PBP3.1 Gold + MCSX+ + Microchip's ICD3 programmer?
Results 1 to 15 of 15
    Aug 2011
    Default Re: PBP3.1 Gold + MCSX+ + Microchip's ICD3 programmer?
    You should be able to. It's similar to adding the Pickit3, but instead of using PK3CMD.EXE you'll need to use the file from the MPLABX folder mplab_ipe\icd3cmd.exe
    See this thread for adding a custom programmer http://www.picbasic.co.uk/forum/showthread.php?t=14064.
    I'm sure there are other posts, as well as the MCSX IDE help.
    The command-line options for icd3cmd.exe can be found in the MPLABX folder docs\Readme for RealICECMD_ICD3CMD.htm
    Give it a try and see how it goes.
    If you're using IPE then this thread might be helpful. It also targets the PICKit3 which is likely different from the ICD3 but as eagleman pointed out you should be able to find the corresponding commands and options for the ICD3 and apply those.
    My guess is that for newer devices you're going to have go "thru" IPE since that's where they add support for the new devices. But once you have it working from within MCSP+ it's a one click operation. Then again, I've only worked with the PICKit3 so I don't really know about the ICD3.
    Aug 2011
    In case there's any confusion, the mplabx ipecmd.exe is the generic command-line driver that can handle any of the programmers.
    The '傍P' option lets you select which tool:
    傍PPK3 PICkit3
    傍PICD4 MPLAB ICD4
    傍PICD3 MPLAB ICD3
    傍PRICE MPLAB REALICE
    傍PPM3 MPLAB PM3
    傍PPKOB PICkit On Board (PKOB) demo boards
    The april update of mplabx is supposedly going to add the Pickit4.
    For legacy purposes, some tool-specific command line interfaces are available:
    RealICECMD.exe
    ICD3CMD.exe
    PK3CMD.exe
    PM3CMD.exe
    Probably easier to just follow Henrik's example and use ipecmd.exe for all of them.
    If I may add, ICD3 is a crap...
    It is supposed to be a professional programmer-debugger but ... un-functional for me. Also unable to power the very light (in aspect of current consumption) circuits and external power is always a must.
    PicKit3 is great and when possible I use the Stand alone software for this.
    Even better a third programmer, (in my case Elnec which is far away...).
    Aug 2011
    IMHO the ICD3 is the best one I've used. Far better than the pickit3, and I prefer it even to the RealICE.
    Mine supplies well over 150mA to the target... way more than the pickit2 or 3.
    There must be something wrong with yours. They usually fix them for free...
    Most of the time, there is even no communication with the ICD3.
    Something with Endpoint ..etc.
    All start with the new MPLABX thing. When I used the MPLAB 8.xx it worked OK.
    After changing firmware and swithced to X all went too bad.
    It is too pity as I really liked it as it was before.
    Aug 2011
    Oh, so your problem is with MPLABX. Welcome to the club.
    It's not the ICD3 that's crap, it's MPLABX. I've had problems with all the tools in every version of MPLABX.
    Some versions are better than others. I've had the least issues with the earlier V3.xx releases, but V4.xx is basically unusable for me.
    I try and use MPLAB 8.92 whenever I can.
    I have had issues with this too with both pk3 and icd3 . today I noticed it was much worse when using salea logic no salea in use minimal connection losses , so I did a bit of googling . one suggestion was to use a powered usb hub.
    well guess what it really works problem is gone
  1. PBP3 Code Does not Compile with PBP3.1
    By RossWaddell in forum PBP3
    Last Post: - 2nd July 2017, 08:42
  2. Replies: 2
    Last Post: - 4th June 2016, 22:21
  3. ICD3 with PBP
    Last Post: - 2nd November 2014, 12:41
  4. MCSX not fully loading, anyone else?
    Last Post: - 2nd February 2013, 05:28
  5. Problems with PBP3, Windows 7 and MELabs programmer
    By chaneyv4 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2011, 14:58
