ADC resolution for 16F616
Results 1 to 11 of 11
    OK
    Default Re: ADC resolution for 16F616
    With PBP3 you won't need to even list ADCON0 unless you change your resolution. PBP3 has to address the ADCON0 Register to select the appropriate AD Channel, and the Justify Bit. Try not listing ADCON0 or ADCON1 at all and see if it still works.
    Everything you need to setup the registers is really in the pdf of your chip. Please be careful selecting new chips as Microchip may issue a Preliminary pdf file having a lot of errors. Also keep your eye on the errata files that Microchip publishes on the chip's page.
    Now, you asked for more precision on your first post.
    Most chips have 8 or 10 bits at the low end 8-bit chips. If you can spare some time on your chip and your application, then you may use the Oversampling routine published here: http://dt.picbasic.co.uk/CODEX/AnalogueOverSampling
    You may reach 16-bits results given you will sacrifice 50-100ms, depending on the chip. I thing 12 or 14 bits are good enough with maximum 6.2ms delay in your program (less if you have a fast MCU).
    With the routine mentioned, you do not need to filter your results for noise or invalid sampling.
  1. 16F616 A to D
    Last Post: - 1st May 2009, 17:37
  2. Configuring 16F616
    Last Post: - 16th February 2009, 17:28
  3. How to calculate ADC resolution (pic12f683)
    By peu in forum mel PIC BASIC Pro
    Last Post: - 18th April 2007, 19:39
  4. Replies: 14
    Last Post: - 4th October 2006, 06:45
  5. High resolution ADC
    By vsingh in forum mel PIC BASIC Pro
    Last Post: - 29th April 2004, 19:53
