Serial to WiFi <> Wifi to virtual com port
Results 1 to 12 of 12
    Default Re: Serial to WiFi <> Wifi to virtual com port
    Tibbo, Lantronix, Netburner and Wiznet do such modules. With the Wiznet I had some issues. Maybe because of the Power supply not supplying enough current. Never managed to make it work. Lantronix is my favorite though most expensive I suppose.
    Anyway, they all are in the logic of Serial to Ethernet and then your PC will run a piece of software to read the Ethernet and convert it to Virtual Com Port. Then your old software can just read the virtual serial port as if it was a real Serial data arriving from your Serial device connected locally.
    Ioannis, I also use the Lantronix RS232 to WIFI converters in my system at home. I haven't ever had any problems to date. I currently use about 6 of them.
    EN82fn
    At £150 a pop, I should hope not.
    George
    George, where did that 150 come from?
    OK, Lantronix are expensive comparing but the cable Ethernet to serial are around 50 and the Wifi to serial around 70-75.
    Other makers are cheaper of course. You can find from chine even cheaper.
    Google. Post must be 10
    George
    SWITZERLAND (french speaking)
    Thanks a lot for all your info
    Roger
  1. create an USB virtual serial port on pic18f4550
    Last Post: - 23rd November 2016, 18:42
  2. Serial WiFi module
    By Art in forum WiFi
    Last Post: - 6th December 2015, 03:50
  3. 2.4 ghz WiFi ID
    By tazntex in forum Ethernet
    Last Post: - 16th January 2013, 17:01
  4. Replies: 22
    Last Post: - 5th January 2012, 06:49
  5. USB to virtual serial com port Please
    By dala01 in forum USB
    Last Post: - 26th December 2011, 18:31
