PWM and audio noise
Results 1 to 23 of 23
    OK
    Default Re: PWM and audio noise
    On larger projects I may use over a dozen 0.1 uF (and one or two 0.01 uF) caps to filter board noise. I also add 10 uF and 100 uF caps near the power supply. I filter both the input to the LM7805 and the output. I use a 47 or 100 ohm resistor between my power source and voltage regulator to further filter the power supply. Invariably, whenever I'm getting unexpected behavior, it's often due to insufficient capacitive filtering. In other words, wherever you think, then add another one or two.
    Like someone suggested above. You should try to increase the frequency of your PWM. A 1khz square wave will have strong harmonics at 3khz, 5khz and 7khz. Thats right in the middle of the audio range. Then you start stepping thru the duty cycle, this will alternate between odd and even harmonics.
    Easy fix unless I'm missing something
    Change this
    PWM 1, Duty, 1000
    to this
    PWM 1, Duty, 20000
  1. Play & Record PWM audio?
    By Art in forum General
    Last Post: - 12th April 2015, 11:45
  2. Replies: 1
    Last Post: - 4th March 2013, 21:57
  3. Fan causing noise in audio circuit
    Last Post: - 28th August 2011, 11:47
  4. PWM - Mosfet/motor introducing noise
    By DynamoBen in forum Off Topic
    Last Post: - 18th October 2007, 15:37
  5. Input Noise
    By PJALM in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 19:26
