CONFIG issues with 18F26K22
Results 1 to 13 of 13
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default CONFIG issues with 18F26K22
    Hi everybody,
    I am trying to replace a 18F2685 by an 18F26K22 on an old design.
    Everything should be compatible providing a correct configuration of my new PIC.
    But the new CONFIG is more complex than with the old one.
    Moreover I need to use a PicKit3 instead of a PicKit2 but this should not be a problem.
    I am using an external 8 MHz xtal and I do not need any BOR reset, stack overflow reset, watch dog, etc..
    I do not care about code protection
    I have built my CONFIG accordingly with the help of the .INFO file.
    I can program my device, but the program does not work.
    When I try to debug, MPLAB IDE slows, sometime hangs, and after a few seconds displays a message :
    PK3Err0040: The target device is not ready for debugging.
    Please check your configuration bit settings and program
    the device before proceeding.
    I suspect that my CONFIG is not appropriate. Please see the attached file.
    I am surprised by at least two things :
    IESO is OFF by default. Am I right if I set it ON ?
    What about DEBUG. ON, OFF, managed by the debug program ?
    I have tryied several combinations but no way.
    Can you see any obvious issue in my CONFIG file ?
    Thank you for your help.
    MikeBZH
    Aug 2011
    Default Re: CONFIG issues with 18F26K22
    I'd try changing these to start with:
      CONFIG PLLCFG = OFF       ; Oscillator used directly
      CONFIG IESO = OFF         ; Oscillator Switchover mode disabled
      CONFIG DEBUG = OFF        ; Disabled
    DEBUG is controlled from within MPLAB when you program it for debugging.
    Usually "The target device is not ready for debugging" is an osc issue.
    FWIW if you want to use your Pickit2, heres a modified PK2DeviceFile which can programme 18F26K22 and a couple of simple apps for manipulating the dat file.
    George
    May 2009
    Many thanks tumbleweed, it works now !
    I can't understand why Microchip make such complex thinks sometimes
    "Keep it simple" should be the rule !
    George, would your mods for the PicKit2 provide also the debug capability or only programming ?
    Best regards
    MikeBZH
    Dec 2010
    If you are really using a crystal then you need FOSC = LP (or the correct setting for a low power crystal with your device.)
    Your file is set for a medium power high speed resonator
    Aug 2011
    LP, XT, and HS settings are all for use with crystals.
    See section 2.5.3 in the datasheet.
    @Mike. No, just stand alone PK2cmd.exe and Pickit2v2.exe.
    For what it's worth the config I use (in Proton but easily transposed)
    	' internal clock 16MHz with 4xPLL = 64MHz
      $if _device = _18F26K22
      	Config_Start
      	  FOSC = INTIO67	   ; Internal oscillator block
      	  PLLCFG = On	       ; Oscillator multiplied by 4
      	  PRICLKEN = On	     ; Primary clock enabled
      	  FCMEN = OFF	       ; Fail-Safe Clock Monitor disabled
      	  PWRTEN = On	       ; Power up timer enabled
      	  BOREN = On	       ; Brown-out Reset enabled and controlled by software (SBOREN is enabled)
      	  BORV = 285	       ; VBOR set to 2.85 V nominal
      	  WDTEN = OFF	       ; Watch dog timer is always disabled. SWDTEN has no effect.
      	  WDTPS = 32768	     ; 1:32768
      	  CCP2MX = PORTC1	   ; CCP2 input/output is multiplexed with RC1
      	  PBADEN = OFF	     ; PORTB<5:0> pins are configured as digital I/O on Reset
      	  CCP3MX = PORTB5	   ; P3A/CCP3 input/output is multiplexed with RB5
      	  HFOFST = On	       ; HFINTOSC output and ready status are not delayed by the oscillator stable status
      	  T3CMX = PORTC0	   ; T3CKI is on RC0
      	  P2BMX = PORTB5	   ; P2B is on RB5
      	  MCLRE = INTMCLR	   ; RE3 input pin enabled; MCLR disabled
      	  STVREN = On	       ; Stack full/underflow will cause Reset
      	  LVP = OFF	         ; Single-Supply ICSP disabled
      	  XINST = OFF	       ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
      	  Debug = OFF	       ; Disabled
      	  Cp0 = OFF	         ; Block 0 (000800-003FFFh) not code-protected
      	  CP1 = OFF	         ; Block 1 (004000-007FFFh) not code-protected
      	  CP2 = OFF	         ; Block 2 (008000-00BFFFh) not code-protected
      	  CP3 = OFF	         ; Block 3 (00C000-00FFFFh) not code-protected
      	  CPB = OFF	         ; Boot block (000000-0007FFh) not code-protected
      	  CPD = OFF	         ; Data EEPROM not code-protected
      	  WRT0 = OFF	       ; Block 0 (000800-003FFFh) not write-protected
      	  WRT1 = OFF	       ; Block 1 (004000-007FFFh) not write-protected
      	  WRT2 = OFF	       ; Block 2 (008000-00BFFFh) not write-protected
      	  WRT3 = OFF	       ; Block 3 (00C000-00FFFFh) not write-protected
      	  WRTC = OFF	       ; Configuration registers (300000-3000FFh) not write-protected
      	  WRTB = OFF	       ; Boot Block (000000-0007FFh) not write-protected
      	  WRTD = OFF	       ; Data EEPROM not write-protected
      	  EBTR0 = OFF	       ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
      	  EBTR1 = OFF	       ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
      	  EBTR2 = OFF	       ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
      	  EBTR3 = OFF	       ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
      	  EBTRB = OFF	       ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
      	Config_End
      $endif
    George
    MikeBZH, Here is the config I use for almost all of my 26K22 projects: 64Mhz internal OSC.
    ;----- CONFIG1H Options --------------------------------------------------
    __config _CONFIG1H, _FOSC_INTIO7_1H & _PLLCFG_ON_1H & _PRICLKEN_ON_1H & _FCMEN_ON_1H & _IESO_OFF_1H
    ;----- CONFIG2L Options --------------------------------------------------
    __config _CONFIG2L, _PWRTEN_ON_2L & _BOREN_ON_2L & _BORV_190_2L
    ;----- CONFIG2H Options --------------------------------------------------
    __config _CONFIG2H, _WDTEN_OFF_2H & _WDTPS_32768_2H
    ;----- CONFIG3H Options --------------------------------------------------
    __config _CONFIG3H, _CCP2MX_PORTB3_3H & _PBADEN_OFF_3H & _HFOFST_OFF_3H & _T3CMX_PORTB5_3H & _MCLRE_EXTMCLR_3H
    ;----- CONFIG4L Options --------------------------------------------------
    __config _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    EN82fn
    Dec 2010
    Tumbleweed - You're right - I should have looked it up instead of going by memory.
    May 2009
    Thank you Dave,
    I need some frequency accuracy. This is why I don't use the internal oscillator but an external xtal and in that case the CONFIG is a little bit different.
    But this issue is fixed now.
    I am now faced with reading the port A digital inputs. Quite simple question but for an unknown reason it behaves differently than with the 18F2685.
    73
    MikeBZH (F8DFN)
    Aug 2011
    Both devices have analog functions on portA but the function is selected differently.
    On the 2685 you use the ADCON1 register, while with the 26K22 it's set with the ANSELA register.
    Mike, here is the setup for one of my projects:
    ANSELA = %00101111 'PORTS A5,A3,A2,A1,A0 ALALOG, A7,A6,A4 DIGITAL
    ANSELB = %00100000 'PORTS B7,B6,B4,B3,B2,B1,B0 DIGITAL BUFFERED, B5 ANALOG
    ANSELC = %00000000 'PORTS C7,C6,C5,C4,C3,C2,C1,C0 DIGITAL BUFFERED
    Hope this helps...
    EN82fn
    Oct 2010
    im also having issues to understand the configuration fuses of the PIC18F26K22. I believe that microchip would like to give you more access for each peripheral, but for us it makes it more complicated. It should be straight forward. In the manual it is not cleared what are the right configuration bits needs to be set. Especially the ones covers the OSCCON, OSCCON2 and OSCTUNE.
    For internal use of OSC and 4xPLL it is a bit more clear. But i'm really confused for the external OSC. This is what i have set up to now in this thread. Thanks to Ioannis and to Richard helping me out.
    http://www.picbasic.co.uk/forum/show...982#post143982
    It would be nice if we could have a clear configuration of the internal and external use of osc with 4x PLL.
    thanks a lot.
  1. DT_INTS and 18F26k22
    By Mike2545 in forum mel PIC BASIC Pro
    Last Post: - 9th September 2017, 17:08
  2. 12F1840 config issues
    By enigma in forum PBP3
    Last Post: - 15th February 2015, 08:49
  3. 18F26K22 slow startup
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 7th January 2014, 23:10
  4. Compiling for 18F26K22 - Does anyone have a solution for me?
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 28th August 2012, 13:49
  5. 12c508a Device Config. And Burning Issues
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 17:50
