the problem is in this macro
PrintStr macro x, y, Str
    local TheString, OverStr
    goto OverStr
TheString
    data   Str, 0
OverStr
    MOVE?CB  x, _PosX
    MOVE?CB  y, _PosY
    MOVE?CW  TheString, _Addr
    L?CALL   _StringOut
its not that simple going from code for pic18 to pic16
the word size for core 14 pics ie pic16 is 14bits
the "data" directive attempts to write two 8 bit pieces of data into a 14bit slot ,hence the end falls off
you could change it to use the "da" directive to pack two 7 bit pieces of data into that space [its ok for 7bit ascii]
but then you need to unpack the data when you read it back
