Nokia lcd include , small footprint to suit pic16's - Page 3
Page 3 of 3 FirstFirst 123
Results 81 to 111 of 111
  1. #81
    Oct 2010
    Default Re: Nokia lcd include , small footprint to suit pic16's
    post is duplicated....
  2. #82
    Does it matter that SFR are commented in the pic18f46k22 pbpinc?
    no
    I have tried the new inc and got the following errors. (used PIC18f46k22)
    Is there a way i could fix those?
    if configured correctly you won't get errors
    IT needed a tweak to work for a 18f26k22
    Oct 2010
    Richard thanks,
    tested and confirmed that is working.
    I have tested only the small font 7x5_18 as text.
    I'm trying to figure out how to display a variable.
  5. #85
    Oct 2010
    tested with big fonts as well.
    it is really easy to use it like that.
    Richard is there a way to print variables other than text?
  6. #86
    doesn't the demo show that with the contrast and backlight stuff ?
    what have you tried ?
    Oct 2010
    I havent tried the demo. Just download the txt.
    As far as i understant it is using the command
    ARRAYWRITE BUFF [dec C,0]
    LCDSTR x,y, buff
    i tried and it worked.
    a = 1
    b = 2
    c = a+b
  8. #88
    have you read the pbp manual and understood the syntax for
    Output Modifiers for Formatting Strings using arraywrite ?
    its all there
    Oct 2010
    Hi Richard,
    my fault, yes i have read the arraywrite - arrayread command and corrected the code in my previous edited message.
    Many thanks.
  10. #90
    Oct 2010
    i have a question regarding the library and the code for the nokia 3310.
    for the following code:
    ARRAYWRITE speed [dec var1,dec2 var2,0]
    LCDSTR x,y, buff
    VAR1 is a byte and VAR2 is a byte as well. Those two numbers are presenting the Speed in format VAR1,VAR2 (where VAR1 can be any number from 0 to infinity, and VAR2 can be any number from 0 to 99)
    In case that the VAR1 gets the variable from 0 to =<255 the it can be used as a byte.
    My problem is that i need this floating number for ex. speed = 50,86 to get it as an integer speed = 5086. May i have your help please?
    If i set speed (VAR1 VAR2) as word then the following command
    LCDSTR x,y, speed
    does not accept word.
    Could you please help me to get the speed as an integer and read it as it is.
    For my program i'm testing:
    if speed is > 5086 then limit ; 50,86
    thanks once again.
  11. #91
    i will start here
    you do it exactly the same way as for a lcd display
    buff var byte[6] ; 4dig+dp+null
    speed var word
    ARRAYWRITE buff,[dec2 speed/100,".",dec2 speed//100 ,0]
    LCDSTR x,y, buff
    LCDSTR x,y, speed
    correct lcdstr str buffer var ,const str
    from the inc file
    USERCOMMAND "LCDC" ;X,Y,CHR 0 < X < 84 , 0 < Y < 7 , 31 < CHR > 127
    USERCOMMAND "LCDCLR" ;clear LCD
    USERCOMMAND "LCDSTR" ;STRING @ X,Y or Constant String
    USERCOMMAND "LCDCMD" ;cmd BYTE TO LCD
    USERCOMMAND "LCDDAT" ;DATA BYTE TO LCD
    i might preempt the next question
    leading zero's and right justifying fields
    http://support.melabs.com/forum/picb...strtok-usercmd
    Oct 2010
    im not in front of the circuit and computer in order to test it.
    i havent done it as it following /100 and //100 (remainder)
    buff var byte[6] ; 4dig+dp+nullspeed
    var word
    ARRAYWRITE buff,[dec2 speed/100,"."dec2 speed//100 ,0]
    LCDSTR x,y, buff
    I have used it with "." like the following in the loop and i get it right on the LCD as 50,86 for example. :
    I need on the screen the right "floating" value.
    ARRAYWRITE speed [dec var1,".",dec2 var2,0]
    LCDSTR x,y, speed
    then i send the code to sub label
    speedlimit:
    and i havent used "."
    i sent the command like:
    having that it was not possible to use speed as word.
  13. #93
    makes no sense to me
    ARRAYWRITE speed
    speed must be an existing chr array big enough to contain the text generated plus a null terminator
    a word var could hold only 1 chr safely ,since pbp checks nothing anything could get clobbered by misuse like that
    Oct 2010
    now it makes sense why i was getting some messy chr on the screen like that.
  15. #95
    Oct 2010
    i've tried the following but didnt work.
    rbuf  var byte
    wbuf var word
    checkt:
    arraywrite RBUF,[DEC2 speed1/100,DEC2 speed2//100,0] ; for example speed1 = 56 and speed2 is 85
    LCDSTR 0,2, RBUF ; ----------> this gives 0085
    wbuf = rbuf
    if wBUF > 5685 then
    gosub limit
    then i tried:
    checkt:
    arraywrite RBUF,[DEC speed1,DEC2 speed2//100,0] ; for example speed1 = 56 and speed2 is 85
    LCDSTR 0,2, RBUF ; ----------> this gives 5685 which is what i want....BUT!!!! when i try to check if wbuf > than 5685, it doesnt work
    wbuf = rbuf
    if wBUF > 5685 then   ' IF THE TEMPC IS GREATER THAN 37 C THEN LIGHT UP THE BLUE LED
    high lata.0
    low lata.0
    how is it possible to combine those two speed1 and speed2 vars in one var? and check then the result as an integer number?
  16. #96
    You have only declared "rbuf var byte" It is being used as a pointer as far as I can see. It will be NO LARGER than 255.
    EN82fn
  17. #97
    Oct 2010
    Hi dave,
    i solved it.
    i used the rbuf as var word
    Then i didnt add the commands for
    arraywrite rbuf,[dec speed1,dec2 speed2,0]
    i used the above command only to combine it with the following and present the number to the lcd.
    So the solutions for me is:
    checkt:
    RBUF = (SPEED1*100) + SPEED2
    IF RBUF > 5682 THEN ; THIS IS JUST AN EXAMPLE
    GOSUB LIMIT
    Thanks a lot for the help all of you.
  18. #98
    Oct 2010
    additional missing line from the previous message
    LCDSTR x,y, rbuf
    in any case the solution is to use the rbuf as word, multiply by 100 the speed1 and add speed2.
  19. #99
    i solved it.
    has not solved it at all , you cannot safely use arraywrite rbuf,[dec speed1,dec2 speed2,0] with a word var as the destination
    the destination for the text chrs generated by arraywrite m
    not doing so will lead to enormous problems
    secondy to expect the result of arraywrite to be usable as a number is absurd , its a textual chr string
    Oct 2010
    there is a missandestanding. my fault because i consfused you by using the same name for the variable SBUF and RBUF in the previous posts.
    vars.....
    SBUF var byte
    RBUF var word
    Program in the main loop includes the command:
    arraywrite SBUF, [dec speed1, dec2 speed2,0] ;
    then there is a checkSpeed LABEL
    checkSpeed:
    RBUF = (speed1*100) + speed2
    if RBUF > 5687 then; just an example
    gosub limit
    And that is what it works for me. It is under testing for a day now, and havent seen any strange behaviour.
    thanks.
  21. #101
    SBUF var byte
    sadly still woefully incorrect.
    that reserves 1 byte , you need at least 5 bytes
    Oct 2010
    Do you mean something like that?
    SBUF var BYTE[6]
    it is already configured.
  23. #103
    well done!
    you have proved yet again that code snippets are generally useless time wasters..
    this time with the nice added touch of posting snippets that bear no semblance to
    the code actually employed. a touch of genius . not
    don't know why i bother
    Oct 2010
    Thanks for any help.
    please try to be gentle. Life is small and there are lots of good people out there.
    Have a nice day.
  25. #105
    Oct 2010
    Good day to all.
    I have two questions. One is related to this amazing library shared by Richard and the other one is related to a small project i have.
    1. May i add a picture to nokia LCD via the usercommand LCDDAT?
    For image data could i use the GLCD from Miktoelektronics?
     USERCOMMAND "LCDC"     ;X,Y,CHR  0 <  X < 84  ,   0 <  Y < 7    31 < CHR > 127
    2. Im working with some speed values. So range can be from 0 to infinity.
    How could i catch/retreive the highest value from a Variable? Is there any specific way - path to do that?
    thanks.
  26. #106
    Can you define infinity please?
    Your variables can be: bit (0-1), bytes (0-255), word (0-65535) and long (-2147483648 to 2147483647)
    Oct 2010
    Hi Ioanni, thanks for the reply.
    Speed is not going to exceed any value more than a logical speed targeting to a bicycle or a car. In that case as i understand we could use "word" variable.
    But there is no specific value as a limit. It can be any possible number that a variable may have.
    thanks in advance.
  28. #108
    Maybe the MAX operator can do what you want.
    Your check loop can be something like this:
    max_value = old_speed MAX speed
    old_speed = max_value
    But this will lead eventually to a top value on max_value and you may have to reset this value. Don't know what you try to accomplish but a periodic reset may be needed.
    Oct 2010
    Thanks Ioanni,
    i will try the MAX operator.
    What i'm trying to export is the maximum speed value of a single run.
    As i'm not in my home computer right now i will try your advice later today.
    Many thanks.
  30. #110
    i did look at the array generated by Mikroelektronics glcd bitmap generator and
    it seems i rejected it for that generated by lcdassistant, cannot recall why.
    none of my posted examples use mokroe files . they would all need a bit of
    work to leverage into pbp anyway
    the LCDDAT sends 1 byte to the lcd @ the current cursor posn
    it would not be the most efficient way to upload an image.
    i saw no way to read pixel data back from the display so i decided that the only way to
    create a decent bitmapped image function was using a frame buffer. this i have implemented
    in the c version as posted.
    implementing this function in pbb is not something i'm willing to invest the time into
    I know 3310 LCD is the cheapest graphic LCD one can buy, but the effort to display something is too much relative to the result (B/W bitmap).
    Next best solution is the Nextion 2.4" at about 15 euros, 65536 colors, 4MB memory, 320*240 and touch with RS232 control.
    No MCU load to control the display and feedback with touch (no hardware buttons etc).
    Richard did an exceptional job on 3310 but is it worth anymore with the cheap smart displays?
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. 16F946 pcb footprint (64 tqfp)
    By nomad in forum Schematics
    Last Post: - 8th September 2009, 12:14
  3. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 21:37
  4. Nokia 3310 LCD
    By barkerben in forum General
    Last Post: - 10th December 2005, 20:08
  5. Small LCD module,character
    Last Post: - 27th November 2005, 19:13
