need help with PBP, I2C and MCP23017
Results 1 to 6 of 6
    Default Re: need help with PBP, I2C and MCP23017
    It's probably your copy and paste, because it's done it to me before on this forum, but if the code is indeed correct, your ANSEL, ANSELH, TRISC, and TRISA don't look right. It should a % sign letting PBP know that it's binary and it should have 8 bits.
    TRISC = %00000000
    I2CWRITE SDA,SCL,$20,[$05,%10111000]
    I had the same setup for Arduino which worked fine.
    Arduino use a 7 bit i2c address pbp uses a 8 bit address.
    you make no mention of how you have AO,A1,A2 on the expander connected
    pbp i2c address = (% 0 1 0 0 A2 A1 A0 )<<1 for a mcp23017
    Jun 2011
    Indian Harbour Nova Scotia
    Address bits are connected to ground. for Arduino I could use address $20 or 0 to access, the latter if I used one of the libraries.
    in Australia I drive on the other side of the road, its horses for courses
    pbp uses 8bit address scheme
    so A0=0 A1=0 A2=0
    plugged into formula
    addr =(%0100000)<<1 = $40
    so
    I2CWRITE SDA,SCL,$40,[$05,%10111000] is whats required
    Jun 2011
    Thanks Richard. MELabs also told me it was $40 for address. That was the problem! That and the fact my outputs are active low and I was sending active high bits.
  1. I2C question w/ MCP23017 Port Expanders
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 26th December 2012, 05:47
  2. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 14:01
  3. HW I2C with PBP
    By EToscano in forum Serial
    Last Post: - 15th October 2009, 17:35
  4. i2c PBP questions
    By TimV in forum General
    Last Post: - 5th February 2007, 17:58
  5. More I2C question with PBP
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2006, 21:35
