Learning how to use USART
Results 1 to 14 of 14
    Default Learning how to use USART
    I'm trying to get one PIC to talk to the other. I'm not using MIDI messages at this point, but I am using MIDI hardware to connect the two PICs. The schematics are found here https://www.tigoe.com/pcomp/code/picbasic-pro/161/
    I'm using two 16F887. One is the transmitting PIC. MIDI out hardware is connected to pin 25/portc.6/TX. I'm trying to send the numbers 1 ~ 9 every 600ms. An LED blinks each time it's supposed to send just to let me know that it's doing something.
    The other PIC is supposed to receive the number and display it on an LCD. The MIDI in hardware is connected to pin 26/portC.7/RC. I made the LCD display "ready to receive" at start up so I know that it's working.
    The blinking LED on the transmitting PIC is working, and the LCD on the receiving PIC is working, but I'm not seeing any numbers being displayed.
    Here's the code for the transmitting PIC:
    define OSC 20
    define HSER_RCSTA 90h
    define HSER_TXSTA 20h
    define HSER_BAUD 31250
    ANSEL = %00000000
    ANSELH = %00000000
    TRISD = %00000000
    TRISE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %01000000
    send var byte
    send = send + 1
    hserout [send]
    PORTA.0 = 1
    pause 300
    PORTA.0 = 0
    pause 300
    if send >= 10 then
        send = 0
    Here's the code for the receiving PIC:
    CLEARdefine LOADER_USED 1
    define OSC 20
    define LCD_DREG PORTD
    define LCD_DBIT 0
    define LCD_RSREG PORTE
    define LCD_RSBIT 0
    define LCD_EREG PORTE
    define LCD_EBIT 1
    define LCD_RWREG PORTE
    define LCD_RWBIT 2
    define LCD_BITS 4
    define LCD_LINES 4
    define LCD_COMMANDUS 2000
    define LCD_DATAUS 50
    ANSEL = %00000000
    ANSELH =%00000000
    TRISD = %00000000
    TRISE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %01000000
    data_in var byte
    pause 250
    lcdout $fe, 1
    lcdout $fe, $d4, "ready to receive"
    lcdout $fe, 1
    pause 250
    hserin [dec data_in]
    pause 5
    if data_in != 0 then
    gosub display
    display:
    lcdout $fe, 1
    lcdout $fe, $94, dec data_in
    data_in = 0
    OK
    Default Re: Learning how to use USART
    LCDs speak in ASCii. The PBP3 Reference Manual covers ASCii on pages 42 & 305-6. To work with decimal, add 48 to your decimal value & it should appear on the LCD screen as the value intended.
    That didn't help. I also realized that PORTC register should have been TRISC=%10000000. I fixed that, but it didn't help either.
    OK
    There is an initialization process to get LCDs to come on line. It usually isn't needed, but I ran into an instance like yours where everything suggested it SHOULD work, but it didn't. One of the HD44780 LCD Data Sheets outlined an initialization process. Here is what I use:
    4-Wire
    Init_LCD:
        RS = 0
    '    LCD = $20
        DB7 = 0
        DB6 = 0
        DB5 = 1
        DB4 = 0
            En = 1
            pauseus 10
            En = 0
            pause 5
    '    LCD = $20
        DB7 = 0
        DB6 = 0
        DB5 = 1
        DB4 = 0
            En = 1
            pauseus 10
            En = 0
            pauseus 160
    '    LCD = $20
        DB7 = 0
        DB6 = 0
        DB5 = 1
        DB4 = 0
            En = 1
            pauseus 10
            En = 0
            pauseus 160
        LCD = $28
            gosub Send
        LCD = $10
            gosub Send
        LCD = $0C
            gosub Send
        LCD = $06
            gosub Send
        LCD = 1
            gosub Send
            pause 1
        LCD = $80
            gosub Send
        RS = 1
        pause 1
    For 8-wire:
    Init_LCD:
        low RS
        PORTB = $30
            high En
            pauseus 4
            low En
            pause 5
        PORTB = $30
            high En
            pauseus 4
            low En
            pauseus 160
        PORTB = $30
            high En
            pauseus 4
            low En
            pauseus 160
        PORTB = $38
            gosub Send
        PORTB = $10
            gosub Send
        PORTB = $0C
            gosub Send
        PORTB = $06
            gosub Send
        PORTB = 1
            gosub Send
            pause 1
        PORTB = $80
            gosub Send
        high RS
        pause 1
    Send:
        high En
        pauseus 8
        low En
        pause 1
    Maybe this will help.
    given all things working display wise ,imho mike is leading you astray
    tx unit:-
    send = send + 1
    hserout [send]
    will send binary 0 to 9 , probably not the best idea but it is workable
    ps weird baud rate
    rx unit:-
    pause 5
    will never work
    1. its waiting for ascii numbers , the first non number will terminate routine
    2. pause 5 why it serves no purpose and can cause framing errors
    add this define
    DEFINE HSER_CLROERR 1 ' Clear overrun error upon execution of every HSERIN command
    rx unit:-
    if ok but it needs
    hserin [data_in] to match data types
    ps weird baud rate
    Yes, the LDC is working just fine. The baud rate is the standard MIDI baud rate. I'm trying to make a MIDI controller.
    I've updated the code with the suggestions and made it a little more simple. I'm trying to get the LCD of the receiving PIC to display "1" for 300ms and then "0" for 300ms.
    define OSC 20
    ANSEL = %00000000
    ANSELH = %00000000
    TRISD = %00000000
    TRISE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %10000000
    hserout [1]
    PORTA.0 = 1
    pause 300
    hserout [0]
    PORTA.0 = 0
    pause 300
    CLEAR
    define OSC 20
    define HSER_CLROERR 1
    define LCD_DBIT 0
    define LCD_RSBIT 0
    define LCD_EBIT 1
    define LCD_RWBIT 2
    define LCD_BITS 4
    define LCD_LINES 4
    ANSEL = %00000000
    ANSELH = %00000000
    TRISD = %00000000
    TRISE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %10000000
    character var byte
    pause 250
    lcdout $FE, 1
    lcdout $fe, 1
    pause 250
    hserin [character]
    lcdout $fe, 1
    lcdout $fe, $94, character
    It's still not working.
    how can it work ?
    char's 0 and 1 are non printing characters on a lcd
    lcdout $fe, $94, dec character
    how can it work ?
    Adding the dec modifier didn't help. I tried adding it to hserout as well and it didn't work. Maybe it's my hardware. This is what I'm trying to use.
    Can you recommend something else that's better for connecting two PICs?
    it can't get simpler than this depending on distance / speed .
    using serial tty ie hserin/out
    Oct 2009
    I would get the two talking directly without any MIDI interface. Just connect the TX from the PIC running the transmission code, to the RX on the receiving PIC using a simple jumper wire. If you need to send data back the connect the receiving PICs TX pin to the RX pin on the other PIC. I would then use the HSEROUT and HSERIN commands to send data.
    You could write a short test routine so that the receiving PIC sends a character to the transmitting PIC when its ready to receive data (say by pressing a button), the transmission is made and the data displayed on the LCD.
    So your transmission PIC has something like
    RCIF              VAR PIR1.5                    ' USART receive flag
    GIE               VAR INTCON.7                  ' Comms
    TempWD            VAR WORD                      ' temporary WORD variable
    nTest var byte
    FOR TempWD = 0 TO 1000
        IF RCIF=1 THEN GOTO coms                   ; Check to see if somethings in the buffer, if there is something goto Comms
        PAUSE 2
    NEXT TempWD
    coms:
    HSERIN [nTest]
        SELECT CASE nTest
        CASE "Q"                    ; if Q then send data
        GOTO Term_TX:
    Term_TX
    Hserout [DEC3 insert variable here] ; sends three digits of variable eg 123
    You would then have your receiving PIC set up so that when you want to receive data it sends a Q to the transmitting PIC. The transmitting PIC is always looking at the serial port buffer to see if there is something in it, and when it finds something jumps to the comms subroutine, which checks to see what character has been received an for a match. If its Q then it transmits the data. You could use other characters to jump to other routines and do other things if you wanted.
    The only caveat here is that I've only ever sent numeric data this way. Sending ASCII or strings may need more work.
    Whilst the code is clunky it could always be tidied up and made more efficient once you have the two talking.
    Oct 2009
    Strange baudrate !
    Using a EUSART calculator for your baudrate it gives these values for the port settings
    DEFINE HSER_SPBRG 39  ' 31250 Baud @ SPBRGH = 0
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $20   ' Enable transmit, BRGH = 0
    SPBRG = 39    ' 31250 Baud @ 0.0%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    I don't have PBP3 - so no idea if the formatting is the same or needs changing
    Please make sure that PIC to PIC directly connected work as expected.
    Then move to MIDI interface.
    Also be sure to connect TX to RX. Looks trivial but...
    I removed the midi connections and just connected the TX of the transmitting PIC to the RC of the receiving PIC. Here is the code I'm using for each:
    transmitting:
    define OSC 20
    ANSEL = %00000000
    ANSELH = %00000000
    TRISD = %00000000
    TRISE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %10000000
    hserout [dec 1]
    PORTA.0 = 1
    pause 300
    hserout [dec 0]
    PORTA.0 = 0
    pause 300
    receiving:
    CLEAR
    define OSC 20
    define LCD_DBIT 0
    define LCD_RSBIT 0
    define LCD_EBIT 1
    define LCD_RWBIT 2
    define LCD_BITS 4
    define LCD_LINES 4
    ANSEL = %00000000
    ANSELH = %00000000
    TRISD = %00000000
    TRISE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %10000000
    character var byte
    pause 250
    lcdout $FE, 1
    lcdout $fe, 1
    pause 250
    hserin [character]
    lcdout $fe, 1
    So now it's sorta working. The LCD does display something. It displays "216" when it should be displaying "0" and it displays "217" when it should be displaying 1.
    Oct 2009
    Try setting a variable.
    character  var word
    then use something like
    hserout [dec character]
    And similar for the receiving pic. I'm no expert, but I think that just having DEC 1 as you had simply means its setting the DEC command to use just 1 digit as decimal value of a variable, not a value
  1. remote code learning
    Last Post: - 21st February 2021, 15:38
  2. Replies: 7
    Last Post: - 12th January 2018, 17:02
  3. USB Learning
    By ruijc in forum USB
    Last Post: - 26th July 2014, 21:09
  4. Learning Basic
    By bartman in forum General
    Last Post: - 19th November 2004, 00:45
