lcdheight
       POSX = POSX MIN lcdwidth
       LCDCMD POSY|$40
       LCDCMD POSX|$80
    gcga:      ;unpack font from flash and display it
        #ifdef PIC16
            glcdOffset = (glcdch-32)*5/2 + glcdFont  ; point to cga data
        #ELSE
            glcdOffset = (glcdch-32)*6 + glcdFont  ; point to cga data
        #ENDIF
       gosub LCDxy
    #ifdef PIC16
    '     ; COMMENT OUT THIS ASM SECTION IF CHIP HAS NO EEDAT REG
    '    ASM
    '    MOVE?CB high _dsfbuff, FSR1H ;load highbyte
    '    MOVE?CB low  _dsfbuff, FSR1L ;load low byte
    '    MOVE?WW    _glcdOffset,EEADRL
    '    MOVE?CB    3,_glcdDC
    'nxtf
    '    BANKSEL   EECON1
    '    BSF EECON1, EEPGD ;Point to PROGRAM memory
    '    BSF EECON1, RD ;EE Read
    '    NOP
    '    NOP
    '    RLF    EEDAT, W
    '    RLF    EEDATH, W
    '    MOVE?AB  _glcdBc
    '    BANKSEL   EEDAT
    '    BCF    EEDAT,7
    '    MOVF   EEDAT,W
    '    MOVWI FSR1++
    '    MOVE?BA   _glcdBc
    '    MOVWI FSR1++
    '    BANKSEL   EEADRL
    '    incf    EEADRL,F
    '    btfsc   STATUS,Z
    '    incf    EEADRH,F
    '    BANKSEL  _glcdDC
    '    DECFSZ  _glcdDC,F                ;dec count
    '    GOTO    nxtf
    '    BANKSEL 0
    '    ENDASM
        ; UNCOMMENT IF CHIP HAS NO EEDAT REG
        glcdBc=0
        gosub getflash
        if !glcdch.0 then
            dsfbuff[glcdBc] = CTEMP.HIGHBYTE
            glcdBc=glcdBc+1
        dsfbuff[glcdBc] = glcdDC
        glcdBc=glcdBc+1
        gosub getflash
        glcdBc=glcdBc+1
        glcdBc=glcdBc+1
        gosub getflash
        if glcdch.0 then
            glcdBc=glcdBc+1
        dsfbuff[5] =  0
    #else
        for glcddc = 0 to 2
           dsfbuff[glcddc*2] = CTEMP
           dsfbuff[glcddc*2+1] = CTEMP.HIGHBYTE
           glcdOffset     = glcdOffset + 2
        NEXT
    #endif
       if inverted then
       for glcddc = 5 to 0 STEP -1
          dsfbuff[glcddc]=~dsfbuff[glcddc]
       next
       if bigtxt then ;create a big chr from a small one
           DSFBUFF[24] = POSX
           DSFBUFF[25] = POSy
               ctemp = 0
               ctemp1 = 3
               gL = dsfbuff[glcddc]
               for glcdBc = 0 to 7
                   IF  GL & 1 THEN ctemp = ctemp|ctemp1
                   ctemp1 = ctemp1<<2
                   GL = GL>>1
               NEXT
               gL = glcddc*2
               dsfbuff[GL]   =ctemp.LOWBYTE
               dsfbuff[GL+1] =ctemp.LOWBYTE
               dsfbuff[GL+12]=ctemp.HIGHBYTE
               dsfbuff[GL+13]=ctemp.HIGHBYTE
           NEXT
           for   glcddc = 0 to 11
            LCDDAT   dsfbuff[GLCDDC]
           NEXT
           POSY=POSY+1
           POSX=DSFBUFF[24]
           gosub LCDxy
           for   glcddc = 12 to 23
           NEXT
           POSx = POSX + 12
           IF POSX > 72  THEN  POSX=0    ;wrap
           posy=DSFBUFF[25]
           for   glcddc = 0 to 5
           NEXT
           POSx = POSX + 6
           IF POSX > 78  THEN  POSX=0    ;wrap
    getflash:
            readcode glcdOffset,CTEMP
        glcdDC= CTEMP&$7f
        ctemp = ctemp << 1
         glcdOffset = glcdOffset + 1
    overglcd :
    demo file
    '*  Name    : NOKIA_DEMO.PBP                                     *
    '*  Notice  :                                                    *
    '*  Date    : 16/5/2018                                          *
    '*  Version :  mssp1 version  with bigtxt  ,inverse txt          *
    '*  Notes   :  used mikes compressed packed 5 byte font          *
    '*          :FOR pic 16F1847@32MHZ           NOKIA               *
    #CONFIG ; 16FF1847.
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _BOREN_OFF
            __config _CONFIG2, _PLLEN_OFF & _LVP_OFF
    define      OSC         32
    ; --- *** Oscillator  *** ---------------------------------------------------
    OSCCON = %11110000           ;32 MHz,
    ANSELb = 0
    ANSELA = 0
    TRISA=%10010000
    TRISB=%11101011
     ;DEFINES FOR DISPLAY   use   font7x5_16.bas   or  font7x5_18.bas     for pic18
     #DEFINE PIC16 1
     #define use_mssp 1
     lcdwidth  con 83     ; 84 PIXELS WIDE
    ' LCD_CLK     var     LATB.4       ' SCK1     pin needs to be set as dig o/p
    ' LCD_DIN     var     LATB.2       ' SDO1     pin needs to be set as dig o/p
     LCD_RST     var     LATA.4
     LCD_DC      var     LATA.3
     LCD_CE      var     LATA.6
     LCD_LIGHT   var     LATA.0
    BUFF VAR BYTE [16]
    char  VAR BYTE
    Include "nokia_ds5.inc"  ' bring it in
    include "font7x5_16_5.bas"
    '==========================    MAIN  Routine    ==============================
        gosub lcd_init
        LCDCLR
        ARRAYWRITE BUFF,["READY",0]
         inverted=1
        LCDSTR  5,2,BUFF
        PAUSE 1000
        LCDCLR
        inverted=0
        bigtxt = 1
        LCDSTR  5,2,BUFF
        PAUSE 1000
        LCDCLR
        bigtxt = 0
        posx=0
        posy=0
        gosub LCDxy
        char=32
    looper:
        lcdc char
        while posx
        char=char+1
        if char>127 then char=32
        lcdc char
        PAUSE 100
        wend
        posy=posy+1
        if posy>5 then
        posy=0
        gosub LCDxy
        PAUSE 1000
    GOTO LOOPER
    font
    '*  Name    : font7x5_16_5.BAS                                  *
    '*  Author  : mike                                              *
    '*  Notice  :                                                   *
    '*  Date    :                                                   *
    goto overfont
    font7x5:     ;14BIT   PACKED FORMAT   [2X7BITS]     CHR32-126 [SP TO ~ ]
    asm
     endasm
    overfont:
    Aug 2005
    Michigan, USA
    I think I prefer my take on this ...
    A great example. Thank you.
    Quote Originally Posted by richard
    takes more code space than the compressing saves ...
    That's a shame but it was worth a try.
    Thank you very much for the pointers and help. It's been a fun experiment and I've learned a lot.
    ditto
    and I finally figured out what I was doing wrong with asm psect labels
    whats next
    a ttf
    a double size font for digits (0 to 9 +- : )
    Jun 2005
    West Australia
    Hi Richard,
    Thanks for the fix on the single char problem, it works well but I've found another problem...
    When I add DT Ints the big characters don't work, I tried with and without using mssp but same result.
    Also there's something strange taking place with the led backlight insomuch as I need to sprinkle port pin enable code immediately following any lcd write (with or without DT Ints). I tried changing LCD_LIGHT from A.0 to A.1 (while leaving it connected to A.0) with no difference - does the Inc file employ any commands for the light?
    Here's the edited code:
    #CONFIG ; 16F1847.
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
    define      OSC         32
    OSCCON = %11110000   ; 32 MHz,
    ANSELA = 0           ; all digital
    ANSELB = 0           ; all digital
    TRISA=%00000000
    'TRISB=%00000000
    TRISB=%11101011           ; Encoder inputs on B5-7
    ch var byte
    BUFF VAR BYTE [10]
     #DEFINE PIC16 1
     #define use_mssp 1   ; much faster and less words (1027 vs 1106).
     LCD_RST     var     LATA.4
     LCD_DC      var     LATA.3
     LCD_CE      var     LATA.6
    Include "Modedefs.bas"
    INCLUDE "DT_INTS-14.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas"    ' Include if using PBP type interrupts
    Include "nokia_ds.INC"      ' bring it in
    include "font7x5_16.bas"
    'include "font7x5_16 edit degC.BAS"  ; use @ to access degC symbol.
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    IOC_INT,  _Rot_Encoder,   PBP,  yes
    @    INT_ENABLE   IOC_INT     ; Port Change Interrupt
        gosub lcd_init
        LCDCLR
        LCDSTR 5,0,BUFF
        PortA.0 = 0    ' turn on backlight.
        PAUSE 1000
        LCDCLR
        PAUSE 1000
    looper:
        LCDCLR
    '    LCDSTR 0,4,"With@MSSP xfer"
        LCDSTR 0,4,"Hi"
    '    LCDSTR 0,5," "  ; this doesn't compile - causes errors and warnings wherever used.
        LCDC 0,5,"a"    ; use LCDC for single chars.
        PAUSE 1000
        GOTO looper
    Rot_Encoder:
    '    if PortB.7 = 0 then        ' Check if Encoder pushbutton was pushed.
    '    ButtPush = 1               ' Set the flag for a quick exit.
    '    Old_Bits = New_Bits        ' Equalize the disturbance the pushbutton caused.
    @ INT_RETURN                   ; Exit accordingly.
    '    endif
    Is the Inc file compatible with DT Ints?
    Bill
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. 16F946 pcb footprint (64 tqfp)
    By nomad in forum Schematics
    Last Post: - 8th September 2009, 11:14
  3. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 20:37
  4. Nokia 3310 LCD
    By barkerben in forum General
    Last Post: - 10th December 2005, 19:08
  5. Small LCD module,character
    Last Post: - 27th November 2005, 18:13
