GOTO vs RETURN after a GOSUB
Results 1 to 10 of 10
    Miami, Florida USA
    Default GOTO vs RETURN after a GOSUB
    Hi, I have the following code,
    MainLoop:
    'DO SOME STUFF HERE.....
        FOR J = 0 TO 7
            GOSUB SearchForClockSignal
        NEXT J
    goto MainLoop
    SearchForClockSignal:
        USBSERVICE
        SERIN2 PORTE.3, 32, 3, CLOCKSEARCHFAILED, [wait(252), STR RFID_IN\6]
        USBSERVICE
        IF RFID_IN[0] = 252 THEN GOTO MAINLOOP
        SquaresArray[0] = 255
        SquaresArray[1] = 202
        SquaresArray[2] = RFID_IN[0]
        SquaresArray[3] = RFID_IN[1]
        SquaresArray[4] = RFID_IN[2]
        SquaresArray[5] = RFID_IN[3]
        SquaresArray[6] = RFID_IN[4]
        SquaresArray[7] = RFID_IN[5]
        if PPB_DeviceState = 32 then   'ONLY WHEN THERE IS A USB CONNECTION PRESENT
            GOSUB SendUSBData
        GOTO MAINLOOP   'CLOCK SERIAL COMMUNICATION WAS RECEIVED
    CLOCKSEARCHFAILED:
    The program above will run for about 20 seconds and then it will stop working. Now, if I replaced the code in red "GOTO MAINLOOP" above by RETURN, then the code works just fine. Now, I understand that every GOSUB waits for a RETURN, but since I had the option "STACK OVERFLAW" disabled I thought that I could get away with it. Can somebody explains to me what is going on with this issue?
    Anonymous
    Sep 2009
    Default Re: GOTO vs RETURN after a GOSUB
    Better question is why you would use GOSUB without RETURN? That just doesn't have any sense.
    If stack is full then PBP can't call internal subroutines, and it crash...
    You just disabled reset on overflow. That fuse doesn't expand stack to infinity and beyond.
    Better solution to get same result
    MainLoop:
    goto MainLoop
       FOR J = 0 TO 7
        USBSERVICE
        USBSERVICE
        IF RFID_IN[0] = 252 THEN RETURN 'GOTO MAINLOOP
            GOSUB SendUSBData
        RETURN   'CLOCK SERIAL COMMUNICATION WAS RECEIVED
    CLOCKSEARCHFAILED:
        NEXT J
    It's probably overflowing the stack and halting.
    EN82fn
    Miami, Florida USA
    Yes, I'm asking myself the same question . Yes, your code looks better than mine. The program is probably overflowing the stack and halting like Dave said. Will the program restart from the beginning if the stack overflow is enabled?
    Anonymous
    Yes it should create an internal reset condition.
    EN82fn
    Sep 2009
    Yes. It have almost same effect as MCLR pulled low, then high. Only 2 bits are different, if I remember correctly.
    Miami, Florida USA
    Thank you guys.
    Anonymous
    Aug 2003
    If you want to be a cowboy for some reason you could have used GOTO instead of GOSUB.
    Then you could GOTO back as well (instead of RETURN).
    The difference between GOTO and GOSUB is that GOSUB loads the stack with the location it was called from so that a RETURN can go back there, but GOTO doesn’t need to do that.
    BUT! using a GOTO to go somewhere, and another GOTO to go back, just means that neither GOTO had to exist, and you could have just dropped the routine right in where the GOTO was.
    Jan 2006
    Istanbul
    This should work.
    MainLoop:
        FOR J = 0 TO 7
            GOTO SearchForClockSignal
        NEXT J
    goto MainLoop
  1. Is a 'GOTO' Or a 'GoSub'?
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 1st August 2013, 23:27
  2. gosub - return
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 11th August 2010, 10:21
  3. GOTO main or RETURN - Question
    By studysession in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 16:13
  4. Return VS Goto?
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 11th January 2008, 00:13
  5. If ... Then Gosub <> If ... Then Goto?
    By oldtoddler in forum General
    Last Post: - 27th February 2006, 11:52
